Date/Time: Sat, 18 Jul 2026 06:02:06 +0000
LMAX FIX order issue
View Count: 2205
| [2013-04-15 09:20:28] |
| darioneto1 - Posts: 2 |
Hi support I’m testing the LMAX FIX connection and seems like the bracket order doesn’t work properly. When execute the bracket long position for example, 1. With Scale in enabled ( contract number doesn’t increase on the stop loss while adding on more contracts to the position) 2.I’m unable modify the Stop loss (sell stop) order however I’m able to modify Take Profit (Sell limit order)while drag and move There was an error with the order modification: Order modification failed. Internal order ID: 1465 | 2013-04-15 10:16:27 3.The stop for BE doesn’t seems to be triggered to the specified value in ticks. (btw. my charts settings are in Ticks – Ignore Quantity) |
| [2013-04-16 03:34:50] |
1, 2, 3. This is because LMAX does not support the modification of a Stop order. We will have to implement this on the Sierra Chart side. This will be done in the next 3 to 4 weeks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-04-16 04:45:38] |
Thanks for your prompt response. I conclude when you will implement this function on Sierra Chart side, the stop loss would be kept only on client machine (hidden stop) and when triggered it will become market order? Only Take profit will reside on server side? |
| [2013-04-16 05:19:40] |
Stop orders will still be orders that are sent to the exchange. They will just go through a Cancel and New Order sequence when modifying them.
| [2013-12-31 19:22:17] |
| Fraois - Posts: 12 |
Do I get to use buy stop and sell stop not as stop loss but as single orders to chase momemtum and put it on LMAX server side?
| [2013-12-31 19:46:41] |
Yes. These are supported on the LMAX server side.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-31 19:47:09
| [2013-12-31 19:59:47] |
Sorry, is the same situation supported on Currenex server side? I mean I want to have a time priority to get filled when the market reach the buy stop/ sell stop price not being used as stop loss
| [2013-12-31 20:22:00] |
The stop orders are held on the server side.
