Date/Time: Sun, 19 May 2024 11:06:10 +0000
[Locked] - Copy drawings and studies to another chart within the same chart book
View Count: 1513
[2020-08-02 20:05:13] |
User350698 - Posts: 35 |
I have read threads on this watched YouTube videos I’m trying automatically have lines from my source chart taken to my other charts. I thought it was a simple as going to the source chart then Chart settings>advanced settings 2 then enter the chart numbers of the charts where you want the lines to go. Upon doing this I was expecting all the lines I had to copy over to the charts I had entered it to do so but nothing happens. What am I doing wrong ?
[2020-08-02 20:51:40] |
No this is not how it works. Refer to the documentation here: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-04 06:57:41] |
Ok thanks I have sorted that now. Is there a link to overlay moving averages, keltner channels.
[2020-08-04 19:02:09] |
Refer to the information here for how to add a study to the chart: Chart Studies: Adding/Modifying Chart Studies And refer to: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-16 20:20:23] |
Tonight I have been trying to overlay a study from one chart to another (in the same chart book). What I want to achieve is that my moving averages & keltner from off my daily chart overlay onto my 30 min chart. I use the study/price overlay add the study, select the source chart in settings then choose the appropriate studies. I have attached a picture as to what happens when I do this. I want for example the 200sma from off the daily overlaid onto my 30 min chart, this is adding the study underneath. What am I doing wrong ? Picture shows the keltner & 100sma but not overlaid over the candles but separate, underneath.
Date Time Of Last Edit: 2020-08-25 00:45:31
[2020-08-17 10:19:47] |
When posting an image of a chart, only use this method: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-22 09:53:27] |
Im confused i upload the chart and it says sent to system clipboard, I dont know where system clipboard is. Here is a copy of the link for the chart that i uploaded http://www.sierrachart.com/image.php?Image=1598089753287.png The explanation for what I was asking about is above.
Date Time Of Last Edit: 2020-08-25 00:42:36
[2020-08-25 00:43:12] |
You need to set the region for the Study/Price Overlay to be Region 1. Refer to the information here: Chart Studies: Settings and Inputs Tab >> Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-25 08:06:05] |
Ok thanks that’s all sorted now, I have a list of things I want to sort out shall I start a new thread or continue to use this thread ?
[2020-08-26 00:33:45] |
You need to first refer to the documentation rather than posting. Refer to: https://www.sierrachart.com/index.php?page=doc/Contents.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
