Date/Time: Tue, 14 May 2024 14:54:59 +0000
User Email Question
View Count: 621
[2019-10-03 22:08:05] |
Sierra Chart - Max - Posts: 5609 |
I have a client that has Sierra set up with Rithmic but experiences some “freezing” of his charts once in a while, do you think it has anything to do with Rithmic data since he said he has heard before that Rithmic does not run well on Sierra? Anything he can do about it other than change datafeed? I cannot find any info if futures options can be traded on Sierra Charts. Can you please advice if that is possible? Sierra Chart Support |
[2019-10-04 09:52:49] |
No this definitely does not have to do with Rithmic data. A problem like this would be more likely to be encountered with CQG rather than Rithmic. Rithmic data is processed on a background thread. There must be some other reason for the problem and they should find the answer in this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For futures options trading, we recommend either of these two services: CQG Trading Platform Service Sierra Chart / Trading Technologies Futures Order Routing Service Since with these services you can get a listing of the available options symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-04 09:53:05
