Date/Time: Sat, 18 May 2024 12:02:59 +0000
Denali Feed Support
View Count: 509
[2020-06-04 14:42:56] |
User677721 - Posts: 3 |
Hello, Finished setting up following all the steps. I do not see an M symbol on my chart. my symbols are coming as ESM20 without the -cme. Jibin. Date Time Of Last Edit: 2020-06-04 15:11:42
Sierra.PNG / V - Attached On 2020-06-04 15:11:24 UTC - Size: 13.15 KB - 200 views Attachment Deleted. |
[2020-06-04 17:28:50] |
Make sure that the option for Allow Support for Sierra Chart Data Feeds is enabled on the Data/Trade Service Settings window (File >> Data/Trade Service Settings). Also follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog ---- Additionally: The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
