Date/Time: Sat, 04 May 2024 16:36:52 +0000
Problem with charts since changing data source
View Count: 913
[2019-06-17 22:18:12] |
User285256 - Posts: 8 |
I switched from Rithmic to SC Data -All Services mid-morning today.Now my charts are stuck at the the time I ended Rithmic and started SC as the data service. I have closed the program and restarted multiple times with the same result. I have tried replaying multiple charts; they all stop at the time: when Rithmic ended and SC started. There is probably a simple fix, but I haven't been able to find it. Thank you, Bill French |
[2019-06-18 00:02:30] |
Do you just require historical data? Make sure the symbols are correct. They will need to be changed to match the SC Data-All Services service. The first step is to update to the current version of Sierra Chart: Software Download: Fast Update After the update, then use this new command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-21 05:12:06
[2019-06-20 23:03:01] |
Yes, I do need realtime data.Is this not included in my current package? If not , what does it cost and how do I go about getting it? Thanks, Bill |
[2019-06-21 04:09:37] |
Do you still have a funded futures trading account? For the reason why we ask this question, refer to: Sierra Chart Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-21 04:10:06
[2019-06-21 18:25:27] |
I recently closed an account that gave me access to Rithmic. I haven't decided which brokerage to go with, so the answer is no.
[2019-06-21 18:46:01] |
Ok, do you just require real-time data for the CME E-mini futures contracts?
[2019-06-21 22:36:16] |
Yes,that's primarily what I trade. I can do without everything else.
[2019-06-23 20:17:39] |
Therefore, you are going to need to pay the CME E-mini exchange fee at 42 USD per month plus the cost of the Sierra Chart package you are using and the cost of a real-time connection. We recommend waiting until next month when we have a new package available which is going to bundle the CME data feed with Sierra Chart. Please follow up with us in about a week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-01 16:00:48] |
Any news of your CME package ?
[2019-07-01 17:19:02] |
It is going to be released today. It still may be a few hours away.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-01 17:19:10
[2019-07-03 13:23:02] |
What is status as of now ,Wednesday AM?
[2019-07-03 16:18:56] |
This is now available: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-09 17:14:06] |
I made a mistake somewhere, in selecting a Denali package ,, and now the only packages i see to activate are ones thhat require a broker,which do not apply to me. No matter what i try, it brings me back to that screen. Can you hhelp me? I have ALS and am struggling with this.
[2019-07-09 17:50:14] |
We are solving this now. We will make sure all of the exchanges are listed.
[2019-07-09 17:57:42] |
All of the exchanges are now listed here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
