Date/Time: Sun, 19 May 2024 21:31:30 +0000
data stuck
View Count: 513
[2020-11-30 03:26:35] |
User284416 - Posts: 25 |
hello charts don't seem to be moving with no reason. i've updated to current sierra version but quote boards show 0 in every field, footprint is not moving and even bid\ask lines are not displayed. i'm using evaluator account and opened YM and GC |
[2020-11-30 06:04:16] |
Yes this does make sense because there are several problems. You have no real-time exchanges activated on the Denali Exchange Data Feed: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed And additionally you would need to do this once you activate those exchanges if you activate the nonprofessional ones: The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. For now use the Trading Evaluator - Delayed service: Simulated Futures Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-30 06:05:04
