Date/Time: Wed, 01 May 2024 22:49:10 +0000
Show exact trend line values ?
View Count: 1363
[2017-12-03 20:34:53] |
User179195 - Posts: 6 |
hi thaNKS for your prior answer on how to show y-values for trendlines using the "chart values for tools" ...the part i cant work out is how to get an exact value for where a trendline will come in? i know i can hover over the approximate area, but i need to know to the exact tick...if its 2610, then next day is 2620...obviously it comes in at 2630 on the 3rd day, but other charting packages (CQG / Bloomberg) will give you an exact calculation for that specific tendline...rather than just approximating over the area and getting a result....which is quite helpful for longer and more complex trendlines....any solve here? thanks v much. consdinering the full purchase. this would get me to sign up for sure.cheers. Kerrin. |
[2017-12-04 10:38:59] |
Are you using the Ray drawing tool?: Chart Drawing Tools: Line, Ray, Extended Line Those drawings will extend to the right and you can add space to the right side of the chart to see exactly where they are at each chart bar: Working With Charts: Right Side Fill Space There is not way to see the Ray drawing value at each chart bar other than using the Chart Values tool to hover at the approximate level. But visually it is visible. And by the use of a chart grid, you can see where it is at each chart bar: Chart Menu: Horizontal Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-04 10:39:35
