Date/Time: Sat, 04 May 2024 19:43:25 +0000
Question
View Count: 421
[2020-09-21 19:00:17] |
Mathieu44 - Posts: 21 |
I trade Futures and use a R Trader Pro via AMP Clearing w/Rithmic feed to Bookmap to trade via Bookmap's software. I was introduced to your charting software via Futures Trader 26. He is providing us with his charts, etc. I would like to get a real time feed that will support his charts. I know Rithmic is not going to do it. What is the best affordable option for me?
[2020-09-21 20:03:00] |
John - SC Support - Posts: 31362 |
We recommend using our Denali Exchange Data Feed. You will find all the information on this real-time data feed along with pricing and setup instructions here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-21 20:06:05] |
Since Rithmic/R Trader Pro/AMP doesn't work, I don't have a trading platform that is supported. So which pricing model do I get if I want to trade the futures and see the $Tick, $ADD, etc.?
[2020-09-21 20:43:57] |
You can still use Rithmic, and we are in discussions with them about a new implementation, so things have changed a little. If you want to use Rithmic, then just be sure you have the updated Bridge files. You can get them here: Rithmic Bridge Files Otherwise, you would need to select the exchanges that are marked as Professional or for Users Without a Trading Account. The Market Statistics are included with your Sierra Chart package. Refer to the information here: Sierra Chart Market Statistics For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-21 20:56:15] |
I get port number not specified. Will exit.
[2020-09-21 21:08:48] |
It worked. Apparently I need to have SC running prior to clicking on the bridge executable.
