Date/Time: Sat, 18 May 2024 15:25:08 +0000
Number bars not matching up
View Count: 597
[2020-01-02 18:38:13] |
User502498 - Posts: 33 |
Hello. I have two computers, one a VPS and one a local PC. Both are running the latest version of SC. Both using the Rithmic datafeed from AMP using the Rithmic 01 server. Both are running the exact same chart book. The only difference is the VPS is in Chicago and the computer in CA, which is a 2hour time difference. I cannot get the aligned 5t renko bar to match 100%. Some of it matches and some of it doesn't. Any thoughts? The red arrows are showing areas where it doesn't match, but there are many bars where it matches exactly. |
ES-Imbalance.Cht - Attached On 2020-01-02 18:36:32 UTC - Size: 30.66 KB - 228 views unknown.png / V - Attached On 2020-01-02 18:36:48 UTC - Size: 735.54 KB - 236 views |
[2020-01-03 18:40:48] |
We can only refer you to the documentation here in regards to this: Working With Charts: Resolving Differences of Chart Bars Between Charts We recommend using this data feed instead of the Rithmic data feed : Denali Exchange Data Feed In which case you may also be interested in this order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service We do not provide technical support for Rithmic any longer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-03 18:41:45
