Date/Time: Sat, 18 May 2024 17:04:05 +0000
Not getting Live Data
View Count: 801
[2020-03-11 01:57:18] |
strykerr - Posts: 14 |
Hi, I am subscribed to Sierra Chart Exchange Data Feed but I am not receiving live data. What do I need to do? Thanks. |
[2020-03-11 02:43:55] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) You should be receiving delayed streaming data at this time. Please confirm that you are. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-11 17:55:34] |
I am using TD Ameritrade and my broker is set in the Account Details page.
[2020-03-11 17:57:28] |
You could not be using TD Ameritrade. Sierra Chart no longer supports TD Ameritrade. We are not sure what "Account Details page" you are referring to. Select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Tell us the symbol of one of the charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-11 17:57:38
[2020-03-11 18:35:18] |
SC Data All Services. I used to use Sierra Charts with TD Ameritade as my broker last year. I didn't know you had stopped supporting it. Symbol MESH20. |
[2020-03-11 20:02:45] |
Is the chart at least updating but delayed? It should be. So you only have a TD Ameritrade account for trading futures? If so you need to follow the easy solution method here to access the real-time data: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-11 20:21:38] |
Yes, I only have TD Ameritrade account. Do I need to sign up with Denali Exchange Data Feed if I want to keep my account at TD Ameritrade? |
[2020-03-11 22:23:53] |
What if I don't want to open an account with AMP. Is there another way to get access to live data at the discounted price?
[2020-03-11 23:51:47] |
Can I get an answer to my questions? I am try to get this working. |
[2020-03-12 09:18:36] |
We do not have a good answer here, at least the one you are looking for. We have to comply with exchange rules. You just cannot access the real-time data when you have a TD Ameritrade account. We are going to cancel the data feed for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-12 09:18:50
[2020-03-13 17:08:08] |
Would an account with Tradovate also work?
[2020-03-13 18:07:54] |
Sort of. This is another complication. You will have to pay more money to your broker for CQG access.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-13 18:08:06
[2020-03-13 18:09:47] |
In regards to our answer at post 12, we really really do not recommend that solution. Since we want everything to work well for users. The best solution is explained here: Easy Solution to CME Funded Trading Account Requirement You only have to open an account for 100 USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
