Date/Time: Sun, 19 May 2024 08:35:34 +0000
dom ?
View Count: 931
[2016-08-25 15:08:02] |
zippyzip - Posts: 293 |
how can i plot OHLC on the dom , all i get is a separate row on numbers
Private File |
[2016-08-25 16:45:43] |
You need to adjust the Chart Region setting to 1 in the Study Settings window for that Daily OHLC study. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#ChartRegion Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-25 16:50:18] |
ok thanks , i got line to plo but is there a way to plot the names , i cant seem to get the name or value to plot
[2016-08-25 16:52:44] |
as u can see the text is covered and cant see it , and its only allowing me to use right plot
[2016-08-25 17:14:07] |
Set the Horizontal Align for the Name Label to "Left". Also the proper way to post an image is documented here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-25 17:14:45
[2016-08-26 00:35:34] |
i try to but it switches it back to right as the only option , wont let me pick any more
[2016-08-26 03:48:40] |
That does not make sense. The Horizontal Align setting will not change after you set it. And we tested this earlier today.
[2016-08-26 11:59:54] |
ok i got it to work but ran into another issue , unless i extend my chart over 2 screens i cant see these levels , there to far to left , can there be a column made for this kind of stuff ?> its very sloppy all over the chart like this , |
Attachment Deleted. Private File Private File |
[2016-08-26 17:05:24] |
It would be best if you use a normal chart with chart bars and use the Chart DOM. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM This way you can have more flexibility and add space on the right side of the chart and adjust the labels into that space. Refer to: Working With Charts: Right Side Fill Space Or you can set the Horizontal Align option to the "Values Scale" to see the labels there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-26 17:10:56] |
i wanted to but how do i scale it bigger , its very hard to read , and how do i make columns bigger
[2016-08-26 17:15:52] |
Refer to this page for the Chart Scale and scaling: Chart Scale and Scale Adjusting Do you want to make the text on the chart larger? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-26 19:12:00] |
first pic is reg dom 2nd pic is dom on the chart , how do i get them to match , i cant get chart dome to match , color , column , scale , its just very confusing why it wont change
[2016-08-29 00:56:17] |
also can it be possible within nxt few updates to make it possible to have the custom DOM different from rest of them , i like to use one for trading on the chart and one for volume , but if i change one they all change ,
[2016-08-29 14:38:11] |
In response to post #12, refer to: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM The Chart DOM Scale Regarding feature requests, refer to: Notice: Suggestions (Currently not accepting) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
