Date/Time: Mon, 06 May 2024 08:53:18 +0000
demo
View Count: 2140
[2017-07-21 01:08:45] |
User186649 - Posts: 9 |
can't get connected for demo just downloaded. what's the setup?
[2017-07-21 03:51:39] |
What Data or Trading service are you using or do you wish to use? See this page for the list: https://www.sierrachart.com/index.php?page=doc/Data.php Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-21 05:23:25] |
Daily chart is ok. However, intraday chart like 5 min or 15 mins chart can't be shown. Looks like download ok, is there a port IP to be reset for this? NQU17 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: \NQU17.scid | 2017-07-21 01:21:56 Current broker is RCGDirect, looks like no SC by them. Can you get SC over there? |
[2017-07-21 06:33:54] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-21 14:50:43] |
Looks like intraday 5 min data downloaded ok, but no shown on screen. what else set up to show 5-min chart? Mesg. log below: HD Request # 4 | Intraday download COMPLETE for NQU17. Completion time: 20s. Unique request ID: 1 | 2017-07-21 10:47:57 Removed historical data download ID 1 | 2017-07-21 10:47:57 Real-time Intraday chart data file updates started for NQU17 | 2017-07-21 10:47:57 Opened cached Intraday file: \Data\NQU17.scid | 2017-07-21 10:47:57 Intraday chart data file opened for NQU17 | 2017-07-21 10:47:57 |
[2017-07-21 15:41:08] |
This Message Log is incomplete. It is not of any use to us. Here are the instructions again: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Refer to this page for further help: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-26 04:30:43] |
Figured it out. How to split one screen for 2 charts? Also, is there real time update on acct balance and orders filled by Sierra/Rithmic? |
[2017-07-27 02:43:20] |
Use the commands on the Window menu to arrange charts which are currently open: Window and CW Menus Also, is there real time update on acct balance and orders filled by Sierra/Rithmic? Certainly order fills are reported immediately as they occur from the Rithmic system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-03 17:40:48
[2017-08-01 04:11:20] |
Have two charts open, select 'Tile Window--vertically', still one chart for the screen? How to get two charts shown on split screen? How to get 2 mins. chart instead of fixed 1m, 5m, etc.? As for real time acct balance by Sierra, why it has to go w/ Rithmic? Rithmic is just a data feed? |
[2017-08-01 05:00:24] |
You need to open another chart. Refer to: Getting Started, Opening Charts and Basic Trading: Open Chart We can tell you that you have not even read over the Getting Started instructions. That is what you need to start with. You can also detach charts and that is documented here: Detaching and Attaching Chart Windows Refer to: Working With Charts: Changing the Chart Bars Timeframe As for real time acct balance by Sierra, why it has to go w/ Rithmic? Rithmic is just a data feed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-03 05:49:38] |
Can detach the charts. However, how to split one window to get 5 min and 1 hr charts in the same window? How to shift chart time axis from current time to one day ago by mouse? Price axis can be shifted by moving the cursor. Have been using Sierra chart for a few weeks. The setup is not intuitive, like grids, zooming, etc. They are scattering around too many sub-menus, difficult to find. You don't want users to remember +100 functions during busy trading moment. It should be by simply moving cursor or a few sub-menus like TS or TOS. One more time, is there real time acct balance and orders filled update by Sierra/Rithmic? |
[2017-08-03 17:42:35] |
how to split one window to get 5 min and 1 hr charts in the same window? As we said, you just open another chart. And then you can arrange the windows like an ordinary window which you should know how to do. Or you can use the Overlay (Bar) study:Overlay - Bar How to shift chart time axis from current time to one day ago by mouse? Do you not see a scrollbar at the bottom of the chart? Surely you must know how to use the scrollbar? The setup is not intuitive, like grids, zooming, etc. They are scattering around too many sub-menus, difficult to find. You don't want users to remember +100 functions during busy trading moment. This is totally untrue. We do not know how you come to this conclusion. You really need to read the documentation before making further statements like this.The horizontal and vertical grids are accessible from the Chart menu. Refer to: Chart Menu: Horizontal Grid (Chart menu) And "zooming" is fully interactive on the chart itself by using mouse/pointer interaction: Working With Charts: Changing Bar Spacing (we recommend using the dragging timescale method to change bar spacing) Working With Charts: Interactive Scaling: Compress/Expand Vertical Scale, Move Chart Up and Down One more time, is there real time acct balance and orders filled update by Sierra/Rithmic? In regards to the Account Balance, this we are not sure of. However, whatever Account Balance data is sent by Rithmic, Sierra Chart will process it and display it immediately as it is received. You really need to ask Rithmic this question.
Certainly order fills are reported immediately as they occur from the Rithmic system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-03 17:45:49
[2017-08-04 05:13:11] |
Ok overlay bars can be used to place 2 charts in one window, but it's like horizontal split. What I'm looking for is vertical split of two charts at different time frames in one window. What's the setup for this? Don't be defensive on my comments about your chart is not intuitive. You do have good features. However, compared to TS, almost everything is by graphics itself, user shouldn't rely on manual docs. No time for this in real time trading. Your vertical and horz. grids are in separate menus to set up, also too many menus and sub-menus, etc. My feedbacks is for you to improve to be more user friendly. Hope you take this positively. |
[2017-08-04 17:29:39] |
My feedbacks is for you to improve to be more user friendly. Hope you take this positively. The grids are already organized very appropriately. The menu commands enable and disable them and there are both keyboard shortcuts and control bar buttons for those as well.In Chart >> Chart Settings is where you can configure them with more detail. The Sierra Chart design overall is very very good compared to a lot of the junk software designs out there. We already have a large user base who relies upon Sierra Chart designed the way it is. You are already used something that works a certain way. So it does take time to get used to something new. It is not something we would change. There may be small incremental changes as necessary and needed but you should never expect any major change. We would not do that. What I'm looking for is vertical split of two charts at different time frames in one window. What's the setup for this? You can place two charts side by side. Let us know if you need help with that. You cannot do what you want within a single chart window though.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-04 17:31:33
[2017-08-14 04:30:17] |
What script is used to generate automated limit buy or limit sell orders for specified conditions? Any example template? can it be used in replay simulation for test?
Date Time Of Last Edit: 2017-08-14 04:31:10
[2017-08-14 22:34:58] |
Yes, this is all supported. There are two ways this can be done. Through Spreadsheets or using the Advanced Custom Study Interface and Language. This is explained in more detail here: Automated Trading Management We have also reactivated the trial on your account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-14 22:36:00
