Date/Time: Mon, 29 Apr 2024 03:30:10 +0000
E-mini s&P live data
View Count: 2315
[2020-12-04 12:42:05] |
User967852 - Posts: 26 |
I have sierra charts service package 5. If I wanted to get live data for the e-mini s&p 500(with market depth), what packages would I have to purchase. I was a bit confused by the pricing page and so I would like some clarification. Thanks |
[2020-12-04 14:49:44] |
You would need the Denali Exchange Data Feed. Note that it does not matter what Sierra Chart Service Package you are on. The data feeds are a separate item that is not dependent on the Service Package. If you are just wanting the e-mini S&P 500 with Market Depth, then you would need to enable the CME with Market Depth for nonprofessional Trading accounts exchange to get the cheapest price. Your pricing would then be: - Denali Exchange Data Feed For All Services: $25.00 USD per month - CME with Market Depth for nonprofessional Trading accounts: $10.40 per month Total: $35.40 USD per month You will find all this information, including the Setup Instructions on this page: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-05 10:38:53] |
Also be aware of the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-07 12:27:25] |
I tried setting up a futures account with AMP and they rejected me, is it possible to set one up with any of the following so that I can get non-professional fees for the exchange data: Interactive Brokers Live account Rithmic Live account CTS T4 Live account Sierra Chart Order Routing Service GAIN Capital (OEC Trader) Live account CQG Live account Transact Live account |
[2020-12-07 16:08:22] |
Overall, we really recommend using the Sierra Chart Order Routing to verify your non-professional status. You will find a partial list of brokers at Step #2 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-07 18:38:39] |
One last question regarding this, would I have to fund the account with at least $100. thanks for the help so far
[2020-12-07 18:57:36] |
The amount you would need to fund is up to the brokerage.
