Date/Time: Sat, 27 Apr 2024 08:39:33 +0000
Error: waiting to reconnect
View Count: 547
[2020-08-12 20:19:58] |
User46134 - Posts: 4 |
I can not connect to data. Since last three hours I am getting "waiting to reconnect" message. Please send your response to my email address: stunuli@gmail.com. Sincerely Sitara Tunuli email: stunuli@gmail.com |
[2020-08-12 20:40:20] |
Apparently there was a problem at TransAct. It sounds like they have fixed it now, but you would need to check with them to make sure.
[2020-12-01 20:52:15] |
User340063 - Posts: 1 |
I can not connect to data. I am getting "waiting to reconnect" message. Please send your response to my email address: ** Sincerely Date Time Of Last Edit: 2020-12-01 22:18:12
[2020-12-01 21:33:19] |
First thing is to disconnect and reconnect to the data feed to see if that resolves your issue. Refer to the instructions here: File Menu: Procedure to Reconnect to the Data and Trade Servers If you continue to have a problem after that, then get us your Message Log following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
