Date/Time: Sun, 19 May 2024 03:48:25 +0000
Denali data feed problem
View Count: 1300
[2019-08-10 18:41:53] |
User740266 - Posts: 26 |
If I only need to subscribe CME, CBOT, NYMEX, and COMEX exchanges' historical and real-time data plus using number bars, do I only need to subscribe to all of the following? 1.Advanced 5 Package fee for $36 2.Real time connection fee for 20$ 3.Denali exchange fee for 20$ Do I need a validated broker's trading account in order to subscribe to Denali exchange fee? Thank you. |
[2019-08-10 22:53:06] |
You are not quite correct in what you need to activate. Here is the list: - Advanced 5 Package: $36 (needed for Numbers Bars) - Denali Exchange Data Feed (the feed itself, not including exchanges): $25 without SC Order Routing; $20 with SC Order Routing. - Full CME Group exchange fee: $3.25 to $462 (pricing depends on trading status and whether you want Market Depth data or not). If you have a funded futures trading account and do not require market depth data, then the exchange fee is $3.25, but if you do not have a funded futures trading account, then each CME Group exchange is $42 to 115.50. Refer to the following for more information on this: Is Historical and Real-time Futures Data Included?: Available CME Exchanges When Using a Supported Trading Service Also, for more information on the SC Order Routing Service, refer to the following: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-11 22:03:44
[2019-08-11 11:13:32] |
I do not understand what's the difference and advantage between subscribing the denali exchange data feed instead of the real time connection fee? Would you mind to explain more please?
[2019-08-11 22:04:11] |
Yes we mind. The pricing is stated above. That is what you need to pay if you want to use a Sierra Chart provided futures data feed which in this case will be the Denali Exchange Data Feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-11 22:04:22
[2019-08-11 23:21:51] |
I do not understand why I need to pay for two exchange fees and why I do not need to pay for the real time connection fee that originally I should pay for?
[2019-08-12 06:07:32] |
Why would you pay twice for the exchange fees? This is the real-time connection fee: - Denali Exchange Data Feed (the feed itself, not including exchanges): $25 without SC Order Routing; $20 with SC Order Routing.
[2019-08-12 07:47:51] |
I understood now thanks. So the only advantage of paying Denali fee is to get more symbols permissions for live quotes?
[2019-08-12 17:19:23] |
There are two separate data feeds. Each of them is documented here: Sierra Chart Exchange Data Feed Denali Exchange Data Feed You will just use one of them. If you require CME data only, you will want to use Danal Exchange Data Feed. It does not have symbol limits, and it is lower cost. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
