Date/Time: Tue, 07 May 2024 15:48:35 +0000
Candlestick pattern direction and custom text + sound
View Count: 1093
[2018-01-22 15:21:36] |
s291117 - Posts: 28 |
Hello Support, I wish to know how to set up a symbol that would show the direction for each candlestick pattern that has one originally from the list available: CandleStick Patterns Finder: Available Patterns > Is there a way to affect a specific color (red or green) to the custom text for each pattern that is a directionnal signal by nature ? > Is there a way to change the text of each pattern chosed to have a more custom visual experience ? When I try to define a custom Text for the patterns n°2 to 5 in the Subgraph panel, Sierrachart gets back to "Ignore" as draw style nearly immediatly...So there is no way to change HNM for HangingMan just to take an example.. > Is there a way to affect a specific custom sound for each pattern ? In the case I would create all the different sounds required to have an alert when one of the patterns occurs, how do I link the pattern to the sound on registered in the librairy ?? Thanks for your precisions. |
[2018-01-22 21:00:35] |
All of this is going to require custom development. Refer to: Advanced Custom Study Interface and Language (ACSIL) The source code for the Candlestick Patterns Finder study is available: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-24 08:26:51] |
Thanks you but I am definitively not a developper. Perhaps you might think to add some features in the next upgrades ? > the possiblity to add a custom and specific sound for each VWAP, for each Standard Deviations, for each BB or Keltners Channels easily > the possibility to add a Bollinger bands calculated from a higher timeframe placed in a smaller timeframe (like a BB one hour in a 10mn timeframe) > the possibility to see the yield on each specific US tresory bonds inside the chart itself > the possibility to add various information about range: range of the day, the previous day, the x number of previous days average, the higher and lower range of the week, the range between the open and the high/low of the day, previous day, ecc. This would be nices features, useful for a trader. |
[2018-01-25 08:36:27] |
All of this is already supported and we will provide the relevant documentation tomorrow.
[2018-01-25 17:54:48] |
This can be done by using multiple instances of the study and using different alert formulas for each:Chart Studies: Adding/Modifying Chart Studies > the possibility to add a Bollinger bands calculated from a higher timeframe placed in a smaller timeframe (like a BB one hour in a 10mn timeframe)
Refer to:Study/Price Overlay Study > the possibility to see the yield on each specific US tresory bonds inside the chart itself
For the yield symbols, refer to:https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices#INDEX-CBOE > the possibility to add various information about range: range of the day, the previous day, the x number of previous days average, the higher and lower range of the week, the range between the open and the high/low of the day, previous day, ecc. This is all fully supported. Use the following studies:Daily OHLC Average Daily Range Previous/Period OHLC-Variable Period Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-25 17:55:23
