Date/Time: Fri, 03 May 2024 07:20:17 +0000
I would like to have a FXCM demo account assigned to my Sierra C
View Count: 2376
[2018-08-17 18:50:43] |
nioko54130 - Posts: 108 |
I'm trying to connect on the FXCM server that you have shown to me : "FXCM Demo Trading (Standard) - DTC", but i can not add a login or a account number, because there are no case where i can put it. I have tryed to connect to the data feed like that : just after had selected the right fxcm server, i have clicked on file menu and connect to data feed, but i can not connect to the data feed that's my Sierrachart logs file here : "Software version: 1789 32-bit | 2018-08-17 20:40:58 Usage end date: 2019-05-31 | 2018-08-17 20:40:58 Enabled for: Advanced Features. | 2018-08-17 20:40:58 Enabled for: Advanced Features 2. | 2018-08-17 20:40:58 Enabled for: Sierra Chart Historical Data Service. | 2018-08-17 20:40:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-17 20:40:58 Current selected Data/Trading service: Futures Trading Evaluator | 2018-08-17 20:40:58 Chart Update Interval: 10 | 2018-08-17 20:40:58 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-08-17 20:40:58 2018-08-17 20:40:57 Local computer time | 2018-08-17 20:40:58 2018-08-17 18:40:57 Local computer time in UTC | 2018-08-17 20:40:58 2018-08-17 20:40:57 Local computer time in SC Time Zone | 2018-08-17 20:40:58 2018-08-17 18:37:38 Server time in UTC | 2018-08-17 20:40:58 Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-08-17 20:40:58 Program path: C:\SC crypto\ | 2018-08-17 20:40:58 Data Files path: C:\SC crypto\Data\ | 2018-08-17 20:40:58 OS Version Number: 10.0 | 2018-08-17 20:40:58 Locale Setting: C | 2018-08-17 20:40:58 Checking for new symbol settings for service code fxcm | 2018-08-17 20:41:13 Current selected Data/Trading service: FXCM Demo Trading (Standard) - DTC | 2018-08-17 20:41:13 HTTPS connection to www.sierrachart.com:443 (14) | Creating socket. Using TLS 1.2. | 2018-08-17 20:41:13 HTTPS connection to www.sierrachart.com:443 (14) | Connecting to IP: 204.15.192.108. | 2018-08-17 20:41:13 Requesting symbol settings for service code fxcm. Overwrite = on. | 2018-08-17 20:41:14 Symbol settings received. | 2018-08-17 20:41:14 Processed 826 symbol settings. | 2018-08-17 20:41:16 FXCM Demo Trading (Standard) - DTC | Connecting to the server fxcmorders.sierracharts.com. Port 11097 | 2018-08-17 20:41:16 DTC Client socket (15) | Creating socket. Using TLS 1.2. | 2018-08-17 20:41:16 DTC Client socket (15) | Connecting to IP: 192.81.56.146. | 2018-08-17 20:41:16 FXCM Demo Trading (Standard) - DTC | Connected to server. | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Starting socket receive thread. | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Sending encoding request to server: Binary VLS | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Setting DTC encoding to Binary VLS | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Sending logon request message. | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Received logon response. | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Server Name: SC DTC Server. | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Server protocol version: 8. Client protocol version: 8 | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Connection error: Username or Password is incorrect. | 2018-08-17 20:41:17 * DTC Client socket (15) | Initiating close of socket by core. | 2018-08-17 20:41:17 FXCM Demo Trading (Standard) - DTC | Disconnected. | 2018-08-17 20:41:17 DTC Client socket (15) | Shutdown started. Waiting for graceful close. | 2018-08-17 20:41:17 DTC Client socket (15) | Socket gracefully closed by remote side. | 2018-08-17 20:41:17 DTC Client socket (15) | Closed. | 2018-08-17 20:41:17 HTTPS connection to www.sierrachart.com:443 (14) | Socket gracefully closed by remote side. | 2018-08-17 20:41:19 HTTPS connection to www.sierrachart.com:443 (14) | Initiating close of socket by core. | 2018-08-17 20:41:19 HTTPS connection to www.sierrachart.com:443 (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 20:41:19 HTTPS connection to www.sierrachart.com:443 (14) | Closed. | 2018-08-17 20:41:19 " thank's for your help |
[2018-08-21 00:00:34] |
Could you please try connecting again and let us know if there is a problem. You do want to use this particular Service: FXCM Demo Trading (Standard) - DTC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-21 00:02:10] |
Okay we see what the problem is. You have two Sierra Chart accounts and the account that you are using on this Support Board is the account that the FXCM demo account was assigned to. But you are using Sierra Chart which is trying to connect to the FXCM service, with a different account. Refer to: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-21 20:44:56] |
thank's! it's now working good! therefore, do you know how i can overlay my existing alerts from the CQG data feed connected to my main sierrachart platform, to the FXCM data feed connected on the second copy of Sierrachart? thank's |
[2018-08-21 23:02:53] |
You can access the FXCM data in the instance of Sierra Chart which is connected to CQG. Would that work for you?
[2018-09-30 09:02:52] |
Yes i can get it from the CQG data feed connected to SierraChart, of course! But, i need to trigger an action on a CFD instrument (from FXCM) which is coming from an alert from the futures instrument! Let's imagine, i get an alert to buy the market on the 6E futures (eur/usd) from CME (received with CQG), and i would like to apply these alert on the FX contract (EURUSD). Do you know how i can proceed ? More of that, if i have a connected FXCM account to my SC station, do you know if i can exploit some alerts received from the futures market on a first SC instance or platform, and use it on a second SC instance, or on a second SC station opened? Which is the best solution that i have to studie ? |
[2018-10-01 19:05:07] |
Yes, this is possible. So you want to access the futures data in the instance of Sierra Chart used to trade with FXCM. This can be done. We need to do a little set up on our side but it is going to require that you use this data feed: Sierra Chart Exchange Data Feed Let us know if you want to proceed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-01 21:43:47] |
Hi dear Support group! Thank's for your update! Good news! this is exactly what i want to do! I'm ok ! Let me few days to subscribe to the SC futures data feed and i will try to achieve that. Thank's for your precious help |
[2018-10-02 04:49:28] |
So then do you want to just have access to the Forex futures symbols when using FXCM? If so, we can do that. Please confirm so we do not forget about this. It only takes us about a day to get this done. Really just about 30 minutes. But just allow up to a day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-02 07:31:59] |
Hello dear support group! Thank's for your quick reply! basically, i have different alerts that are printed on my chart, and i'm using an automated trading strategy which is based on these alert. These alert need a futures data feed because i'm using the volume and the market depth data to get my signals! Therefore, i want to trade these alert on a CFD broker, like FXCM! I know that i can already have the FXCM data feed (for reading or trading yes) ; but i need to know how can i use my alert from the futures data feed (why not the SC futures data feed) and trade these alert on the cfd market with FXCM. Alerts are received on one futures data feed, and trading action with this alert are made on an other one data feed (fxcm for example). That's my main need :) Thank's for your help! |
[2018-10-03 17:26:57] |
We will add the CME Forex futures symbols to the FXCM services, so you have access to them, but you will need to use the Sierra Chart Exchange Data Feed for the real-time data for them: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-03 17:27:12
[2018-10-08 06:15:57] |
Hello dear Support group! If i understand well, basically, i just have to subscribe to the SC futures data feed, then connect my SC station to an FXCM account, and put a tick on "allow support for sierrachart data feed" on the data trade service window ? If yes, i will only need one instance of SC station right ? Please confirm me this information, in order that i set that this week! thank's a lot Nico |
[2018-10-08 06:37:24] |
If i understand well, basically, i just have to subscribe to the SC futures data feed, then connect my SC station to an FXCM account, and put a tick on "allow support for sierrachart data feed" on the data trade service window ? If yes, i will only need one instance of SC station right ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-08 15:13:47] |
Yes this is all correct. You will see the future symbols now listed in File >> Find Symbol >> Futures-Currencies.
Ok great! So, if i use one SC instance connected to an FXCM account, with the SC futures data feed activated with it, i will be able to get the futures currencies instrument data! Let's imagine that i work on the 6E futures contract, when one of my HFT alert will be triggered with my automated trading strategy, the opened position will be directly opened on the FXCM CFD/FX account ? (even if the data are coming from a futures data source) ? If yes, it will be excellent! :) If it is not the case, should i look for a specific studies to build the connection between the two data feed or it is already done today ? Thank's for help and your quick reply! Nico |
[2018-10-08 19:28:09] |
To do what you want requires that you use this particular setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-09 02:09:14] |
Very good! i have just checked that! I can see on your documentation that we can also adjust the tick size with a price multiplier! It is very usefull. Does it work for the entire instrument selection from FXCM ? or only for forex instrument? For example, if i get the market depth data from the CME emini nasdaq100 and if i trade the NAS100 from FXCM, will it be ok? thank's! |
[2018-10-09 03:18:05] |
I can see on your documentation that we can also adjust the tick size with a price multiplier! It is very usefull. You can certainly make these adjustments for any symbol, but you have to really understand what you are doing and whether it makes sense or not. From our perspective we are not sure what you are exactly intending.
Does it work for the entire instrument selection from FXCM ? or only for forex instrument? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-09 06:08:15] |
basically i just want to get my trading signals from a futures data source (for example SierraChart futures data feed), then trade these signals on a cfd/fx source (as fxcm). That's all! The goal is to benefit from the market depth data from a futures contract, and trade the underlying on a CFD or FX contract! the other ultimate aim is to run my automated trading strategy (working now on SierraChart with a futures data feed) directly on a CFD/FX broker! Thank's for your help |
[2018-10-09 15:22:08] |
Okay, but remember the pricing is different between the futures and cash market, so you have to work out the details of different pricing. That is not something we can help with.
[2018-10-09 16:16:33] |
User138602 - Posts: 169 |
Just a tip: Check fxcm out first. They lock up your money for up to 3 months....so you cant transfer money back to your bank account. They are still in financial trouble due to the CHF debacle and use customer money to earn them some interest. |
[2018-10-10 17:59:48] |
Hey dear SC support! thank's for your reply! So now, you can confirm to me that the connection to the FXCM account in real time/live is ok and can be "coupled" with a sierrachart futures data feed? Do you plan to add this same "solution" for other FX/CFD broker? For example if i want to use the SC futures data feed to get the data and my signals, and trade these signals on an other CFD broker, like Dukascopy or LMAX ? Does it possible ? Thank's for your reply And thank's for the tip regarding FXCM.... |
[2018-10-10 22:57:46] |
So now, you can confirm to me that the connection to the FXCM account in real time/live is ok and can be "coupled" with a sierrachart futures data feed? Yes.Do you plan to add this same "solution" for other FX/CFD broker? For example if i want to use the SC futures data feed to get the data and my signals, and trade these signals on an other CFD broker, like Dukascopy or LMAX ? Does it possible ? Yes but just LMAX. But before you do this, let us know so we can make sure the symbols are listed for LMAX.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-10 22:58:12
[2018-10-22 16:39:31] |
for the moment, i would like to try with FXCM first! But i have a simple question : --> should i open a new FXCM demo account and link it on my SC account to be able to do my backtest in demo mode ? or --> should i only try the SC futures data feed with the FXCM symbol added on the chart setting windows as a "traded symbol" without an FXCM demo account ? thank's |
[2018-10-22 17:50:34] |
--> should i open a new FXCM demo account and link it on my SC account to be able to do my backtest in demo mode ? --> should i only try the SC futures data feed with the FXCM symbol added on the chart setting windows as a "traded symbol" without an FXCM demo account ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-22 17:51:02
