Date/Time: Sun, 19 May 2024 06:24:21 +0000
Problem about "Symbol is unknown" at sierra chart
View Count: 1219
[2016-12-09 14:07:54] |
User475690 - Posts: 34 |
Hi ,I just updated the newest version for my sierra chart, but then I loaded my chart book each of it shows that symbol is unknown,but chart is still real-time update and before I updated everything is alright And I reinstalled sierra chart , but this problem still not resolve ,how to fix it? And when I selected "Trading Chart DOM on" it will pop up again |
[2016-12-09 17:44:42] |
And when I selected "Trading Chart DOM on" it will pop up again Provide a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-09 18:26:13] |
Reading Internal Order ID file. | 2016-12-09 13:23:40 Reading Trade Orders file. | 2016-12-09 13:23:40 Reading Trade Positions file. | 2016-12-09 13:23:40 Software version: 1495 | 2016-12-09 13:23:40 Uses New Spreadsheets | 2016-12-09 13:23:40 Enabled for: Advanced Features. | 2016-12-09 13:23:40 Enabled for: Sierra Chart Historical Data Service. | 2016-12-09 13:23:40 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-09 13:23:40 Current selected Data/Trading service: CQG FIX Trading | 2016-12-09 13:23:40 Chart Update Interval: 500 | 2016-12-09 13:23:40 Data/Trade Service Settings automatically set. | 2016-12-09 13:23:40 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-12-09 13:23:40 2016-12-10 02:23:44 Local computer time | 2016-12-09 13:23:40 2016-12-09 18:23:44 Local computer time in UTC | 2016-12-09 13:23:40 2016-12-09 13:23:44 Local computer time in SC Time Zone | 2016-12-09 13:23:40 2016-12-09 18:23:43 Server time in UTC | 2016-12-09 13:23:40 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-12-09 13:23:40 Program path: C:\SierraChart\ | 2016-12-09 13:23:40 Data Files path: C:\SierraChart\Data\ | 2016-12-09 13:23:40 OS Version Number: 6.2 | 2016-12-09 13:23:40 Locale Setting: C | 2016-12-09 13:23:40 Checking for new symbol settings for cqg | 2016-12-09 13:23:40 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-09 13:23:40 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-09 13:23:40 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-09 13:23:40 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-09 13:23:45 Symbol settings are up-to-date for cqg | 2016-12-09 13:23:46 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-09 13:23:51 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-09 13:23:51 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-09 13:23:51 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-09 13:23:51 Checking for new symbol settings for rim | 2016-12-09 13:23:53 Current selected Data/Trading service: Rithmic Trading | 2016-12-09 13:23:53 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-09 13:23:53 HTTPS connection to www.sierrachart.com:443 (4) | Connected. | 2016-12-09 13:23:53 HTTPS connection to www.sierrachart.com:443 (4) | Starting TLS 1.2 connection. | 2016-12-09 13:23:53 Rithmic Trading | Port for executable: 53269 | 2016-12-09 13:23:54 Listening socket (1076), port 53269 | Closed. | 2016-12-09 13:23:54 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-12-09 13:23:54 HTTPS connection to www.sierrachart.com:443 (4) | SSL connection established. | 2016-12-09 13:23:54 Requesting symbol settings for rim. Overwrite = on. | 2016-12-09 13:23:55 Symbol settings received. | 2016-12-09 13:23:56 Processed 780 symbol settings. | 2016-12-09 13:23:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 53269 | 2016-12-09 13:23:56 Socket (5) | Connected. | 2016-12-09 13:23:56 Rithmic Trading | Connected to server. | 2016-12-09 13:23:56 Rithmic Trading | Sending Encoding Request to server | 2016-12-09 13:23:56 Rithmic Trading | Setting DTC encoding to Binary VLS | 2016-12-09 13:23:56 Rithmic Trading | Sending logon request message. | 2016-12-09 13:23:56 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-12-09 13:23:56 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-12-09 13:23:56 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-12-09 13:23:56 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-12-09 13:23:58 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-12-09 13:23:58 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-12-09 13:23:59 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-12-09 13:24:00 HTTPS connection to www.sierrachart.com:443 (4) | SSL connection closed by remote side. | 2016-12-09 13:24:00 HTTPS connection to www.sierrachart.com:443 (4) | Connection gracefully closed by remote side. | 2016-12-09 13:24:00 HTTPS connection to www.sierrachart.com:443 (4) | SSL object has been freed. SSL state is now disconnected. | 2016-12-09 13:24:00 HTTPS connection to www.sierrachart.com:443 (4) | Shutdown and closed. | 2016-12-09 13:24:00 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-12-09 13:24:01 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-12-09 13:24:01 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-12-09 13:24:02 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-12-09 13:24:02 Rithmic Trading | Received logon response. | 2016-12-09 13:24:03 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-12-09 13:24:03 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-12-09 13:24:03 Rithmic Trading | Successfully connected. IB='AMP'. | 2016-12-09 13:24:03 Rithmic Trading | Trading is supported. | 2016-12-09 13:24:03 Rithmic Trading | Order cancel and replace is supported. | 2016-12-09 13:24:03 Rithmic Trading | OCO Orders supported. | 2016-12-09 13:24:03 Rithmic Trading | Connected to data and trading server. | 2016-12-09 13:24:03 ESH7-CME 5 Min #1 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME 60 Min #2 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME 15 Min #3 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME Daily #4 | Reloading chart. | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: YMH7-CBOT. ID: 1 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: YMH7-CBOT. ID: 1 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: NQH7-CME. ID: 2 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: NQH7-CME. ID: 2 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: ESH7-CME. ID: 3 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: ESH7-CME. ID: 3 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: CLF7-NYMEX. ID: 4 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: CLF7-NYMEX. ID: 4 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: GCG7-COMEX. ID: 5 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: GCG7-COMEX. ID: 5 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: 6EZ6-CME. ID: 6 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: 6EZ6-CME. ID: 6 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: 6JZ6-CME. ID: 7 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: 6JZ6-CME. ID: 7 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: ZNH7-CBOT. ID: 8 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: ZNH7-CBOT. ID: 8 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: ZBH7-CBOT. ID: 9 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: ZBH7-CBOT. ID: 9 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: SIH7-COMEX. ID: 10 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: SIH7-COMEX. ID: 10 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: 6AZ6-CME. ID: 11 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: 6AZ6-CME. ID: 11 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: ZSF7-CBOT. ID: 12 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: ZSF7-CBOT. ID: 12 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: FDAX1216-EUREX. ID: 13 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: FDAX1216-EUREX. ID: 13 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: FGBL0317-EUREX. ID: 14 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: FGBL0317-EUREX. ID: 14 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: HGH7-COMEX. ID: 15 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: HGH7-COMEX. ID: 15 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: NGF7-NYMEX. ID: 16 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: NGF7-NYMEX. ID: 16 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: ZCH7-CBOT. ID: 17 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: ZCH7-CBOT. ID: 17 | 2016-12-09 13:24:11 Rithmic Trading | Starting real-time market data updates for: ZWH7-CBOT. ID: 18 | 2016-12-09 13:24:11 Rithmic Trading | Requesting security definition data for: ZWH7-CBOT. ID: 18 | 2016-12-09 13:24:11 CLF7-NYMEX Weekly #1 | Reloading chart. | 2016-12-09 13:24:11 CLF7-NYMEX Daily #2 | Reloading chart. | 2016-12-09 13:24:11 CLF7-NYMEX 60 Min #3 | Reloading chart. | 2016-12-09 13:24:11 CLF7-NYMEX 15 Min #4 | Reloading chart. | 2016-12-09 13:24:11 CLF7-NYMEX 5 Min #5 | Reloading chart. | 2016-12-09 13:24:11 CLF7-NYMEX 1 Min #6 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME 5 Min #1 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME Daily #2 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME 60 Min #3 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME 15 Min #4 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME Weekly #6 | Reloading chart. | 2016-12-09 13:24:11 ESH7-CME 1 Min #7 | Reloading chart. | 2016-12-09 13:24:11 GCG7-COMEX Weekly #1 | Reloading chart. | 2016-12-09 13:24:11 GCG7-COMEX Daily #2 | Reloading chart. | 2016-12-09 13:24:11 GCG7-COMEX 60 Min #3 | Reloading chart. | 2016-12-09 13:24:11 GCG7-COMEX 15 Min #4 | Reloading chart. | 2016-12-09 13:24:11 GCG7-COMEX 5 Min #5 | Reloading chart. | 2016-12-09 13:24:11 GCG7-COMEX 1 Min #6 | Reloading chart. | 2016-12-09 13:24:11 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: FDAX1216-EUREX | 2016-12-09 13:24:11 Symbol Error - FDAX1216-EUREX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:11 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: FGBL0317-EUREX | 2016-12-09 13:24:11 Symbol Error - FGBL0317-EUREX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:11 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESH7-CME | 2016-12-09 13:24:15 Intraday data recording state for symbol ESH7-CME is set to download 'Pending'. | 2016-12-09 13:24:15 Delaying start of download for ESH7-CME | 2016-12-09 13:24:15 HD Request # 2 | Downloading Historical Daily chart data for ESH7-CME. Starting date: 2016-12-08. Service: rim | 2016-12-09 13:24:15 HD Request # 2 | Requesting historical Daily data for ESH17 starting at 2016-12-07 | 2016-12-09 13:24:15 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-09 13:24:15 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLF7-NYMEX | 2016-12-09 13:24:15 Intraday data recording state for symbol CLF7-NYMEX is set to download 'Pending'. | 2016-12-09 13:24:15 HD Request # 3 | Downloading Intraday chart data for ESH7-CME to the file ESH7-CME.scid. Service: cme | 2016-12-09 13:24:15 HD Request # 3 | Download start date-time: 2016-12-09 13:23:26.000 | 2016-12-09 13:24:15 HD Request # 3 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 13:24:15 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 13:24:15 Requesting market depth updates for: CLF7-NYMEX if supported. | 2016-12-09 13:24:15 Requesting market depth updates for: ESH7-CME if supported. | 2016-12-09 13:24:15 Requesting market depth updates for: GCG7-COMEX if supported. | 2016-12-09 13:24:15 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCG7-COMEX | 2016-12-09 13:24:15 Intraday data recording state for symbol GCG7-COMEX is set to download 'Pending'. | 2016-12-09 13:24:15 HTTP connection to ds01.ddfplus.com:80 (6) | Connected. | 2016-12-09 13:24:15 Socket (7) | Connected. | 2016-12-09 13:24:15 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: CLF7-NYMEX | 2016-12-09 13:24:15 Symbol Error - CLF7-NYMEX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:15 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH7-CME | 2016-12-09 13:24:15 Symbol Error - ESH7-CME is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:15 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: GCG7-COMEX | 2016-12-09 13:24:15 Symbol Error - GCG7-COMEX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:15 HD Request # 3 | Setting DTC encoding to Binary VLS | 2016-12-09 13:24:15 HD Request # 3 | Sending historical data logon request message. | 2016-12-09 13:24:15 HD Request # 2 | Receiving historical Daily data for ESH7-CME starting at 2016-12-08 | 2016-12-09 13:24:15 HD Request # 2 | Writing historical Daily data to the file ESH7-CME.dly | 2016-12-09 13:24:15 HD Request # 2 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for ESH7-CME | 2016-12-09 13:24:15 HD Request # 2 | Daily download COMPLETE for ESH7-CME. Completion time: 1s. Unique request ID: 2 | 2016-12-09 13:24:15 Removed historical data download ID 2 | 2016-12-09 13:24:15 HD Request # 4 | Downloading Historical Daily chart data for CLF7-NYMEX. Starting date: 2016-12-08. Service: rim | 2016-12-09 13:24:15 HD Request # 4 | Requesting historical Daily data for CLF17 starting at 2016-12-07 | 2016-12-09 13:24:15 ESH7-CME Daily #2 | Reloading chart. | 2016-12-09 13:24:15 HD Request # 3 | Requesting Intraday data. Start date-time: 2016-12-09 13:23:26. Record interval: 1. Symbol: ESH17 | 2016-12-09 13:24:15 ESH7-CME Weekly #6 | Reloading chart. | 2016-12-09 13:24:15 HD Request # 3 | Decompressing data. | 2016-12-09 13:24:16 Socket (7) | Shutdown and closed. | 2016-12-09 13:24:16 The network socket for historical data has been closed. | 2016-12-09 13:24:16 HD Request # 3 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH7-CME | 2016-12-09 13:24:16 HD Request # 3 | Intraday download COMPLETE for ESH7-CME. Completion time: 1s. Unique request ID: 1 | 2016-12-09 13:24:16 Removed historical data download ID 1 | 2016-12-09 13:24:16 Real-time Intraday chart data file updates started for ESH7-CME | 2016-12-09 13:24:16 Intraday chart data file opened for ESH7-CME | 2016-12-09 13:24:16 Rithmic Trading | Using primary service for historical data for ESH7-CME | 2016-12-09 13:24:16 Intraday data recording state for symbol ESH7-CME is set to download 'Pending'. | 2016-12-09 13:24:16 HD Request # 5 | Downloading Intraday chart data for ESH7-CME to the file ESH7-CME.scid. Service: rim | 2016-12-09 13:24:16 HD Request # 5 | Download start date-time: 2016-12-09 13:23:26.000 | 2016-12-09 13:24:16 HD Request # 5 | Sending historical data request. Start date-time: 2016-12-09 13:23:26. Record interval: 0. Symbol: ESH7-CME | 2016-12-09 13:24:16 HD Request # 6 | Downloading Intraday chart data for CLF7-NYMEX to the file CLF7-NYMEX.scid. Service: nymex | 2016-12-09 13:24:16 HD Request # 6 | Download start date-time: 2016-12-09 13:23:23.000 | 2016-12-09 13:24:16 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-09 13:24:16 HD Request # 6 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 13:24:16 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 13:24:16 HD Request # 4 | Receiving historical Daily data for CLF7-NYMEX starting at 2016-12-08 | 2016-12-09 13:24:16 HD Request # 4 | Writing historical Daily data to the file CLF7-NYMEX.dly | 2016-12-09 13:24:16 HD Request # 4 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for CLF7-NYMEX | 2016-12-09 13:24:16 HD Request # 4 | Daily download COMPLETE for CLF7-NYMEX. Completion time: 0s. Unique request ID: 3 | 2016-12-09 13:24:16 Removed historical data download ID 3 | 2016-12-09 13:24:16 HD Request # 7 | Downloading Historical Daily chart data for GCG7-COMEX. Starting date: 2016-12-08. Service: rim | 2016-12-09 13:24:16 HD Request # 7 | Requesting historical Daily data for GCG17 starting at 2016-12-07 | 2016-12-09 13:24:16 ESH7-CME Daily #4 | Reloading chart. | 2016-12-09 13:24:16 Socket (8) | Connected. | 2016-12-09 13:24:16 HD Request # 6 | Setting DTC encoding to Binary VLS | 2016-12-09 13:24:16 HD Request # 6 | Sending historical data logon request message. | 2016-12-09 13:24:16 CLF7-NYMEX Weekly #1 | Reloading chart. | 2016-12-09 13:24:16 CLF7-NYMEX Daily #2 | Reloading chart. | 2016-12-09 13:24:16 HD Request # 7 | Receiving historical Daily data for GCG7-COMEX starting at 2016-12-08 | 2016-12-09 13:24:16 HD Request # 7 | Writing historical Daily data to the file GCG7-COMEX.dly | 2016-12-09 13:24:16 HD Request # 7 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for GCG7-COMEX | 2016-12-09 13:24:16 HD Request # 7 | Daily download COMPLETE for GCG7-COMEX. Completion time: 1s. Unique request ID: 5 | 2016-12-09 13:24:16 Removed historical data download ID 5 | 2016-12-09 13:24:16 HD Request # 6 | Requesting Intraday data. Start date-time: 2016-12-09 13:23:23. Record interval: 1. Symbol: CLF17 | 2016-12-09 13:24:16 HD Request # 5 | Receiving Intraday data for ESH7-CME starting at 2016-12-09 13:23:26 | 2016-12-09 13:24:16 HD Request # 5 | Timestamp of first Intraday data file record written: 2016-12-09 13:23:29 | 2016-12-09 13:24:16 HD Request # 5 | Received 303 records from 2016-12-09 13:23:26 to 2016-12-09 13:24:06 (40.0 seconds) and wrote 267 records for ESH7-CME | 2016-12-09 13:24:16 HD Request # 5 | Intraday download COMPLETE for ESH7-CME. Completion time: 1s. Unique request ID: 7 | 2016-12-09 13:24:16 Removed historical data download ID 7 | 2016-12-09 13:24:16 Real-time Intraday chart data file updates started for ESH7-CME | 2016-12-09 13:24:16 Intraday chart data file opened for ESH7-CME | 2016-12-09 13:24:16 GCG7-COMEX Daily #2 | Reloading chart. | 2016-12-09 13:24:16 HD Request # 6 | Decompressing data. | 2016-12-09 13:24:16 Socket (8) | Shutdown and closed. | 2016-12-09 13:24:16 The network socket for historical data has been closed. | 2016-12-09 13:24:16 HD Request # 6 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLF7-NYMEX | 2016-12-09 13:24:16 HD Request # 6 | Intraday download COMPLETE for CLF7-NYMEX. Completion time: 1s. Unique request ID: 4 | 2016-12-09 13:24:16 Removed historical data download ID 4 | 2016-12-09 13:24:16 Real-time Intraday chart data file updates started for CLF7-NYMEX | 2016-12-09 13:24:16 Intraday chart data file opened for CLF7-NYMEX | 2016-12-09 13:24:16 Rithmic Trading | Using primary service for historical data for CLF7-NYMEX | 2016-12-09 13:24:16 Intraday data recording state for symbol CLF7-NYMEX is set to download 'Pending'. | 2016-12-09 13:24:16 HD Request # 8 | Downloading Intraday chart data for CLF7-NYMEX to the file CLF7-NYMEX.scid. Service: rim | 2016-12-09 13:24:16 HD Request # 8 | Download start date-time: 2016-12-09 13:23:23.000 | 2016-12-09 13:24:16 HD Request # 8 | Sending historical data request. Start date-time: 2016-12-09 13:23:23. Record interval: 0. Symbol: CLF7-NYMEX | 2016-12-09 13:24:16 HD Request # 9 | Downloading Intraday chart data for GCG7-COMEX to the file GCG7-COMEX.scid. Service: comex | 2016-12-09 13:24:16 HD Request # 9 | Download start date-time: 2016-12-09 13:23:14.000 | 2016-12-09 13:24:16 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-09 13:24:16 HD Request # 9 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 13:24:16 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 13:24:16 GCG7-COMEX Weekly #1 | Reloading chart. | 2016-12-09 13:24:17 Socket (9) | Connected. | 2016-12-09 13:24:17 HD Request # 9 | Setting DTC encoding to Binary VLS | 2016-12-09 13:24:17 HD Request # 9 | Sending historical data logon request message. | 2016-12-09 13:24:17 HD Request # 8 | Receiving Intraday data for CLF7-NYMEX starting at 2016-12-09 13:23:23 | 2016-12-09 13:24:17 HD Request # 8 | Timestamp of first Intraday data file record written: 2016-12-09 13:23:29 | 2016-12-09 13:24:17 HD Request # 8 | Received 39 records from 2016-12-09 13:23:23 to 2016-12-09 13:24:10 (47.0 seconds) and wrote 36 records for CLF7-NYMEX | 2016-12-09 13:24:17 HD Request # 8 | Intraday download COMPLETE for CLF7-NYMEX. Completion time: 0s. Unique request ID: 8 | 2016-12-09 13:24:17 Removed historical data download ID 8 | 2016-12-09 13:24:17 Real-time Intraday chart data file updates started for CLF7-NYMEX | 2016-12-09 13:24:17 Intraday chart data file opened for CLF7-NYMEX | 2016-12-09 13:24:17 HD Request # 9 | Requesting Intraday data. Start date-time: 2016-12-09 13:23:14. Record interval: 1. Symbol: GCG17 | 2016-12-09 13:24:17 HD Request # 9 | Decompressing data. | 2016-12-09 13:24:17 Socket (9) | Shutdown and closed. | 2016-12-09 13:24:17 The network socket for historical data has been closed. | 2016-12-09 13:24:17 HD Request # 9 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCG7-COMEX | 2016-12-09 13:24:17 HD Request # 9 | Intraday download COMPLETE for GCG7-COMEX. Completion time: 0s. Unique request ID: 6 | 2016-12-09 13:24:17 Removed historical data download ID 6 | 2016-12-09 13:24:17 Real-time Intraday chart data file updates started for GCG7-COMEX | 2016-12-09 13:24:17 Intraday chart data file opened for GCG7-COMEX | 2016-12-09 13:24:17 Rithmic Trading | Using primary service for historical data for GCG7-COMEX | 2016-12-09 13:24:17 Intraday data recording state for symbol GCG7-COMEX is set to download 'Pending'. | 2016-12-09 13:24:17 HD Request # 10 | Downloading Intraday chart data for GCG7-COMEX to the file GCG7-COMEX.scid. Service: rim | 2016-12-09 13:24:17 HD Request # 10 | Download start date-time: 2016-12-09 13:23:14.000 | 2016-12-09 13:24:17 HD Request # 10 | Sending historical data request. Start date-time: 2016-12-09 13:23:14. Record interval: 0. Symbol: GCG7-COMEX | 2016-12-09 13:24:17 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-09 13:24:17 HD Request # 10 | Receiving Intraday data for GCG7-COMEX starting at 2016-12-09 13:23:14 | 2016-12-09 13:24:18 HD Request # 10 | Timestamp of first Intraday data file record written: 2016-12-09 13:23:35 | 2016-12-09 13:24:18 HD Request # 10 | Received 46 records from 2016-12-09 13:23:14 to 2016-12-09 13:24:15 (61.0 seconds) and wrote 37 records for GCG7-COMEX | 2016-12-09 13:24:18 HD Request # 10 | Intraday download COMPLETE for GCG7-COMEX. Completion time: 0s. Unique request ID: 9 | 2016-12-09 13:24:18 Removed historical data download ID 9 | 2016-12-09 13:24:18 Real-time Intraday chart data file updates started for GCG7-COMEX | 2016-12-09 13:24:18 Intraday chart data file opened for GCG7-COMEX | 2016-12-09 13:24:18 Opened cached Intraday file: C:\SierraChart\Data\ESH7-CME.scid | 2016-12-09 13:24:24 Opened cached Intraday file: C:\SierraChart\Data\CLF7-NYMEX.scid | 2016-12-09 13:24:24 Opened cached Intraday file: C:\SierraChart\Data\GCG7-COMEX.scid | 2016-12-09 13:24:34 CLF7-NYMEX #7 | Reloading chart. | 2016-12-09 13:25:00 HTTP connection to ds01.ddfplus.com:80 (6) | Closed. No error. | 2016-12-09 13:25:21 HTTP connection to ds01.ddfplus.com:80 (6) | Shutdown and closed. | 2016-12-09 13:25:21 |
[2016-12-09 18:29:56] |
pop upon like attached pic ,by the way trading DOM didn't showed bid/ask(I order top of book data)
Private File Private File |
[2016-12-09 18:38:56] |
Here are the relevant messages: Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: FDAX1216-EUREX | 2016-12-09 13:24:11
It looks as though your Rithmic account is not authorized for the EUREX. Contact your broker about this.Symbol Error - FDAX1216-EUREX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:11 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: FGBL0317-EUREX | 2016-12-09 13:24:11 Symbol Error - FGBL0317-EUREX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:11 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: CLF7-NYMEX | 2016-12-09 13:24:15 Symbol Error - CLF7-NYMEX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:15 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH7-CME | 2016-12-09 13:24:15 Symbol Error - ESH7-CME is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:15 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: GCG7-COMEX | 2016-12-09 13:24:15 Symbol Error - GCG7-COMEX is unknown, unavailable, or improperly formatted. | 2016-12-09 13:24:15 These messages indicate that your Rithmic account is not authorized for market depth data for these particular futures markets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-09 18:39:46
[2016-12-09 18:43:01] |
Make sure the Bid and Ask Size columns are added to the Trade DOM:http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-09 18:53:43] |
You still may have a problem seeing the best bid and ask on the Trade DOM and we are working on adding support for that now when using Rithmic and not subscribed to market depth data.
[2016-12-09 19:19:05] |
YES I didn't order EUREX ,and my sybol list has FDAX1216 and FGBL0317-EUREX I deleted them ,and reopen sierra chart still showed "symbol is unknown" And please look clearly at attached pic ,my chart column has bid/ask info but Trade DOM don't have bid/ask info!!! |
Private File |
[2016-12-09 19:24:06] |
By the way, I had enabled "Reject Stop Orders That Will Immediately Fill" and "Auto-Send Market Order On Rejected Stop Attached Order" , why my stop order still rejected?
Private File |
[2016-12-09 19:40:40] |
This can still happen because Sierra Chart has a 2 tick tolerance before rejecting the order internally. Meaning it can still be at a price level which will cause it to fill and then could be rejected externally. chart column has bid/ask info but Trade DOM don't have bid/ask info!!!
Make sure the Bid and Ask Size columns are added to the Trade DOM:http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns I deleted them ,and reopen sierra chart still showed "symbol is unknown" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-09 19:41:18
[2016-12-09 19:56:25] |
Ok Thank you
