Date/Time: Tue, 14 May 2024 00:03:54 +0000
Help for Sierra software
View Count: 667
[2016-11-28 11:49:15] |
KAYZER - Posts: 6 |
Hello, I used the demo of your software linked to a demo LMAX account and I worked on the software to fit my requirements and it's not too hard => thank you for that. Nevertheless, I have some questions that I can not solve by myself despite I dug the forum. Question 1:DRAW I created a symbol watchlist and linked 3 charts for time Frame. but when I draw some lines in the bigger time frame, I understood how to see those in the lower but my is problem is that when I draw a line on EURUSD symbol and I decide to change the symbol using watchlist then I see the line on the other symbol and it's a big problem because a drawing on EURUSD is different of USDJPY for example. Could you help me? Question 2 :TAL reports I tried to use TAL but I have data to use in trade activity and trade stats for charts (when charts open) I don't have data for trade statistics / trades / period trade stats even if I tried to change the date and "apply" see pictures. Could you help me? Question 3: chart tick size If I compare the SC chart in tick size ( 25t for example), I have different results between SC and LMAX software, SC seems to be not accurate for charts using ticks time frame? (see example AUDUSD pic) Question 4: historical data available for historical chart the maximum data I could load for different symbol are short (2013 april for many symbols) except EURUSD( I could manage to get 1993 historical) after I checked the window the " data available in the file" On LMAX software I have data from 1976 (GBP/USD) or 1980 (EURUSD), that's why I don't understand because I thought the data will be the same ?? Could you help me ? (maybe it's just to demo not for real LMAX account?) I am available for questions. Sorry for my English I'm french. Regards, K |
Private File Private File Private File |
[2016-11-28 18:27:53] |
1. You need to uncheck this option in Chart Settings: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ShowChartDrawingsForDifferentSymbol 2. You need to select the particular symbol at the top of the Trade Activity Log. Here are instructions: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradeStatisticsTab 3. If you are using the LMAX demo data feed, then refer to: http://www.sierrachart.com/index.php?page=doc/LMAX.php#DifferencesLMAXLiveDemoDataFeeds The live data feed is different and we would expect it to have a lot more price updates than the LMAX charts do. So you cannot compare the two. This is simply not valid. 4. We will add more historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-28 18:32:02
[2016-11-28 18:33:01] |
The prior post has been updated.
