Date/Time: Sun, 18 Oct 2026 09:49:05 +0000
TSX Real Time Data not automatically updating
View Count: 1009
[2019-02-19 16:10:26]
USERanon - Posts: 4
I have purchased the TSX Realtime
When I have an intraday 1 minute chart loaded, it does not automatically update.
The only way I can get it to update is to disconnect and reconnect again.
ELD.TO [M] - However when I reconnect I am still 2 minutes behind.
[2019-02-19 18:22:33]
We checked this data feed and we do not see any problems with the real-time data on our server.
Reconnect to the data feed:
If we still cannot determine what the problem is we will look at this with remote assistance.
And it might not be unusual for a symbol that does not trade a lot, for it to be two minutes behind.
Date Time Of Last Edit: 2019-02-19 18:23:04
[2019-02-19 18:53:27]
USERanon - Posts: 4
Thank you kindly for the response
Log sent internally
[2019-02-19 19:22:23]
USERanon - Posts: 4
I do get this message though
symbol unknown (yet it downloads the data)
|Over symbol limit: limit is 0 symbols
imagesymbol.png / V - Attached On 2019-02-19 19:20:40 UTC - Size: 1.65 KB - 396 views
[2019-02-19 19:24:37]
Yes we see that. We are looking into this now.
[2019-02-19 19:58:28]
We have implemented a temporary solution to this problem. Reconnect to the data feed:
There is an issue with determining the exchanges on your account on the server side. We need more time to look into this, but for now the issue is resolved.
[2019-02-20 17:44:19]
USERanon - Posts: 4
I did reconnect and the same problem persists, it continues today as well. I continue to have 0 symbol limit and worried that all this disconnect and reconnect might get me booted off the server
[2019-02-20 18:21:01]
We apologize for this. We did look into this very carefully yesterday and the problem cleared up. It has to do with the authorization data from our vendor of record. We will get it temporarily resolved again.
Follow the instructions here to reconnect to the data feed:
Date Time Of Last Edit: 2019-02-20 18:22:17
