Date/Time: Sun, 19 May 2024 07:44:24 +0000
Connection
View Count: 1382
[2019-07-26 09:16:41] |
kdpleiser2 - Posts: 12 |
Hello I need datasets for nyse,nasdac and spy without!!!!!! Broker just for charting Please help me Regards Klaus-Dieter Pleiser |
[2019-07-26 10:08:01] |
Did you require real-time data for those exchanges. Or just historical data?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 10:08:08
[2019-07-26 10:30:28] |
I need real-time data without broker!!!
[2019-07-26 11:06:16] |
In this case you will need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed You will need to pay for the real-time connection and also activate the US Equities exchange: Sierra Chart Exchange Data Feed: Supported Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-26 11:43:43] |
I have a big problem to activate these instruments Wahr ist the Price for the real-time datAfeed and the connection pet month ?? Real-time datAfeed bots 10,25 usd per month Connection for 20 real-time instruments ????? I can’t activate it and I need your help Sorry I paid already 50 usd in additional big nothing happens I am very annoying Regards Klaus-Dieter Pleiser |
[2019-07-26 17:53:39] |
You activated the wrong service. We are going to cancel the Denali Exchange Data Feed on your account and refund it. Update: this is now done. You need to follow the step-by-step instructions here: Sierra Chart Exchange Data Feed: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 18:25:06
[2019-07-26 23:57:09] |
We will help you through the setup process. But we think it is best to wait until August 1 so you do not pay a full exchange fee right at the end of the month. And we have issued you a credit for the data feed previously activated. And we have added an additional week of usage time to your account as well. How many symbols you want to receive real-time data on at the same time? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-27 07:34:30] |
i need max. 20 instruments at the same time and Thank you for your welcome and your help |
[2019-07-27 09:29:39] |
Thank you for the information. Would you like to wait until August 1 for us to start the data feed for you? In this way you will save paying the 10.50USD exchange fee just for the few days remaining in this month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-27 10:39:17] |
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[2019-07-28 04:56:21] |
Please remind us August 1 to help you through the activation of the services. We will need you at that time also to sign the market data agreement.
[2019-08-01 07:50:36] |
599/5000 Good day, I should remind you that we wanted to adjust the settings for NYSE, NASDAC and SPY together with data feed together. Furthermore, I need from you a hint, as I in a chart z.V. 1 hour on the right side set a volume profile for the current day and on the left side a separate volume profile should be set, which shows me the current week. Continue in the daily chart on the far left side a VP for the whole year and then a VP for each week. Thank you for your helpfulness. Where can I get the heatmap? |
[2019-08-01 08:21:38] |
Could you complete the agreement (Market Data Agreement (With US Equities Agreement) ) so then we can go on to the next step: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures&reload=1#Agreements Let us know when done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-01 08:21:55
[2019-08-01 10:01:22] |
OK its done
[2019-08-01 11:10:23] |
At this time you are all set to receive the real time US Equities data feed.
[2019-08-01 11:52:23] |
Which service should I take? Barchart does not exist in the list. And what do I do with the volume profile? Where can I find the heatmap? |
[2019-08-01 13:08:39] |
Sierra Chart is already set to the correct service. There is no other service you need to select within Sierra Chart. Follow the instructions here to open a chart: Getting Started, Opening Charts and Basic Trading: Open Chart You just need to manually type the stock symbol. For example for Microsoft you would use the symbol MSFT. Or you could perform a symbol search: File Menu: Searching for Symbols Furthermore, I need from you a hint, as I in a chart z.V. 1 hour on the right side set a volume profile for the current day and on the left side a separate volume profile should be set, which shows me the current week. Continue in the daily chart on the far left side a VP for the whole year and then a VP for each week. In regards to this, we will put together an example for you later today.
[2019-08-01 18:57:42] |
Here is a Study Collection that you can apply to one of your charts that will give you a Daily Volume by Price profile on the right side, and then Weekly and Yearly Volume by Price profiles that are based at the beginning of their periods on the left (that is, you would need to scroll back in time to the beginning of the current week to see the weekly profile and then back further to the beginning of the year to see the yearly profile). Refer to the following documentation for how to use the Study Collection: Study Collections: Using a Study Collection Provided by Sierra Chart Support Also, the Heatmap is called the Market Depth Historical Graph in Sierra Chart. You will find the documentation for it here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
VbP-Day_Week_Year.StdyCollct - Attached On 2019-08-01 18:56:24 UTC - Size: 28 KB - 283 views |
[2019-08-01 20:13:18] |
Also, be aware of the following setting in the Volume by Price study: Allow Side by Side Profiles on Right Side - This will allow you to have all the profiles in the right side of the chart for easy viewing. Refer to the documentation here that gives instructions on how to use this option and set up the profiles: Volume By Price Study: Allow Side-By-Side Profiles on Right Side For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-02 07:56:02] |
Good morning dear service people. I do not want to annoy you but I copied everything exactly as directed but I do not see the new StdyCllct in the left window Analysis. If I look under "SaveStudies" it is there, but I do not get it in the left window to take it from there to the chart. So it exists in the directory .. \ Data and it is also displayed under "Save Studies" but not under "Studies Available" or "Add Custom Studies". What am I doing wrong???? THANK YOU for your great effort with me.
Attachment Deleted. Heldental_135 2019-08-02 09.50.jpg / V - Attached On 2019-08-02 07:55:25 UTC - Size: 158.52 KB - 269 views |
[2019-08-02 09:09:58] |
Attachment Deleted. Heldental_135 2019-08-02 09.50.jpg / V - Attached On 2019-08-02 07:50:58 UTC - Size: 158.52 KB - 304 views |
[2019-08-02 14:39:02] |
In order to use the Study Collection select the Analysis pulldown menu in Sierra Chart, then down towards the bottom of that pulldown menu is the list of Study Collections available to you. You should see the one that you downloaded in there. Just select it from that pulldown menu and it will add it to your chart. This is explained a little better in this section of the documentation: Study Collections: Applying a Study Collection to a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
