Date/Time: Mon, 12 Oct 2026 06:02:15 +0000
Rollover Troubleshooting
View Count: 336
| [2026-07-09 15:53:58] |
| itslikely2 - Posts: 7 |
I am not able to complete rollover after I allowed two rollover contracts to pass. I have updated the Sierra Charts version and I am still unable to get the rollover to take. The screen just stays white and does nothing after attempting to load. I'm doing the rollover the way I always have. Everything is paid and current on all sides. Please help!
| [2026-07-09 16:11:42] |
| John - SC Support - Posts: 48169 |
How did you perform the rollover? What is the current symbol for the chart (as it shows in "Chart >> Chart Settings >> Symbol >> Symbol)? We want to point out that you are setup to get your data from Rithmic, so if you are having an issue with their data, you will have to ask your broker/Rithmic about this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-09 17:25:24] |
I went to Chart >> Perform Futures Symbol Rollover >> Chose ESU6.CME >> ok The current symbol is ESH6.CME and I want to rollover to ESU6 The data appears to be coming through fine as far as I can see. I've never had this happen, so what would be the reason that a rollover you not go through? Does the fact that I did not rollover for the contract in between change anything? |
| [2026-07-09 18:44:18] |
We are confused. You state that "The data appears to be coming through fine as far as I can see." If the data is working now, then do you still have an issue? If you had a problem earlier and it is resolved now, then we do not know what might have occurred earlier. There should not be any issue with doing the rollover "later". The only thing that matters is the symbol of the chart. If you want to view the data for an older contract, then that is fine - you can do this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-14 13:55:59] |
I have reached out to Rithmic and my data appears to be fine and connected without issue. I still am unable to complete a rollover at this point. Is there a process that you can walk me through or remotely access my computer to get to the bottom of this? I would like to get back to trading as soon as possible. I am still attempting to complete a rollover and I am just getting a white screen that never loads. What should I check or do from here?
| [2026-07-14 16:03:23] |
The main thing a rollover does is change the symbol in the chart to the current front contract. Therefore, whatever issue you are having is not related to the rollover, it is something else. For a chart where you are having an issue, what is the setting for "Chart >> Chart Settings >> Symbol >> Symbol"? Also, please get us your Message Log for that symbol, by following these instructions to open a single chart: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-15 14:52:12] |
I am having the issue loading ESU6.CME from ESH6.CME The symbol I attempted to load was ESU6.CME. The screen loaded black with no price action visible or live market feed. Here is the message log: 2026-07-14 13:49:29.717 | Trade activity files set size: 1158 2026-07-14 13:49:29.725 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 13:49:29.758 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2026-07-14 13:49:29.758 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2026-07-14 13:49:29.758 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130. 2026-07-14 13:49:29.773 | Created the DTC Protocol server. 2026-07-14 13:49:29.774 | DTC Protocol Server listening on port 11099. Address: 0.0.0.0 2026-07-14 13:49:29.774 | Reading Internal Order ID file. 2026-07-14 13:49:29.775 | Reading Trade Orders file. 2026-07-14 13:49:29.775 | Reading Trade Positions file. 2026-07-14 13:49:29.776 | Reading Trade Account Data files. 2026-07-14 13:49:29.778 | Software version: 2922 64-bit 2026-07-14 13:49:29.778 | Primary Thread ID: 2408 2026-07-14 13:49:29.778 | Usage end date: 2026-08-01 2026-07-14 13:49:29.778 | Enabled for: Advanced Features 2. 2026-07-14 13:49:29.778 | Enabled for: Sierra Chart Historical Data Service. 2026-07-14 13:49:29.778 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-07-14 13:49:29.778 | Enabled for: Delayed Denali Exchange Data Feed. 2026-07-14 13:49:29.778 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-07-14 13:49:29.778 | Current selected Data/Trading service: Rithmic Direct - DTC 2026-07-14 13:49:29.778 | Custom symbol settings values: enabled 2026-07-14 13:49:29.778 | Chart Update Interval: 500 2026-07-14 13:49:29.778 | Intraday Data Storage Time Unit: 0 2026-07-14 13:49:29.778 | Time Zone: +00:00:00 (UTC+00) 2026-07-14 13:49:29.778 | 2026-07-14 13:49:29 Local computer time in UTC 2026-07-14 13:49:29.778 | 2026-07-14 13:49:29 Local computer time in SC Time Zone 2026-07-14 13:49:29.778 | 2026-07-14 13:49:29 Server time in UTC 2026-07-14 13:49:29.778 | Local computer UTC time and Server UTC time difference: 0 seconds. 2026-07-14 13:49:29.778 | Program path: C:\SierraChart\ 2026-07-14 13:49:29.778 | Data Files path: C:\SierraChart\Data\ 2026-07-14 13:49:29.778 | OS Version Number: 10.0 2026-07-14 13:49:29.778 | Locale Setting: C 2026-07-14 13:49:29.778 | Crash reporter started: true 2026-07-14 13:49:29.778 | 2026-07-14 13:49:29.796 | Created the DTC Protocol historical data server. 2026-07-14 13:49:29.796 | HD Server Manager | Listening on port 11098. 2026-07-14 13:49:29.796 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2026-07-14 13:49:29.808 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-07-14 13:49:29.817 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-07-14 13:49:29.817 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-07-14 13:49:29.837 | Received 5 login tokens. 2026-07-14 13:49:29.920 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-14 13:49:29.921 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 13:49:29.922 | Symbol settings MD5 received. Request ID: 1. 2026-07-14 13:49:29.922 | Symbol settings are up-to-date for rithmic_v2.trading. 2026-07-14 13:49:30.175 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2026-07-14 13:49:30.175 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. 2026-07-14 13:49:30.193 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2026-07-14 13:49:30.193 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2026-07-14 13:49:32.300 | Requested user files to download. 2026-07-14 13:49:32.422 | There are no user files to download. 2026-07-14 13:49:34.300 | 2026-07-14 13:49:34.300 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-07-14 13:49:34.300 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-07-14 13:49:34.301 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-07-14 13:49:34.351 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-14 13:49:34.351 | DTC Client socket (1) | New receive buffer size: 0 2026-07-14 13:49:34.351 | DTC Client socket (1) | Connecting to IP: 38.65.210.70. 2026-07-14 13:49:34.353 | Rithmic Direct - DTC | Network connection to server complete. 2026-07-14 13:49:34.353 | Rithmic Direct - DTC | Starting socket receive thread. 2026-07-14 13:49:34.353 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-07-14 13:49:34.353 | Rithmic Direct - DTC | Sending logon request message. 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Received logon response. 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Server Name: . 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Successfully connected. 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Trading is supported. 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | OCO Orders supported. 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Connection to server complete. 2026-07-14 13:49:34.375 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-07-14 13:49:34.375 | Using symbol data fast lookup vector 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Starting real-time market data updates for: F.US.EPU26. ID: 1 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Requesting security definition data for: F.US.EPU26. ID: 1 2026-07-14 13:49:34.375 | Rithmic Direct - DTC | Using primary service for historical data for F.US.EPU26 2026-07-14 13:49:34.376 | Starting DelayedDownloadMonitoringTimer 2026-07-14 13:49:34.376 | Starting HDTimeoutTimer 2026-07-14 13:49:34.376 | Historical data service client indicated that downloads are not enabled. Symbol: F.US.EPU26. Data Type: Intraday data. 2026-07-14 13:49:34.376 | Historical data download ID 1 not found when removing ID from outstanding request set. 2026-07-14 13:49:34.376 | Real-time Intraday chart data file updates started for F.US.EPU26 2026-07-14 13:49:34.376 | Intraday chart data file opened for F.US.EPU26 2026-07-14 13:49:37.521 | Files to Open on Startup | File does not exist: C:\SierraChart\Data\ExampleChartbook.cht 2026-07-14 13:49:54.316 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. 2026-07-14 13:49:54.316 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0 2026-07-14 13:49:54.316 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 216.66.0.130. 2026-07-14 13:49:54.445 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-14 13:49:54.446 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 13:49:54.706 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call. 2026-07-14 13:49:54.706 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. 2026-07-14 13:49:54.724 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. 2026-07-14 13:49:54.724 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed. 2026-07-14 13:56:20.801 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-14 13:56:20.803 | Rithmic Direct - DTC | Using primary service for historical data for ESM5.CME 2026-07-14 13:56:20.803 | Historical data service client indicated that downloads are not enabled. Symbol: ESM5.CME. Data Type: Intraday data. 2026-07-14 13:56:20.803 | Historical data download ID 2 not found when removing ID from outstanding request set. 2026-07-14 13:56:20.803 | Real-time Intraday chart data file updates started for ESM5.CME 2026-07-14 13:56:20.803 | Intraday chart data file opened for ESM5.CME 2026-07-14 13:56:20.805 | Rithmic Direct - DTC | Using primary service for historical data for ESU5.CME 2026-07-14 13:56:20.805 | Historical data service client indicated that downloads are not enabled. Symbol: ESU5.CME. Data Type: Intraday data. 2026-07-14 13:56:20.805 | Historical data download ID 3 not found when removing ID from outstanding request set. 2026-07-14 13:56:20.805 | Real-time Intraday chart data file updates started for ESU5.CME 2026-07-14 13:56:20.805 | Intraday chart data file opened for ESU5.CME 2026-07-14 13:56:20.863 | Rithmic Direct - DTC | Using primary service for historical data for ESH6.CME 2026-07-14 13:56:20.863 | Historical data service client indicated that downloads are not enabled. Symbol: ESH6.CME. Data Type: Intraday data. 2026-07-14 13:56:20.863 | Historical data download ID 4 not found when removing ID from outstanding request set. 2026-07-14 13:56:20.863 | Real-time Intraday chart data file updates started for ESH6.CME 2026-07-14 13:56:20.863 | Intraday chart data file opened for ESH6.CME 2026-07-14 13:56:20.865 | ESH6.CME [CBV] #1 | Performing continuous chart historical Daily data download for symbol ESH6.CME starting at last date in file. 2026-07-14 13:56:20.865 | Starting DelayedDownloadMonitoringTimer 2026-07-14 13:56:20.865 | Starting HDTimeoutTimer 2026-07-14 13:56:20.865 | Added historical Daily data request for ESH6.CME to the queue. 2026-07-14 13:56:20.865 | Triggering next historical data download in queue. 2026-07-14 13:56:20.893 | ESH6.CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:20.957 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 13:56:20.963 | ESH6.CME [CBV] 5000 Volume #2 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:21.069 | ESH6.CME #3 | Reloading chart. 2026-07-14 13:56:21.133 | ESH6.CME Renko 4t #5 | Reloading chart. 2026-07-14 13:56:21.222 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-14 13:56:21.263 | ESH6.CME [CBV] #8 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:21.343 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 13:56:21.355 | ESH6.CME [CBV] Renko 4t #9 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:21.641 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 13:56:21.647 | ESH6.CME [CBV] 100 Volume #12 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:21.691 | ESH6.CME 5000 Volume #13 | Reloading chart. 2026-07-14 13:56:21.797 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 13:56:21.870 | ESH6.CME [CBV] 5000 Volume #4 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:21.932 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 13:56:21.939 | ESH6.CME [CBV] Renko 8t #10 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:22.335 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 13:56:22.380 | ESH6.CME [CBV] Renko 2t #6 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:22.428 | ESH6.CME Renko 8t #7 | Reloading chart. 2026-07-14 13:56:22.600 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 13:56:22.606 | ESH6.CME [CBV] Renko 16t #11 | Waiting for historical downloads to complete with the IDs: 5, 2026-07-14 13:56:22.866 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU6.CME. ID: 5 Service code: rithmic.trading 2026-07-14 13:56:22.866 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESU6.CME. 2026-07-14 13:56:22.866 | Rithmic Direct - DTC | Requesting security definition data for: ESU6.CME. ID: 5 2026-07-14 13:56:22.874 | HD Request # 1 | Downloading Historical Daily chart data for ESH6.CME. Starting date: 2026-03-18. Service: rithmic.trading 2026-07-14 13:56:23.092 | HD Request # 1 | Requesting historical Daily data for ESH26 starting at 2026-03-17. SC External HD service. 2026-07-14 13:56:23.218 | Rithmic Direct - DTC | Starting real-time market data updates for: ESH6.CME. ID: 4 Service code: rithmic.trading 2026-07-14 13:56:23.218 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESH6.CME. 2026-07-14 13:56:23.218 | Rithmic Direct - DTC | Requesting security definition data for: ESH6.CME. ID: 4 2026-07-14 13:56:23.258 | HD Request # 1 | Receiving historical Daily data for ESH6.CME starting at 2026-03-18. 2026-07-14 13:56:23.258 | HD Request # 1 | Writing historical Daily data to the file ESH6.CME.dly. 2026-07-14 13:56:23.260 | HD Request # 1 | Bytes received: 225 2026-07-14 13:56:23.260 | HD Request # 1 | Received 4 Daily data records from 2026-03-18 00:00:00 to 2026-03-20 00:00:00 (3.0 days) and wrote 3 records for ESH6.CME 2026-07-14 13:56:23.260 | HD Request # 1 | Completion time: 1s. 2026-07-14 13:56:23.260 | HD Request # 1 | Daily data download complete for ESH6.CME. Unique request ID: 5 2026-07-14 13:56:23.260 | Removing historical data download ID 5. 2026-07-14 13:56:23.260 | 2026-07-14 13:56:23.260 | No download requests in the queue to start downloads for. 2026-07-14 13:56:23.291 | ESH6.CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:23.342 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-14 13:56:23.507 | ESH6.CME [CBV] 5000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:23.537 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 13:56:23.542 | ESH6.CME [CBV] Renko 2t #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:23.542 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 13:56:23.638 | ESH6.CME [CBV] Renko 4t #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:23.704 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 13:56:23.953 | ESH6.CME [CBV] Renko 8t #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:24.227 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 13:56:24.530 | ESH6.CME [CBV] 5000 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:24.995 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 13:56:25.254 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=100 2026-07-14 13:56:25.255 | Separate subscription for market depth updates not supported. ESH6.CME 2026-07-14 13:56:25.258 | ESH6.CME [CBV] Renko 16t #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:25.302 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 13:56:25.303 | ESH6.CME [CBV] 100 Volume #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:25.304 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 13:56:25.305 | ESH6.CME [CBV] #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 13:56:25.305 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-14 13:56:26.195 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-14 13:56:26.711 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 13:56:26.720 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 13:56:26.730 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 13:56:27.251 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 13:56:27.916 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 13:56:28.642 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-14 13:56:29.901 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 13:56:29.959 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 13:56:36.527 | Loading market depth data. 2026-07-14 13:56:44.457 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 13:56:51.880 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 13:56:58.894 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 13:57:02.564 | ESH6.CME 5000 Volume #13 | Chart data loading complete. 2026-07-14 13:57:05.856 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 13:57:10.010 | ESH6.CME [CBV] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:57:11.299 | ESH6.CME [CBV] 5000 Volume #4 | Chart data loading complete. 2026-07-14 13:57:11.950 | ESH6.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:57:11.956 | ESH6.CME #3 | Chart data loading complete. 2026-07-14 13:57:12.268 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 13:57:12.630 | ESH6.CME [CBV] 100 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:57:13.197 | ESH6.CME [CBV] 100 Volume #12 | Chart data loading complete. 2026-07-14 13:57:17.997 | Loading market depth data. 2026-07-14 13:57:18.094 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 13:57:18.622 | ESH6.CME [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-14 13:57:23.490 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-14 13:57:30.014 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-14 13:57:32.396 | Loading market depth data. 2026-07-14 13:57:37.641 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 13:57:39.999 | ESH6.CME Renko 8t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:57:40.256 | ESH6.CME Renko 8t #7 | Chart data loading complete. 2026-07-14 13:57:41.168 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-14 13:57:41.213 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 13:57:41.214 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 13:57:43.016 | ESH6.CME [CBV] #8 | Chart data loading complete. 2026-07-14 13:57:45.345 | Loading market depth data. 2026-07-14 13:57:45.443 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 13:57:46.163 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 13:57:49.324 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-14 13:57:56.306 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 13:57:56.993 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-14 13:58:02.612 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 13:58:02.667 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 13:58:03.057 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 13:58:03.148 | ESH6.CME Renko 4t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:58:03.745 | ESH6.CME Renko 4t #5 | Chart data loading complete. 2026-07-14 13:58:08.358 | ESH6.CME [CBV] #1 | Chart data loading complete. 2026-07-14 13:58:08.725 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-14 13:58:09.686 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 13:58:12.487 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 13:58:17.298 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 13:58:19.664 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 13:58:19.665 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 13:58:22.076 | Loading market depth data. 2026-07-14 13:58:22.291 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 13:58:22.971 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 13:58:25.851 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 13:58:25.853 | ESH6.CME [CBV] Renko 8t #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:58:25.963 | ESH6.CME [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-14 13:58:27.713 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 13:58:30.940 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-14 13:58:33.119 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 13:58:35.410 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 13:58:41.373 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-14 13:58:41.445 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 13:58:46.546 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 13:58:46.714 | ESH6.CME [CBV] Renko 2t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:58:47.251 | ESH6.CME [CBV] Renko 2t #6 | Chart data loading complete. 2026-07-14 13:58:48.935 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 13:58:50.145 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 13:58:50.146 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 13:58:53.553 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 13:58:54.563 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 13:58:54.565 | ESH6.CME [CBV] Renko 16t #11 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:58:54.590 | ESH6.CME [CBV] Renko 16t #11 | Chart data loading complete. 2026-07-14 13:58:55.967 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 13:58:57.292 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 13:58:59.374 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 13:59:01.757 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 13:59:01.791 | ESH6.CME [CBV] Renko 4t #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 13:59:01.985 | ESH6.CME [CBV] Renko 4t #9 | Chart data loading complete. 2026-07-14 14:00:11.018 | ESU6.CME [CBV] #1 | Reloading chart. 2026-07-14 14:00:11.021 | Rithmic Direct - DTC | Using primary service for historical data for ESM6.CME 2026-07-14 14:00:11.021 | Historical data service client indicated that downloads are not enabled. Symbol: ESM6.CME. Data Type: Intraday data. 2026-07-14 14:00:11.021 | Historical data download ID 6 not found when removing ID from outstanding request set. 2026-07-14 14:00:11.021 | Real-time Intraday chart data file updates started for ESM6.CME 2026-07-14 14:00:11.021 | Intraday chart data file opened for ESM6.CME 2026-07-14 14:00:11.022 | Rithmic Direct - DTC | Using primary service for historical data for ESU6.CME 2026-07-14 14:00:11.022 | Historical data service client indicated that downloads are not enabled. Symbol: ESU6.CME. Data Type: Intraday data. 2026-07-14 14:00:11.022 | Historical data download ID 7 not found when removing ID from outstanding request set. 2026-07-14 14:00:11.022 | Real-time Intraday chart data file updates started for ESU6.CME 2026-07-14 14:00:11.022 | Intraday chart data file opened for ESU6.CME 2026-07-14 14:00:11.024 | ESU6.CME [CBV] #1 | Performing continuous chart historical Daily data download for symbol ESU6.CME starting at last date in file. 2026-07-14 14:00:11.024 | Added historical Daily data request for ESU6.CME to the queue. 2026-07-14 14:00:11.024 | Triggering next historical data download in queue. 2026-07-14 14:00:11.054 | ESU6.CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.057 | ESU6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:00:11.066 | ESU6.CME [CBV] 5000 Volume #2 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.068 | ESU6.CME #3 | Reloading chart. 2026-07-14 14:00:11.073 | ESU6.CME Renko 4t #5 | Reloading chart. 2026-07-14 14:00:11.077 | ESU6.CME [CBV] #8 | Reloading chart. 2026-07-14 14:00:11.121 | ESU6.CME [CBV] #8 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.143 | ESU6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 14:00:11.153 | ESU6.CME [CBV] Renko 4t #9 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.242 | ESU6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 14:00:11.245 | ESU6.CME [CBV] 100 Volume #12 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.246 | ESU6.CME 5000 Volume #13 | Reloading chart. 2026-07-14 14:00:11.249 | ESU6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 14:00:11.258 | ESU6.CME [CBV] 5000 Volume #4 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.264 | ESU6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:00:11.273 | ESU6.CME [CBV] Renko 8t #10 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.361 | ESU6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 14:00:11.370 | ESU6.CME [CBV] Renko 2t #6 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.374 | ESU6.CME Renko 8t #7 | Reloading chart. 2026-07-14 14:00:11.404 | ESU6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 14:00:11.413 | ESU6.CME [CBV] Renko 16t #11 | Waiting for historical downloads to complete with the IDs: 8, 2026-07-14 14:00:11.433 | HD Request # 2 | Downloading Historical Daily chart data for ESU6.CME. Starting date: 2026-07-07. Service: rithmic.trading 2026-07-14 14:00:11.437 | ESU6.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:00:11.442 | ESU6.CME #3 | Chart data loading complete. 2026-07-14 14:00:11.443 | ESU6.CME Renko 4t #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:11.448 | ESU6.CME Renko 4t #5 | Chart data loading complete. 2026-07-14 14:00:11.463 | ESU6.CME 5000 Volume #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:11.467 | ESU6.CME 5000 Volume #13 | Chart data loading complete. 2026-07-14 14:00:11.473 | ESU6.CME Renko 8t #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:11.474 | ESU6.CME Renko 8t #7 | Chart data loading complete. 2026-07-14 14:00:11.622 | HD Request # 2 | Requesting historical Daily data for ESU26 starting at 2026-07-06. SC External HD service. 2026-07-14 14:00:11.751 | HD Request # 2 | Receiving historical Daily data for ESU6.CME starting at 2026-07-07. 2026-07-14 14:00:11.751 | HD Request # 2 | Writing historical Daily data to the file ESU6.CME.dly. 2026-07-14 14:00:11.754 | HD Request # 2 | Bytes received: 422 2026-07-14 14:00:11.754 | HD Request # 2 | Received 7 Daily data records from 2026-07-07 00:00:00 to 2026-07-14 00:00:00 (8.0 days) and wrote 6 records for ESU6.CME 2026-07-14 14:00:11.754 | HD Request # 2 | Completion time: 0s. 2026-07-14 14:00:11.754 | HD Request # 2 | Daily data download complete for ESU6.CME. Unique request ID: 8 2026-07-14 14:00:11.754 | Removing historical data download ID 8. 2026-07-14 14:00:11.754 | 2026-07-14 14:00:11.754 | No download requests in the queue to start downloads for. 2026-07-14 14:00:11.760 | ESU6.CME [CBV] Renko 8t #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:11.761 | ESU6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:00:11.776 | Loading market depth data. 2026-07-14 14:00:11.777 | ESU6.CME [CBV] Renko 8t #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:11.778 | ESU6.CME [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-14 14:00:11.854 | ESU6.CME [CBV] Renko 2t #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:11.854 | ESU6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 14:00:11.866 | Loading market depth data. 2026-07-14 14:00:11.866 | ESU6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 14:00:11.901 | ESU6.CME [CBV] Renko 16t #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:11.901 | ESU6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 14:00:11.912 | Loading market depth data. 2026-07-14 14:00:11.913 | ESU6.CME [CBV] Renko 16t #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:11.913 | ESU6.CME [CBV] Renko 16t #11 | Chart data loading complete. 2026-07-14 14:00:12.010 | ESU6.CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:12.010 | ESU6.CME [CBV] #1 | Reloading chart. 2026-07-14 14:00:12.066 | ESU6.CME [CBV] 5000 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:12.067 | ESU6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:00:12.081 | ESU6.CME [CBV] 5000 Volume #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.082 | ESU6.CME [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-14 14:00:12.082 | ESU6.CME [CBV] #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:12.083 | ESU6.CME [CBV] #8 | Reloading chart. 2026-07-14 14:00:12.139 | ESU6.CME [CBV] Renko 4t #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:12.139 | ESU6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 14:00:12.151 | Loading market depth data. 2026-07-14 14:00:12.153 | ESU6.CME [CBV] Renko 4t #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.154 | ESU6.CME [CBV] Renko 4t #9 | Chart data loading complete. 2026-07-14 14:00:12.229 | ESU6.CME [CBV] 100 Volume #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:12.229 | ESU6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 14:00:12.231 | Loading market depth data. 2026-07-14 14:00:12.231 | ESU6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 14:00:12.244 | ESU6.CME [CBV] 5000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:00:12.245 | ESU6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 14:00:12.259 | ESU6.CME [CBV] 5000 Volume #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.260 | ESU6.CME [CBV] 5000 Volume #4 | Chart data loading complete. 2026-07-14 14:00:12.260 | ESU6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:00:12.283 | Loading market depth data. 2026-07-14 14:00:12.285 | ESU6.CME [CBV] Renko 8t #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.287 | ESU6.CME [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-14 14:00:12.354 | ESU6.CME [CBV] Renko 2t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.355 | ESU6.CME [CBV] Renko 2t #6 | Chart data loading complete. 2026-07-14 14:00:12.401 | ESU6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 14:00:12.422 | Loading market depth data. 2026-07-14 14:00:12.422 | Requesting market depth updates for: ESU6.CME if supported. NumLevels=100 2026-07-14 14:00:12.422 | Separate subscription for market depth updates not supported. ESU6.CME 2026-07-14 14:00:12.510 | ESU6.CME [CBV] #1 | Reloading chart. 2026-07-14 14:00:12.598 | ESU6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:00:12.619 | ESU6.CME [CBV] 5000 Volume #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.621 | ESU6.CME [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-14 14:00:12.622 | ESU6.CME [CBV] #8 | Reloading chart. 2026-07-14 14:00:12.710 | ESU6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 14:00:12.733 | ESU6.CME [CBV] 100 Volume #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.733 | ESU6.CME [CBV] 100 Volume #12 | Chart data loading complete. 2026-07-14 14:00:12.733 | Loading market depth data. 2026-07-14 14:00:12.734 | ESU6.CME [CBV] Renko 4t #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.735 | ESU6.CME [CBV] Renko 4t #9 | Chart data loading complete. 2026-07-14 14:00:12.745 | ESU6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 14:00:12.901 | ESU6.CME [CBV] Renko 16t #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:12.902 | ESU6.CME [CBV] Renko 16t #11 | Chart data loading complete. 2026-07-14 14:00:13.245 | ESU6.CME [CBV] 5000 Volume #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:13.247 | ESU6.CME [CBV] 5000 Volume #4 | Chart data loading complete. 2026-07-14 14:00:35.973 | ESU6.CME [CBV] #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:35.981 | ESU6.CME [CBV] #1 | Chart data loading complete. 2026-07-14 14:00:36.052 | ESU6.CME [CBV] #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-14 14:00:36.059 | ESU6.CME [CBV] #8 | Chart data loading complete. 2026-07-14 14:08:43.548 | File >> Disconnect selected. 2026-07-14 14:08:43.548 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-07-14 14:08:43.548 | DTC Client socket (1) | CloseSocket call. 2026-07-14 14:08:43.548 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-07-14 14:08:43.549 | Rithmic Direct - DTC | Disconnected. 2026-07-14 14:08:43.551 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-07-14 14:08:43.551 | DTC Client socket (1) | Closed. 2026-07-14 14:08:53.030 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2. 2026-07-14 14:08:53.030 | Current selected Data/Trading service: CQG WebAPI 2026-07-14 14:08:53.246 | Symbol settings MD5 received. Request ID: 2. 2026-07-14 14:08:53.247 | Requested symbol settings for service code cqg. Request ID: 3. 2026-07-14 14:08:53.495 | Symbol settings received. Request ID: 3. 2026-07-14 14:08:58.662 | 2026-07-14 14:08:58.662 | CQG WebAPI | Connecting to server api.cqg.com 2026-07-14 14:08:58.662 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 2026-07-14 14:08:58.675 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. 2026-07-14 14:08:58.675 | CQG WebSocket socket (1) | New receive buffer size: 0 2026-07-14 14:08:58.675 | CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. 2026-07-14 14:08:58.678 | CQG WebSocket | Opening WebSocket. 2026-07-14 14:08:58.678 | CQG WebSocket | Sending WebSocket handshake. 2026-07-14 14:08:58.695 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols 2026-07-14 14:08:58.695 | CQG WebSocket | Server header | Connection: Upgrade 2026-07-14 14:08:58.695 | CQG WebSocket | Server header | Sec-WebSocket-Accept: Y3Gj+vGIadrDtUPPodXe7oOcQdQ= 2026-07-14 14:08:58.695 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2 2026-07-14 14:08:58.695 | CQG WebSocket | Server header | Upgrade: websocket 2026-07-14 14:08:58.695 | CQG WebSocket | Server header | 2026-07-14 14:08:58.695 | CQG WebSocket | Web socket state is now open. 2026-07-14 14:08:58.695 | CQG WebAPI | WebSocket connected. 2026-07-14 14:08:58.695 | CQG WebAPI | Sending market data logon message. 2026-07-14 14:08:58.819 | CQG WebAPI | Base Time: 2026-07-11T20:43:44. 2026-07-11 20:43:44 2026-07-14 14:08:58.819 | CQG WebAPI | Logon successful. Session Token = viinyWt5ZiTzygKdMYe6PaTnyVg/U4U6euc2qF8zdgkkcF8OBmhh5fFN7VbBejVDenZAhCV6ISy 2026-07-14 14:08:58.819 | CQG WebAPI | Connection to server complete. 2026-07-14 14:08:58.820 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-07-14 14:08:58.820 | Using symbol data fast lookup vector 2026-07-14 14:08:58.820 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU26. ID: 1 2026-07-14 14:08:58.820 | Symbol Error | F.US.EPU26 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU26. ID: 1 2026-07-14 14:08:58.820 | CQG WebAPI | Using primary service for historical data for F.US.EPU26 2026-07-14 14:08:58.820 | No historical data client is currently set to download historical Intraday data for F.US.EPU26. 2026-07-14 14:08:58.820 | Real-time Intraday chart data file updates started for F.US.EPU26 2026-07-14 14:08:58.820 | Intraday chart data file opened for F.US.EPU26 2026-07-14 14:08:58.820 | Updated verified funded futures trading account ending date to: 2026-08-13 14:08:58 2026-07-14 14:08:58.820 | CQG WebAPI | Sending Trade Accounts request message. 2026-07-14 14:08:58.876 | CQG WebAPI | Brokerage name: AMP. Account Name: 161273 2026-07-14 14:08:58.876 | Updated verified funded futures trading account ending date to: 2026-08-13 14:08:58 2026-07-14 14:08:58.876 | CQG WebAPI | Sending collateral subscribe request. 2026-07-14 14:08:59.073 | CQG WebAPI | Sending positions subscribe request. RequestID: 684697 2026-07-14 14:08:59.073 | CQG WebAPI | Sending orders subscribe request. RequestID: 684698 2026-07-14 14:09:05.034 | ESZ5.CME [CBV] #1 | Reloading chart. 2026-07-14 14:09:05.035 | ESZ5.CME [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.035 | ESZ5.CME [CBV] #1 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:05.077 | ESZ5.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:09:05.077 | ESZ5.CME [CBV] 5000 Volume #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.077 | ESZ5.CME [CBV] 5000 Volume #2 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:05.125 | ESZ5.CME #3 | Reloading chart. 2026-07-14 14:09:05.191 | ESZ5.CME Renko 4t #4 | Reloading chart. 2026-07-14 14:09:05.230 | ESZ5.CME [CBV] #5 | Reloading chart. 2026-07-14 14:09:05.230 | ESZ5.CME [CBV] #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.230 | ESZ5.CME [CBV] #5 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:05.265 | ESZ5.CME [CBV] Renko 4t #6 | Reloading chart. 2026-07-14 14:09:05.265 | ESZ5.CME [CBV] Renko 4t #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.265 | ESZ5.CME [CBV] Renko 4t #6 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:05.468 | ESZ5.CME [CBV] 100 Volume #7 | Reloading chart. 2026-07-14 14:09:05.468 | ESZ5.CME [CBV] 100 Volume #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.468 | ESZ5.CME [CBV] 100 Volume #7 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:05.510 | ESZ5.CME 5000 Volume #8 | Reloading chart. 2026-07-14 14:09:05.560 | ESZ5.CME [CBV] 5000 Volume #9 | Reloading chart. 2026-07-14 14:09:05.560 | ESZ5.CME [CBV] 5000 Volume #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.560 | ESZ5.CME [CBV] 5000 Volume #9 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:05.619 | ESZ5.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:09:05.619 | ESZ5.CME [CBV] Renko 8t #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:05.619 | ESZ5.CME [CBV] Renko 8t #10 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:06.105 | ESZ5.CME [CBV] Renko 2t #11 | Reloading chart. 2026-07-14 14:09:06.105 | ESZ5.CME [CBV] Renko 2t #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:09:06.105 | ESZ5.CME [CBV] Renko 2t #11 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:09:06.127 | ESZ5.CME Renko 8t #12 | Reloading chart. 2026-07-14 14:09:06.288 | CQG WebAPI | Starting real-time market data updates for: ESZ5.CME. ID: 2 2026-07-14 14:09:06.288 | CQG WebAPI | Sending symbol resolution request for ESZ5.CME. ID: 684699 2026-07-14 14:09:06.288 | CQG WebAPI | Requesting security definition data for: ESZ5.CME. ID: 2 2026-07-14 14:09:06.288 | CQG WebAPI | Using primary service for historical data for ESZ5.CME 2026-07-14 14:09:06.288 | Starting DelayedDownloadMonitoringTimer 2026-07-14 14:09:06.288 | Starting HDTimeoutTimer 2026-07-14 14:09:06.289 | Added historical Intraday data request for ESZ5.CME to the queue. 2026-07-14 14:09:06.289 | Intraday data recording state for symbol ESZ5.CME is set to download 'Pending'. 2026-07-14 14:09:06.289 | Triggering next historical data download in queue. 2026-07-14 14:09:06.289 | Delaying start of download for ESZ5.CME. 2026-07-14 14:09:06.311 | CQG WebAPI | Received message: Requested symbol was not found. 2026-07-14 14:09:06.311 | Symbol Error | ESZ5.CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-07-14 14:09:06.334 | Requesting market depth updates for: ESZ5.CME if supported. NumLevels=1400 2026-07-14 14:09:06.334 | Symbol Error | ESZ5.CME is unknown, unavailable, or improperly formatted. Symbol is invalid during SubscribeToSymbolDOM 2026-07-14 14:09:07.009 | Loading market depth data. 2026-07-14 14:09:07.379 | HD Request # 3 | Downloading Intraday chart data for ESZ5.CME to the file ESZ5.CME.scid. Service: cqg 2026-07-14 14:09:07.413 | HD Request # 3 | Download start date-time: 2026-01-09 14:09:07.000000. File last date-time: 2025-12-19 14:29:59.847000 2026-07-14 14:09:07.413 | HD Request # 3 | Error downloading historical Intraday data for ESZ5.CME. The symbol is unknown to the server. 2026-07-14 14:09:07.494 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESZ5.CME 2026-07-14 14:09:07.495 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-12-19 14:29:59.847000 2026-07-14 14:09:07.495 | HD Request # 3 | Completion time: 0s. 2026-07-14 14:09:07.495 | HD Request # 3 | Intraday data download complete for ESZ5.CME. Unique request ID: 9 2026-07-14 14:09:07.495 | Removing historical data download ID 9. 2026-07-14 14:09:07.495 | Real-time Intraday chart data file updates started for ESZ5.CME 2026-07-14 14:09:07.495 | Intraday chart data file opened for ESZ5.CME 2026-07-14 14:09:07.495 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-07-14 14:09:07.666 | 2026-07-14 14:09:07.667 | No download requests in the queue to start downloads for. 2026-07-14 14:09:14.569 | Loaded depth data records for ESZ5.CME 2025-12-16 from 2025-12-16 07:59:41.511000 to 2025-12-16 17:59:59.805000. 2026-07-14 14:09:18.885 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-07-14 14:09:19.010 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"Funded Trading Account Status Expiration Date Extended"}. Success=true 2026-07-14 14:09:24.061 | Loaded depth data records for ESZ5.CME 2025-12-17 from 2025-12-16 18:00:00.000000 to 2025-12-17 17:59:59.897000. 2026-07-14 14:09:28.027 | ESZ5.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:09:28.031 | ESZ5.CME #3 | Chart data loading complete. 2026-07-14 14:09:29.457 | ESZ5.CME [CBV-D] 5000 Volume #9 | Chart data loading complete. 2026-07-14 14:09:31.156 | Loaded depth data records for ESZ5.CME 2025-12-18 from 2025-12-17 18:00:00.000000 to 2025-12-18 17:59:59.675000. 2026-07-14 14:09:31.617 | Loaded depth data records for ESZ5.CME 2025-12-19 from 2025-12-18 18:00:00.001000 to 2025-12-19 08:29:59.847000. 2026-07-14 14:09:31.618 | ESZ5.CME [CBV-D] 100 Volume #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:09:31.766 | ESZ5.CME [CBV-D] 100 Volume #7 | Chart data loading complete. 2026-07-14 14:09:39.686 | ESZ5.CME [CBV-D] 5000 Volume #2 | Chart data loading complete. 2026-07-14 14:09:45.006 | ESZ5.CME 5000 Volume #8 | Chart data loading complete. 2026-07-14 14:09:52.030 | Loading market depth data. | Number times message added: 1 2026-07-14 14:09:55.033 | Loaded depth data records for ESZ5.CME 2025-12-09 from 2025-12-09 08:29:59.863000 to 2025-12-09 17:59:59.717000. 2026-07-14 14:09:55.344 | ESZ5.CME [CBV-D] #5 | Chart data loading complete. 2026-07-14 14:09:58.972 | Loaded depth data records for ESZ5.CME 2025-12-09 from 2025-12-09 08:29:59.863000 to 2025-12-09 17:59:59.717000. 2026-07-14 14:09:59.177 | Loaded depth data records for ESZ5.CME 2025-12-10 from 2025-12-09 18:00:00.000000 to 2025-12-10 17:59:59.993000. 2026-07-14 14:10:00.148 | ESZ5.CME [CBV-D] #1 | Chart data loading complete. 2026-07-14 14:10:04.821 | Loaded depth data records for ESZ5.CME 2025-12-11 from 2025-12-10 18:00:00.001000 to 2025-12-11 17:59:59.995000. 2026-07-14 14:10:05.591 | Loaded depth data records for ESZ5.CME 2025-12-10 from 2025-12-09 18:00:00.000000 to 2025-12-10 17:59:59.993000. 2026-07-14 14:10:11.876 | Loaded depth data records for ESZ5.CME 2025-12-12 from 2025-12-11 18:00:00.000000 to 2025-12-12 16:00:00.064000. 2026-07-14 14:10:11.878 | Loaded depth data records for ESZ5.CME 2025-12-13 from 2025-12-12 22:51:31.535839 to 2025-12-12 22:51:40.433000. 2026-07-14 14:10:14.124 | Loaded depth data records for ESZ5.CME 2025-12-11 from 2025-12-10 18:00:00.001000 to 2025-12-11 17:59:59.995000. 2026-07-14 14:10:15.274 | Loaded depth data records for ESZ5.CME 2025-12-16 from 2025-12-16 07:59:41.511000 to 2025-12-16 17:59:59.805000. 2026-07-14 14:10:18.748 | Loaded depth data records for ESZ5.CME 2025-12-17 from 2025-12-16 18:00:00.000000 to 2025-12-17 17:59:59.897000. 2026-07-14 14:10:21.822 | Loaded depth data records for ESZ5.CME 2025-12-18 from 2025-12-17 18:00:00.000000 to 2025-12-18 17:59:59.675000. 2026-07-14 14:10:22.009 | Loaded depth data records for ESZ5.CME 2025-12-19 from 2025-12-18 18:00:00.001000 to 2025-12-19 08:29:59.847000. 2026-07-14 14:10:22.011 | ESZ5.CME [CBV-D] Renko 2t #11 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:10:22.334 | Loaded depth data records for ESZ5.CME 2025-12-12 from 2025-12-11 18:00:00.000000 to 2025-12-12 16:00:00.064000. 2026-07-14 14:10:22.335 | Loaded depth data records for ESZ5.CME 2025-12-13 from 2025-12-12 22:51:31.535839 to 2025-12-12 22:51:40.433000. 2026-07-14 14:10:22.422 | ESZ5.CME [CBV-D] Renko 2t #11 | Chart data loading complete. 2026-07-14 14:10:23.980 | Loaded depth data records for ESZ5.CME 2025-12-16 from 2025-12-16 07:59:41.511000 to 2025-12-16 17:59:59.805000. 2026-07-14 14:10:25.620 | ESZ5.CME Renko 8t #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:10:25.733 | ESZ5.CME Renko 8t #12 | Chart data loading complete. 2026-07-14 14:10:26.022 | Loaded depth data records for ESZ5.CME 2025-12-17 from 2025-12-16 18:00:00.000000 to 2025-12-17 17:59:59.897000. 2026-07-14 14:10:27.077 | Loaded depth data records for ESZ5.CME 2025-12-18 from 2025-12-17 18:00:00.000000 to 2025-12-18 17:59:59.675000. 2026-07-14 14:10:27.160 | Loaded depth data records for ESZ5.CME 2025-12-19 from 2025-12-18 18:00:00.001000 to 2025-12-19 08:29:59.847000. 2026-07-14 14:10:27.161 | ESZ5.CME [CBV-D] Renko 8t #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:10:27.239 | ESZ5.CME [CBV-D] Renko 8t #10 | Chart data loading complete. 2026-07-14 14:10:30.194 | Loading market depth data. 2026-07-14 14:10:30.880 | Loaded depth data records for ESZ5.CME 2025-12-09 from 2025-12-09 08:29:59.863000 to 2025-12-09 17:59:59.717000. 2026-07-14 14:10:31.936 | Loaded depth data records for ESZ5.CME 2025-12-10 from 2025-12-09 18:00:00.000000 to 2025-12-10 17:59:59.993000. 2026-07-14 14:10:33.101 | Loaded depth data records for ESZ5.CME 2025-12-11 from 2025-12-10 18:00:00.001000 to 2025-12-11 17:59:59.995000. 2026-07-14 14:10:34.473 | Loaded depth data records for ESZ5.CME 2025-12-12 from 2025-12-11 18:00:00.000000 to 2025-12-12 16:00:00.064000. 2026-07-14 14:10:34.474 | Loaded depth data records for ESZ5.CME 2025-12-13 from 2025-12-12 22:51:31.535839 to 2025-12-12 22:51:40.433000. 2026-07-14 14:10:35.410 | Loaded depth data records for ESZ5.CME 2025-12-16 from 2025-12-16 07:59:41.511000 to 2025-12-16 17:59:59.805000. 2026-07-14 14:10:36.556 | Loaded depth data records for ESZ5.CME 2025-12-17 from 2025-12-16 18:00:00.000000 to 2025-12-17 17:59:59.897000. 2026-07-14 14:10:36.843 | ESZ5.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:10:37.077 | ESZ5.CME Renko 4t #4 | Chart data loading complete. 2026-07-14 14:10:37.629 | Loaded depth data records for ESZ5.CME 2025-12-18 from 2025-12-17 18:00:00.000000 to 2025-12-18 17:59:59.675000. 2026-07-14 14:10:37.723 | Loaded depth data records for ESZ5.CME 2025-12-19 from 2025-12-18 18:00:00.001000 to 2025-12-19 08:29:59.847000. 2026-07-14 14:10:37.725 | ESZ5.CME [CBV-D] Renko 4t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:10:37.964 | ESZ5.CME [CBV-D] Renko 4t #6 | Chart data loading complete. 2026-07-14 14:12:44.513 | F.US.EPU26 [CBV-D] #1 | Reloading chart. 2026-07-14 14:12:44.513 | CQG WebAPI | Using primary service for historical data for F.US.EPM25 2026-07-14 14:12:44.513 | No historical data client is currently set to download historical Intraday data for F.US.EPM25. 2026-07-14 14:12:44.518 | CQG WebAPI | Using primary service for historical data for F.US.EPU25 2026-07-14 14:12:44.518 | No historical data client is currently set to download historical Intraday data for F.US.EPU25. 2026-07-14 14:12:44.537 | CQG WebAPI | Using primary service for historical data for F.US.EPZ25 2026-07-14 14:12:44.537 | No historical data client is currently set to download historical Intraday data for F.US.EPZ25. 2026-07-14 14:12:44.538 | F.US.EPU26 [CBV-D] #1 | Performing continuous chart historical Daily data download for symbol F.US.EPZ25 starting at last date in file. 2026-07-14 14:12:44.538 | Added historical Daily data request for F.US.EPZ25 to the queue. 2026-07-14 14:12:44.538 | Triggering next historical data download in queue. 2026-07-14 14:12:44.538 | CQG WebAPI | Using primary service for historical data for F.US.EPH26 2026-07-14 14:12:44.538 | No historical data client is currently set to download historical Intraday data for F.US.EPH26. 2026-07-14 14:12:44.539 | F.US.EPU26 [CBV-D] #1 | Performing continuous chart historical Daily data download for symbol F.US.EPH26 starting at last date in file. 2026-07-14 14:12:44.539 | Added historical Daily data request for F.US.EPH26 to the queue. 2026-07-14 14:12:44.539 | CQG WebAPI | Using primary service for historical data for F.US.EPM26 2026-07-14 14:12:44.539 | No historical data client is currently set to download historical Intraday data for F.US.EPM26. 2026-07-14 14:12:44.539 | F.US.EPU26 [CBV-D] #1 | Performing continuous chart historical Daily data download for symbol F.US.EPM26 starting at last date in file. 2026-07-14 14:12:44.539 | Added historical Daily data request for F.US.EPM26 to the queue. 2026-07-14 14:12:44.540 | CQG WebAPI | Using primary service for historical data for F.US.EPU26 2026-07-14 14:12:44.540 | No historical data client is currently set to download historical Intraday data for F.US.EPU26. 2026-07-14 14:12:44.540 | F.US.EPU26 [CBV-D] #1 | Performing continuous chart historical Daily data download for symbol F.US.EPU26 starting at last date in file. 2026-07-14 14:12:44.540 | Added historical Daily data request for F.US.EPU26 to the queue. 2026-07-14 14:12:44.553 | F.US.EPU26 [CBV-D] #1 | Waiting for historical downloads to complete with the IDs: 10, 11, 12, 13, 2026-07-14 14:12:44.557 | F.US.EPU26 [CBV-D] 5000 Volume #2 | Reloading chart. 2026-07-14 14:12:44.557 | Enabling compression for file: C:\SierraChart\Data\F.US.EPM26.scid 2026-07-14 14:12:44.558 | F.US.EPU26 [CBV-D] 5000 Volume #2 | Waiting for historical downloads to complete with the IDs: 12, 13, 2026-07-14 14:12:44.561 | F.US.EPU26 #3 | Reloading chart. 2026-07-14 14:12:44.574 | F.US.EPU26 Renko 4t #4 | Reloading chart. 2026-07-14 14:12:44.579 | F.US.EPU26 [CBV-D] #5 | Reloading chart. 2026-07-14 14:12:44.579 | Enabling compression for file: C:\SierraChart\Data\F.US.EPM25.scid 2026-07-14 14:12:44.581 | Enabling compression for file: C:\SierraChart\Data\F.US.EPH26.scid 2026-07-14 14:12:44.596 | F.US.EPU26 [CBV-D] #5 | Waiting for historical downloads to complete with the IDs: 10, 11, 12, 13, 2026-07-14 14:12:44.625 | F.US.EPU26 [CBV-D] Renko 4t #6 | Reloading chart. 2026-07-14 14:12:44.626 | F.US.EPU26 [CBV-D] Renko 4t #6 | Waiting for historical downloads to complete with the IDs: 12, 13, 2026-07-14 14:12:44.638 | F.US.EPU26 [CBV-D] 100 Volume #7 | Reloading chart. 2026-07-14 14:12:44.639 | F.US.EPU26 [CBV-D] 100 Volume #7 | Waiting for historical downloads to complete with the IDs: 13, 2026-07-14 14:12:44.640 | F.US.EPU26 5000 Volume #8 | Reloading chart. 2026-07-14 14:12:44.643 | F.US.EPU26 [CBV-D] 5000 Volume #9 | Reloading chart. 2026-07-14 14:12:44.644 | F.US.EPU26 [CBV-D] 5000 Volume #9 | Waiting for historical downloads to complete with the IDs: 12, 13, 2026-07-14 14:12:44.655 | F.US.EPU26 [CBV-D] Renko 8t #10 | Reloading chart. 2026-07-14 14:12:44.657 | F.US.EPU26 [CBV-D] Renko 8t #10 | Waiting for historical downloads to complete with the IDs: 12, 13, 2026-07-14 14:12:44.754 | F.US.EPU26 [CBV-D] Renko 2t #11 | Reloading chart. 2026-07-14 14:12:44.755 | F.US.EPU26 [CBV-D] Renko 2t #11 | Waiting for historical downloads to complete with the IDs: 12, 13, 2026-07-14 14:12:44.763 | F.US.EPU26 Renko 8t #12 | Reloading chart. 2026-07-14 14:12:44.790 | HD Request # 4 | Downloading Historical Daily chart data for F.US.EPZ25. Starting date: 2025-10-28. Service: cqg 2026-07-14 14:12:44.794 | F.US.EPU26 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:12:44.800 | F.US.EPU26 #3 | Chart data loading complete. 2026-07-14 14:12:44.801 | F.US.EPU26 Renko 4t #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:44.806 | F.US.EPU26 Renko 4t #4 | Chart data loading complete. 2026-07-14 14:12:44.809 | F.US.EPU26 5000 Volume #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:44.827 | F.US.EPU26 5000 Volume #8 | Chart data loading complete. 2026-07-14 14:12:44.831 | F.US.EPU26 Renko 8t #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:44.831 | F.US.EPU26 Renko 8t #12 | Chart data loading complete. 2026-07-14 14:12:44.937 | HD Request # 4 | Requesting historical Daily data for ESZ25 starting at 2025-10-27. SC External HD service. 2026-07-14 14:12:45.078 | HD Request # 4 | Receiving historical Daily data for F.US.EPZ25 starting at 2025-10-28. 2026-07-14 14:12:45.078 | HD Request # 4 | Writing historical Daily data to the file F.US.EPZ25.dly. 2026-07-14 14:12:45.081 | HD Request # 4 | Bytes received: 2343 2026-07-14 14:12:45.081 | HD Request # 4 | Received 39 Daily data records from 2025-10-28 00:00:00 to 2025-12-19 00:00:00 (53.0 days) and wrote 38 records for F.US.EPZ25 2026-07-14 14:12:45.081 | HD Request # 4 | Completion time: 1s. 2026-07-14 14:12:45.081 | HD Request # 4 | Daily data download complete for F.US.EPZ25. Unique request ID: 10 2026-07-14 14:12:45.081 | Removing historical data download ID 10. 2026-07-14 14:12:45.081 | 2026-07-14 14:12:45.081 | Triggering next historical data download in queue. 2026-07-14 14:12:45.082 | HD Request # 5 | Downloading Historical Daily chart data for F.US.EPH26. Starting date: 1986-04-10. Service: cqg 2026-07-14 14:12:45.194 | HD Request # 5 | Requesting historical Daily data for ESH26 starting at 1986-04-09. SC External HD service. 2026-07-14 14:12:45.344 | HD Request # 5 | Receiving historical Daily data for F.US.EPH26 starting at 2023-08-17. 2026-07-14 14:12:45.344 | HD Request # 5 | Writing historical Daily data to the file F.US.EPH26.dly. 2026-07-14 14:12:45.346 | HD Request # 5 | Bytes received: 32872 2026-07-14 14:12:45.346 | HD Request # 5 | Received 651 Daily data records from 2023-08-17 00:00:00 to 2026-03-20 00:00:00 (2.6 years) and wrote 651 records for F.US.EPH26 2026-07-14 14:12:45.346 | HD Request # 5 | Completion time: 0s. 2026-07-14 14:12:45.346 | HD Request # 5 | Daily data download complete for F.US.EPH26. Unique request ID: 11 2026-07-14 14:12:45.346 | Removing historical data download ID 11. 2026-07-14 14:12:45.346 | 2026-07-14 14:12:45.346 | Triggering next historical data download in queue. 2026-07-14 14:12:45.347 | HD Request # 6 | Downloading Historical Daily chart data for F.US.EPM26. Starting date: 1986-07-10. Service: cqg 2026-07-14 14:12:45.460 | HD Request # 6 | Requesting historical Daily data for ESM26 starting at 1986-07-09. SC External HD service. 2026-07-14 14:12:45.501 | HD Request # 6 | Receiving historical Daily data for F.US.EPM26 starting at 2023-08-17. 2026-07-14 14:12:45.501 | HD Request # 6 | Writing historical Daily data to the file F.US.EPM26.dly. 2026-07-14 14:12:45.504 | HD Request # 6 | Bytes received: 35646 2026-07-14 14:12:45.504 | HD Request # 6 | Received 714 Daily data records from 2023-08-17 00:00:00 to 2026-06-18 00:00:00 (2.8 years) and wrote 714 records for F.US.EPM26 2026-07-14 14:12:45.504 | HD Request # 6 | Completion time: 0s. 2026-07-14 14:12:45.504 | HD Request # 6 | Daily data download complete for F.US.EPM26. Unique request ID: 12 2026-07-14 14:12:45.504 | Removing historical data download ID 12. 2026-07-14 14:12:45.504 | 2026-07-14 14:12:45.504 | Triggering next historical data download in queue. 2026-07-14 14:12:45.504 | HD Request # 7 | Downloading Historical Daily chart data for F.US.EPU26. Starting date: 1986-07-24. Service: cqg 2026-07-14 14:12:45.618 | HD Request # 7 | Requesting historical Daily data for ESU26 starting at 1986-07-23. SC External HD service. 2026-07-14 14:12:45.659 | HD Request # 7 | Receiving historical Daily data for F.US.EPU26 starting at 2023-08-17. 2026-07-14 14:12:45.660 | HD Request # 7 | Writing historical Daily data to the file F.US.EPU26.dly. 2026-07-14 14:12:45.662 | HD Request # 7 | Bytes received: 35844 2026-07-14 14:12:45.662 | HD Request # 7 | Received 730 Daily data records from 2023-08-17 00:00:00 to 2026-07-14 00:00:00 (2.9 years) and wrote 730 records for F.US.EPU26 2026-07-14 14:12:45.662 | HD Request # 7 | Completion time: 0s. 2026-07-14 14:12:45.662 | HD Request # 7 | Daily data download complete for F.US.EPU26. Unique request ID: 13 2026-07-14 14:12:45.662 | Removing historical data download ID 13. 2026-07-14 14:12:45.662 | 2026-07-14 14:12:45.662 | No download requests in the queue to start downloads for. 2026-07-14 14:12:45.744 | F.US.EPU26 [CBV] Renko 2t #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:45.745 | F.US.EPU26 [CBV] Renko 2t #11 | Reloading chart. 2026-07-14 14:12:45.750 | Enabling compression for file: C:\SierraChart\Data\F.US.EPM26.dly 2026-07-14 14:12:45.757 | Enabling compression for file: C:\SierraChart\Data\F.US.EPU26.dly 2026-07-14 14:12:45.773 | Loading market depth data. 2026-07-14 14:12:45.773 | F.US.EPU26 [CBV] Renko 2t #11 | Reloading chart. 2026-07-14 14:12:46.010 | F.US.EPU26 [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.011 | F.US.EPU26 [CBV] #1 | Reloading chart. 2026-07-14 14:12:46.048 | Enabling compression for file: C:\SierraChart\Data\F.US.EPH26.dly 2026-07-14 14:12:46.077 | F.US.EPU26 [CBV] 5000 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.077 | F.US.EPU26 [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:12:46.095 | F.US.EPU26 [CBV] 5000 Volume #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.103 | F.US.EPU26 [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-14 14:12:46.122 | F.US.EPU26 [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.123 | F.US.EPU26 [CBV] #5 | Reloading chart. 2026-07-14 14:12:46.187 | F.US.EPU26 [CBV] Renko 4t #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.187 | F.US.EPU26 [CBV] Renko 4t #6 | Reloading chart. 2026-07-14 14:12:46.204 | Loading market depth data. 2026-07-14 14:12:46.215 | F.US.EPU26 [CBV] Renko 4t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.217 | F.US.EPU26 [CBV] Renko 4t #6 | Chart data loading complete. 2026-07-14 14:12:46.224 | F.US.EPU26 [CBV] 5000 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.225 | F.US.EPU26 [CBV] 5000 Volume #9 | Reloading chart. 2026-07-14 14:12:46.253 | F.US.EPU26 [CBV] 5000 Volume #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.254 | F.US.EPU26 [CBV] 5000 Volume #9 | Chart data loading complete. 2026-07-14 14:12:46.262 | F.US.EPU26 [CBV] 100 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.263 | F.US.EPU26 [CBV] 100 Volume #7 | Reloading chart. 2026-07-14 14:12:46.275 | F.US.EPU26 [CBV] Renko 8t #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-14 14:12:46.276 | Loading market depth data. 2026-07-14 14:12:46.276 | F.US.EPU26 [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:12:46.288 | Loading market depth data. 2026-07-14 14:12:46.288 | F.US.EPU26 [CBV] 100 Volume #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.288 | F.US.EPU26 [CBV] 100 Volume #7 | Chart data loading complete. 2026-07-14 14:12:46.289 | F.US.EPU26 [CBV] Renko 8t #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.293 | F.US.EPU26 [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-14 14:12:46.316 | F.US.EPU26 [CBV] Renko 2t #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.316 | F.US.EPU26 [CBV] Renko 2t #11 | Chart data loading complete. 2026-07-14 14:12:46.511 | F.US.EPU26 [CBV] #1 | Reloading chart. 2026-07-14 14:12:46.632 | F.US.EPU26 [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:12:46.674 | F.US.EPU26 [CBV] 5000 Volume #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.676 | F.US.EPU26 [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-14 14:12:46.684 | F.US.EPU26 [CBV] #5 | Reloading chart. 2026-07-14 14:12:46.815 | F.US.EPU26 [CBV] Renko 4t #6 | Reloading chart. 2026-07-14 14:12:46.848 | F.US.EPU26 [CBV] 5000 Volume #9 | Reloading chart. 2026-07-14 14:12:46.870 | Loading market depth data. 2026-07-14 14:12:46.873 | F.US.EPU26 [CBV] Renko 4t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.913 | F.US.EPU26 [CBV] Renko 4t #6 | Chart data loading complete. 2026-07-14 14:12:46.914 | F.US.EPU26 [CBV] 5000 Volume #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.921 | F.US.EPU26 [CBV] 5000 Volume #9 | Chart data loading complete. 2026-07-14 14:12:46.941 | F.US.EPU26 [CBV] 100 Volume #7 | Reloading chart. 2026-07-14 14:12:46.944 | Loading market depth data. 2026-07-14 14:12:46.963 | F.US.EPU26 [CBV] 100 Volume #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:46.970 | F.US.EPU26 [CBV] 100 Volume #7 | Chart data loading complete. 2026-07-14 14:12:46.982 | Requesting market depth updates for: F.US.EPU26 if supported. NumLevels=100 2026-07-14 14:12:46.982 | CQG WebAPI | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPU26 2026-07-14 14:12:46.983 | F.US.EPU26 [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:12:47.018 | Loading market depth data. 2026-07-14 14:12:47.024 | F.US.EPU26 [CBV] Renko 8t #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:47.026 | F.US.EPU26 [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-14 14:12:55.196 | F.US.EPU26 [CBV] #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:55.197 | F.US.EPU26 [CBV] #5 | Chart data loading complete. 2026-07-14 14:12:55.198 | F.US.EPU26 [CBV] #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU26.scid 2026-07-14 14:12:55.201 | F.US.EPU26 [CBV] #1 | Chart data loading complete. 2026-07-14 14:13:53.618 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-14 14:13:53.618 | ESH6.CME [CBV] #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:53.618 | ESH6.CME [CBV] #1 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:53.708 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:13:53.708 | ESH6.CME [CBV] 5000 Volume #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:53.708 | ESH6.CME [CBV] 5000 Volume #2 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:53.829 | ESH6.CME #3 | Reloading chart. 2026-07-14 14:13:54.026 | ESH6.CME Renko 4t #5 | Reloading chart. 2026-07-14 14:13:54.229 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-14 14:13:54.229 | ESH6.CME [CBV] #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:54.229 | ESH6.CME [CBV] #8 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:54.393 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 14:13:54.393 | ESH6.CME [CBV] Renko 4t #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:54.393 | ESH6.CME [CBV] Renko 4t #9 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:54.941 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 14:13:54.941 | ESH6.CME [CBV] 100 Volume #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:54.941 | ESH6.CME [CBV] 100 Volume #12 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:55.221 | ESH6.CME 5000 Volume #13 | Reloading chart. 2026-07-14 14:13:55.699 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 14:13:55.699 | ESH6.CME [CBV] 5000 Volume #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:55.699 | ESH6.CME [CBV] 5000 Volume #4 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:55.769 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:13:55.769 | ESH6.CME [CBV] Renko 8t #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:55.769 | ESH6.CME [CBV] Renko 8t #10 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:56.524 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 14:13:56.524 | ESH6.CME [CBV] Renko 2t #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:56.524 | ESH6.CME [CBV] Renko 2t #6 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:57.124 | ESH6.CME Renko 8t #7 | Reloading chart. 2026-07-14 14:13:57.492 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 14:13:57.492 | ESH6.CME [CBV] Renko 16t #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-07-14 14:13:57.492 | ESH6.CME [CBV] Renko 16t #11 | There are no continuous futures contract symbols. Loading data normally. 2026-07-14 14:13:57.673 | CQG WebAPI | Starting real-time market data updates for: ESH6.CME. ID: 6 2026-07-14 14:13:57.673 | CQG WebAPI | Sending symbol resolution request for ESH6.CME. ID: 684700 2026-07-14 14:13:57.673 | CQG WebAPI | Requesting security definition data for: ESH6.CME. ID: 6 2026-07-14 14:13:57.755 | CQG WebAPI | Received message: Requested symbol was not found. 2026-07-14 14:13:57.755 | Symbol Error | ESH6.CME is unknown, unavailable, or improperly formatted. Requested symbol was not found. 2026-07-14 14:13:57.965 | CQG WebAPI | Using primary service for historical data for ESH6.CME 2026-07-14 14:13:57.965 | Added historical Intraday data request for ESH6.CME to the queue. 2026-07-14 14:13:57.965 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-07-14 14:13:57.965 | Triggering next historical data download in queue. 2026-07-14 14:13:57.965 | HD Request # 8 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cqg 2026-07-14 14:13:58.150 | HD Request # 8 | Download start date-time: 2026-02-27 21:59:59.000000. File last date-time: 2026-02-27 21:59:59.001009 2026-07-14 14:13:58.150 | HD Request # 8 | Error downloading historical Intraday data for ESH6.CME. The symbol is unknown to the server. 2026-07-14 14:13:58.150 | HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESH6.CME 2026-07-14 14:13:58.557 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2026-02-27 21:59:59.001009 2026-07-14 14:13:58.573 | HD Request # 8 | Completion time: 1s. 2026-07-14 14:13:58.573 | HD Request # 8 | Intraday data download complete for ESH6.CME. Unique request ID: 14 2026-07-14 14:13:58.573 | Removing historical data download ID 14. 2026-07-14 14:13:58.573 | Real-time Intraday chart data file updates started for ESH6.CME 2026-07-14 14:13:58.573 | Intraday chart data file opened for ESH6.CME 2026-07-14 14:13:58.573 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2026-07-14 14:13:58.574 | 2026-07-14 14:13:58.574 | No download requests in the queue to start downloads for. 2026-07-14 14:13:58.608 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=1400 2026-07-14 14:13:58.608 | Symbol Error | ESH6.CME is unknown, unavailable, or improperly formatted. Symbol is invalid during SubscribeToSymbolDOM 2026-07-14 14:14:05.670 | Loading market depth data. 2026-07-14 14:14:14.036 | ESH6.CME [CBV] #1 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:15.147 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 14:14:16.976 | ESH6.CME [CBV] 5000 Volume #2 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.121 | ESH6.CME #3 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.417 | ESH6.CME Renko 4t #5 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.467 | ESH6.CME [CBV] #8 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.695 | Loading market depth data. 2026-07-14 14:14:17.695 | ESH6.CME [CBV] Renko 4t #9 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.701 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 09:10:03.782000. 2026-07-14 14:14:17.708 | Loaded depth data records for ESH6.CME 2026-02-25 from 00:00:00.000000 to 00:00:00.000000. 2026-07-14 14:14:17.709 | Loaded depth data records for ESH6.CME 2026-02-26 from 00:00:00.000000 to 00:00:00.000000. 2026-07-14 14:14:17.711 | Loaded depth data records for ESH6.CME 2026-02-27 from 00:00:00.000000 to 00:00:00.000000. 2026-07-14 14:14:17.711 | ESH6.CME [CBV] 100 Volume #12 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.884 | ESH6.CME 5000 Volume #13 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:17.924 | ESH6.CME [CBV] 5000 Volume #4 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:18.034 | Loading market depth data. 2026-07-14 14:14:18.034 | ESH6.CME [CBV] Renko 8t #10 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:18.046 | Loading market depth data. 2026-07-14 14:14:18.046 | ESH6.CME [CBV] Renko 2t #6 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:18.065 | ESH6.CME Renko 8t #7 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:18.124 | Loading market depth data. 2026-07-14 14:14:18.124 | ESH6.CME [CBV] Renko 16t #11 | Chart Data Loading Thread: Load canceled. 2026-07-14 14:14:31.251 | CQG WebAPI | Sending Web API Logoff message. 2026-07-14 14:14:31.251 | CQG WebSocket socket (1) | CloseSocket call. 2026-07-14 14:14:31.251 | CQG WebSocket | WebSocket closed. 2026-07-14 14:14:31.251 | CQG WebAPI | WebSocket closed. 2026-07-14 14:14:31.251 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 2026-07-14 14:14:31.251 | CQG WebAPI | Disconnected. 2026-07-14 14:14:31.251 | CQG WebSocket socket (0) | CloseSocket call. | Number times message added: 2 2026-07-14 14:14:31.253 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 14:14:31.254 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed. 2026-07-14 14:14:31.254 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. 2026-07-14 14:14:31.256 | CQG WebSocket socket (1) | Socket gracefully closed by remote side. 2026-07-14 14:14:31.257 | CQG WebSocket socket (1) | Closed. 2026-07-14 14:14:31.288 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. 2026-07-14 14:14:31.289 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | New receive buffer size: 0 2026-07-14 14:14:31.289 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Connecting to IP: 38.79.0.89. 2026-07-14 14:14:31.291 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 4. 2026-07-14 14:14:31.291 | Current selected Data/Trading service: Rithmic Direct - DTC 2026-07-14 14:14:31.326 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-07-14 14:14:31.451 | Symbol settings MD5 received. Request ID: 4. 2026-07-14 14:14:31.451 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 5. 2026-07-14 14:14:31.516 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. 2026-07-14 14:14:31.516 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-14 14:14:31.517 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 14:14:31.518 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | CloseSocket call. 2026-07-14 14:14:31.518 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-07-14 14:14:31.518 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Closed. 2026-07-14 14:14:31.518 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. 2026-07-14 14:14:31.711 | Symbol settings received. Request ID: 5. 2026-07-14 14:14:35.338 | 2026-07-14 14:14:35.339 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-07-14 14:14:35.339 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-07-14 14:14:35.340 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-07-14 14:14:35.382 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-14 14:14:35.382 | DTC Client socket (1) | New receive buffer size: 0 2026-07-14 14:14:35.382 | DTC Client socket (1) | Connecting to IP: 38.65.210.70. 2026-07-14 14:14:35.385 | Rithmic Direct - DTC | Network connection to server complete. 2026-07-14 14:14:35.385 | Rithmic Direct - DTC | Starting socket receive thread. 2026-07-14 14:14:35.385 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-07-14 14:14:35.385 | Rithmic Direct - DTC | Sending logon request message. 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Received logon response. 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Server Name: . 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Successfully connected. 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Trading is supported. 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | OCO Orders supported. 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-07-14 14:14:35.403 | Rithmic Direct - DTC | Connection to server complete. 2026-07-14 14:14:35.405 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-07-14 14:14:35.405 | Using symbol data fast lookup vector 2026-07-14 14:14:35.405 | Rithmic Direct - DTC | Starting real-time market data updates for: F.US.EPU26. ID: 1 2026-07-14 14:14:35.405 | Rithmic Direct - DTC | Requesting security definition data for: F.US.EPU26. ID: 1 2026-07-14 14:14:35.405 | Rithmic Direct - DTC | Using primary service for historical data for F.US.EPU26 2026-07-14 14:14:35.405 | Starting DelayedDownloadMonitoringTimer 2026-07-14 14:14:35.405 | Starting HDTimeoutTimer 2026-07-14 14:14:35.405 | Historical data service client indicated that downloads are not enabled. Symbol: F.US.EPU26. Data Type: Intraday data. 2026-07-14 14:14:35.405 | Historical data download ID 15 not found when removing ID from outstanding request set. 2026-07-14 14:14:35.405 | Real-time Intraday chart data file updates started for F.US.EPU26 2026-07-14 14:14:35.405 | Intraday chart data file opened for F.US.EPU26 2026-07-14 14:14:40.293 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-14 14:14:40.416 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-14 14:14:40.455 | ESH6.CME #3 | Reloading chart. 2026-07-14 14:14:40.497 | ESH6.CME Renko 4t #5 | Reloading chart. 2026-07-14 14:14:40.582 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-14 14:14:40.732 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-14 14:14:41.080 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-14 14:14:41.107 | ESH6.CME 5000 Volume #13 | Reloading chart. 2026-07-14 14:14:41.141 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-14 14:14:41.184 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-14 14:14:41.606 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-14 14:14:41.637 | ESH6.CME Renko 8t #7 | Reloading chart. 2026-07-14 14:14:41.664 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-14 14:14:41.845 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU6.CME. ID: 2 Service code: rithmic.trading 2026-07-14 14:14:41.845 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESU6.CME. 2026-07-14 14:14:41.845 | Rithmic Direct - DTC | Requesting security definition data for: ESU6.CME. ID: 2 2026-07-14 14:14:41.982 | Rithmic Direct - DTC | Starting real-time market data updates for: ESH6.CME. ID: 3 Service code: rithmic.trading 2026-07-14 14:14:41.982 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESH6.CME. 2026-07-14 14:14:41.982 | Rithmic Direct - DTC | Requesting security definition data for: ESH6.CME. ID: 3 2026-07-14 14:14:41.982 | Rithmic Direct - DTC | Using primary service for historical data for ESH6.CME 2026-07-14 14:14:41.982 | Historical data service client indicated that downloads are not enabled. Symbol: ESH6.CME. Data Type: Intraday data. 2026-07-14 14:14:41.982 | Historical data download ID 16 not found when removing ID from outstanding request set. 2026-07-14 14:14:41.982 | Real-time Intraday chart data file updates started for ESH6.CME 2026-07-14 14:14:41.982 | Intraday chart data file opened for ESH6.CME 2026-07-14 14:14:42.020 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=100 2026-07-14 14:14:42.020 | Separate subscription for market depth updates not supported. ESH6.CME 2026-07-14 14:14:50.192 | Loading market depth data. 2026-07-14 14:14:55.358 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. 2026-07-14 14:14:55.359 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0 2026-07-14 14:14:55.359 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 38.79.0.89. 2026-07-14 14:14:55.539 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2026-07-14 14:14:55.540 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-14 14:14:55.541 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 14:14:55.541 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call. 2026-07-14 14:14:55.541 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-07-14 14:14:55.541 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed. 2026-07-14 14:14:57.332 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 14:15:12.309 | ESH6.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:15:12.315 | ESH6.CME #3 | Chart data loading complete. 2026-07-14 14:15:12.325 | ESH6.CME 5000 Volume #13 | Chart data loading complete. 2026-07-14 14:15:12.524 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 14:15:14.856 | ESH6.CME [CBV] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:15:15.525 | ESH6.CME [CBV] 5000 Volume #4 | Chart data loading complete. 2026-07-14 14:15:20.482 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 14:15:30.250 | ESH6.CME [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-14 14:15:33.876 | Loading market depth data. 2026-07-14 14:15:33.977 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 14:15:38.438 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-14 14:15:38.753 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 14:15:43.254 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-14 14:15:49.050 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 14:15:49.051 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 14:15:50.201 | ESH6.CME [CBV] #8 | Chart data loading complete. 2026-07-14 14:15:51.463 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 14:15:53.637 | ESH6.CME Renko 8t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:15:53.723 | ESH6.CME Renko 8t #7 | Chart data loading complete. 2026-07-14 14:15:53.828 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 14:15:53.831 | ESH6.CME [CBV] 100 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:15:54.248 | ESH6.CME [CBV] 100 Volume #12 | Chart data loading complete. 2026-07-14 14:15:54.463 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 14:15:56.787 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 14:15:58.968 | Loading market depth data. 2026-07-14 14:15:59.047 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 14:15:59.486 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 14:15:59.672 | Loading market depth data. 2026-07-14 14:15:59.971 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 14:16:05.260 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 14:16:05.262 | ESH6.CME [CBV] Renko 2t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:16:05.786 | ESH6.CME [CBV] Renko 2t #6 | Chart data loading complete. 2026-07-14 14:16:05.834 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. | Number times message added: 1 2026-07-14 14:16:08.280 | Loading market depth data. 2026-07-14 14:16:08.405 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-14 14:16:11.972 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. | Number times message added: 1 2026-07-14 14:16:15.199 | ESH6.CME [CBV] #1 | Chart data loading complete. 2026-07-14 14:16:16.829 | ESH6.CME Renko 4t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:16:17.176 | ESH6.CME Renko 4t #5 | Chart data loading complete. 2026-07-14 14:16:18.026 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-14 14:16:22.489 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 14:16:22.492 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 14:16:25.651 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 14:16:25.652 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 14:16:31.494 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 14:16:32.005 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-14 14:16:34.702 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 14:16:42.682 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. | Number times message added: 1 2026-07-14 14:16:48.097 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-14 14:16:48.098 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-14 14:16:49.969 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. | Number times message added: 1 2026-07-14 14:16:58.323 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-14 14:17:02.532 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. | Number times message added: 1 2026-07-14 14:17:10.887 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-14 14:17:18.008 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 14:17:18.010 | ESH6.CME [CBV] Renko 16t #11 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:17:18.021 | ESH6.CME [CBV] Renko 16t #11 | Chart data loading complete. 2026-07-14 14:17:18.407 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-14 14:17:19.570 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 14:17:19.572 | ESH6.CME [CBV] Renko 8t #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:17:19.647 | ESH6.CME [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-14 14:17:21.170 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-14 14:17:23.473 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-14 14:17:23.474 | ESH6.CME [CBV] Renko 4t #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-14 14:17:23.686 | ESH6.CME [CBV] Renko 4t #9 | Chart data loading complete. 2026-07-14 18:14:55.596 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. 2026-07-14 18:14:55.596 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | New receive buffer size: 0 2026-07-14 18:14:55.596 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Connecting to IP: 216.66.0.130. 2026-07-14 18:14:55.751 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-14 18:14:55.752 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 18:14:56.004 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | CloseSocket call. 2026-07-14 18:14:56.004 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close. 2026-07-14 18:14:56.022 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. 2026-07-14 18:14:56.022 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Closed. 2026-07-14 22:14:55.797 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. 2026-07-14 22:14:55.798 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | New receive buffer size: 0 2026-07-14 22:14:55.798 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Connecting to IP: 38.79.0.89. 2026-07-14 22:14:55.970 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. 2026-07-14 22:14:55.971 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-14 22:14:55.971 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-14 22:14:55.971 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | CloseSocket call. 2026-07-14 22:14:55.972 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-07-14 22:14:55.972 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Closed. 2026-07-14 22:14:55.972 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. 2026-07-15 02:14:56.016 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2. 2026-07-15 02:14:56.016 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 0 2026-07-15 02:14:56.016 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Connecting to IP: 38.79.0.89. 2026-07-15 02:14:56.222 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2026-07-15 02:14:56.255 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-15 02:14:56.256 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-15 02:14:56.256 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | CloseSocket call. 2026-07-15 02:14:56.256 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-07-15 02:14:56.257 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Closed. 2026-07-15 06:14:56.322 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Creating socket. Using TLS 1.2. 2026-07-15 06:14:56.322 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | New receive buffer size: 0 2026-07-15 06:14:56.322 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Connecting to IP: 216.66.0.130. 2026-07-15 06:14:56.477 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-15 06:14:56.478 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-15 06:14:56.740 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | CloseSocket call. 2026-07-15 06:14:56.740 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Shutdown started. Waiting for graceful close. 2026-07-15 06:14:56.760 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Socket gracefully closed by remote side. 2026-07-15 06:14:56.760 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Closed. 2026-07-15 10:14:56.557 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Creating socket. Using TLS 1.2. 2026-07-15 10:14:56.558 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | New receive buffer size: 0 2026-07-15 10:14:56.558 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Connecting to IP: 216.66.0.130. 2026-07-15 10:14:56.691 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-15 10:14:56.692 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-15 10:14:56.943 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | CloseSocket call. 2026-07-15 10:14:56.943 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Shutdown started. Waiting for graceful close. 2026-07-15 10:14:56.962 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Socket gracefully closed by remote side. 2026-07-15 10:14:56.962 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Closed. 2026-07-15 14:14:56.722 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Creating socket. Using TLS 1.2. 2026-07-15 14:14:56.723 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | New receive buffer size: 0 2026-07-15 14:14:56.723 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Connecting to IP: 216.66.0.130. 2026-07-15 14:14:56.852 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-15 14:14:56.853 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-15 14:14:57.109 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | CloseSocket call. 2026-07-15 14:14:57.109 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Shutdown started. Waiting for graceful close. 2026-07-15 14:14:57.127 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Socket gracefully closed by remote side. 2026-07-15 14:14:57.128 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Closed. 2026-07-15 14:39:27.233 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-15 14:39:27.234 | Rithmic Direct - DTC | Using primary service for historical data for ESM5.CME 2026-07-15 14:39:27.234 | Historical data service client indicated that downloads are not enabled. Symbol: ESM5.CME. Data Type: Intraday data. 2026-07-15 14:39:27.234 | Historical data download ID 17 not found when removing ID from outstanding request set. 2026-07-15 14:39:27.235 | Real-time Intraday chart data file updates started for ESM5.CME 2026-07-15 14:39:27.235 | Intraday chart data file opened for ESM5.CME 2026-07-15 14:39:27.235 | Rithmic Direct - DTC | Using primary service for historical data for ESU5.CME 2026-07-15 14:39:27.235 | Historical data service client indicated that downloads are not enabled. Symbol: ESU5.CME. Data Type: Intraday data. 2026-07-15 14:39:27.235 | Historical data download ID 18 not found when removing ID from outstanding request set. 2026-07-15 14:39:27.236 | Real-time Intraday chart data file updates started for ESU5.CME 2026-07-15 14:39:27.236 | Intraday chart data file opened for ESU5.CME 2026-07-15 14:39:27.237 | Rithmic Direct - DTC | Using primary service for historical data for ESH6.CME 2026-07-15 14:39:27.237 | Historical data service client indicated that downloads are not enabled. Symbol: ESH6.CME. Data Type: Intraday data. 2026-07-15 14:39:27.237 | Historical data download ID 19 not found when removing ID from outstanding request set. 2026-07-15 14:39:27.237 | ESH6.CME [CBV] #1 | Performing continuous chart historical Daily data download for symbol ESH6.CME starting at last date in file. 2026-07-15 14:39:27.237 | Added historical Daily data request for ESH6.CME to the queue. 2026-07-15 14:39:27.237 | Triggering next historical data download in queue. 2026-07-15 14:39:27.265 | ESH6.CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:27.336 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-15 14:39:27.342 | ESH6.CME [CBV] 5000 Volume #2 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:27.385 | ESH6.CME #3 | Reloading chart. 2026-07-15 14:39:27.457 | ESH6.CME Renko 4t #5 | Reloading chart. 2026-07-15 14:39:27.506 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-15 14:39:27.547 | ESH6.CME [CBV] #8 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:27.598 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-15 14:39:27.610 | ESH6.CME [CBV] Renko 4t #9 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:27.936 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-15 14:39:27.942 | ESH6.CME [CBV] 100 Volume #12 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:27.968 | ESH6.CME 5000 Volume #13 | Reloading chart. 2026-07-15 14:39:28.002 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-15 14:39:28.008 | ESH6.CME [CBV] 5000 Volume #4 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:28.051 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-15 14:39:28.057 | ESH6.CME [CBV] Renko 8t #10 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:28.328 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-15 14:39:28.334 | ESH6.CME [CBV] Renko 2t #6 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:28.357 | ESH6.CME Renko 8t #7 | Reloading chart. 2026-07-15 14:39:28.385 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-15 14:39:28.391 | ESH6.CME [CBV] Renko 16t #11 | Waiting for historical downloads to complete with the IDs: 20, 2026-07-15 14:39:28.583 | HD Request # 9 | Downloading Historical Daily chart data for ESH6.CME. Starting date: 2026-03-18. Service: rithmic.trading 2026-07-15 14:39:28.736 | HD Request # 9 | Requesting historical Daily data for ESH26 starting at 2026-03-17. SC External HD service. 2026-07-15 14:39:28.880 | HD Request # 9 | Receiving historical Daily data for ESH6.CME starting at 2026-03-18. 2026-07-15 14:39:28.880 | HD Request # 9 | Writing historical Daily data to the file ESH6.CME.dly. 2026-07-15 14:39:28.882 | HD Request # 9 | Bytes received: 225 2026-07-15 14:39:28.882 | HD Request # 9 | Received 4 Daily data records from 2026-03-18 00:00:00 to 2026-03-20 00:00:00 (3.0 days) and wrote 3 records for ESH6.CME 2026-07-15 14:39:28.883 | HD Request # 9 | Completion time: 0s. 2026-07-15 14:39:28.883 | HD Request # 9 | Daily data download complete for ESH6.CME. Unique request ID: 20 2026-07-15 14:39:28.883 | Removing historical data download ID 20. 2026-07-15 14:39:28.883 | 2026-07-15 14:39:28.883 | No download requests in the queue to start downloads for. 2026-07-15 14:39:28.883 | ESH6.CME [CBV] Renko 16t #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:28.884 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-15 14:39:28.928 | ESH6.CME [CBV] 100 Volume #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:28.929 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-15 14:39:28.990 | ESH6.CME [CBV] #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:28.991 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-15 14:39:29.113 | ESH6.CME [CBV] 5000 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:29.113 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-15 14:39:29.116 | ESH6.CME [CBV] Renko 8t #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:29.117 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-15 14:39:29.120 | ESH6.CME [CBV] Renko 4t #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:29.121 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-15 14:39:29.225 | ESH6.CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:29.226 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-15 14:39:29.318 | ESH6.CME [CBV] Renko 2t #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:29.319 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-15 14:39:29.334 | ESH6.CME [CBV] 5000 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-07-15 14:39:29.334 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-15 14:39:29.381 | ESH6.CME [CBV] Renko 16t #11 | Reloading chart. 2026-07-15 14:39:29.429 | ESH6.CME [CBV] 100 Volume #12 | Reloading chart. 2026-07-15 14:39:29.856 | ESH6.CME [CBV] #8 | Reloading chart. 2026-07-15 14:39:29.935 | ESH6.CME [CBV] 5000 Volume #4 | Reloading chart. 2026-07-15 14:39:29.944 | ESH6.CME [CBV] Renko 4t #9 | Reloading chart. 2026-07-15 14:39:31.053 | ESH6.CME [CBV] Renko 8t #10 | Reloading chart. 2026-07-15 14:39:32.076 | ESH6.CME [CBV] #1 | Reloading chart. 2026-07-15 14:39:32.682 | ESH6.CME [CBV] Renko 2t #6 | Reloading chart. 2026-07-15 14:39:32.689 | ESH6.CME [CBV] 5000 Volume #2 | Reloading chart. 2026-07-15 14:39:37.760 | Loading market depth data. 2026-07-15 14:39:45.550 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-15 14:39:57.943 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-15 14:40:00.235 | ESH6.CME [CBV] 5000 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:40:00.846 | ESH6.CME [CBV] 5000 Volume #4 | Chart data loading complete. 2026-07-15 14:40:06.355 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-15 14:40:07.953 | ESH6.CME 5000 Volume #13 | Chart data loading complete. 2026-07-15 14:40:09.102 | ESH6.CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:40:09.108 | ESH6.CME #3 | Chart data loading complete. 2026-07-15 14:40:13.299 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-15 14:40:20.620 | ESH6.CME [CBV] 5000 Volume #2 | Chart data loading complete. 2026-07-15 14:40:20.802 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-15 14:40:20.916 | ESH6.CME [CBV] 100 Volume #12 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:40:21.363 | ESH6.CME [CBV] 100 Volume #12 | Chart data loading complete. 2026-07-15 14:40:28.758 | Loading market depth data. 2026-07-15 14:40:29.094 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-15 14:40:30.153 | Loading market depth data. | Number times message added: 1 2026-07-15 14:40:30.353 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. | Number times message added: 1 2026-07-15 14:40:37.451 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. | Number times message added: 2 2026-07-15 14:40:46.768 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. | Number times message added: 2 2026-07-15 14:40:55.144 | ESH6.CME Renko 4t #5 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:40:55.467 | ESH6.CME Renko 4t #5 | Chart data loading complete. 2026-07-15 14:40:56.866 | ESH6.CME [CBV] #1 | Chart data loading complete. 2026-07-15 14:40:58.128 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-15 14:40:58.129 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-15 14:40:58.631 | ESH6.CME [CBV] #8 | Chart data loading complete. 2026-07-15 14:40:58.725 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-15 14:40:58.726 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-15 14:40:59.349 | ESH6.CME Renko 8t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:40:59.403 | ESH6.CME Renko 8t #7 | Chart data loading complete. 2026-07-15 14:41:04.127 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. | Number times message added: 1 2026-07-15 14:41:04.419 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-15 14:41:04.419 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-15 14:41:10.036 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-15 14:41:12.269 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. | Number times message added: 1 2026-07-15 14:41:12.832 | Loading market depth data. 2026-07-15 14:41:13.185 | Loaded depth data records for ESH6.CME 2026-02-17 from 2026-02-17 15:59:59.045000 to 2026-02-17 17:59:59.959000. 2026-07-15 14:41:24.433 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. | Number times message added: 1 2026-07-15 14:41:26.045 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-15 14:41:30.608 | Loaded depth data records for ESH6.CME 2026-02-18 from 2026-02-17 18:00:00.000000 to 2026-02-18 17:59:59.932000. 2026-07-15 14:41:35.950 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-15 14:41:41.837 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. | Number times message added: 1 2026-07-15 14:41:44.994 | Loaded depth data records for ESH6.CME 2026-02-19 from 2026-02-18 18:00:00.000000 to 2026-02-19 17:59:59.990000. 2026-07-15 14:41:47.675 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-15 14:41:59.077 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-15 14:41:59.102 | ESH6.CME [CBV] Renko 8t #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:41:59.181 | ESH6.CME [CBV] Renko 8t #10 | Chart data loading complete. 2026-07-15 14:42:00.047 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-15 14:42:00.170 | ESH6.CME [CBV] Renko 2t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:42:00.797 | ESH6.CME [CBV] Renko 2t #6 | Chart data loading complete. 2026-07-15 14:42:01.070 | Loaded depth data records for ESH6.CME 2026-02-20 from 2026-02-19 18:00:00.000000 to 2026-02-20 17:41:13.826575. 2026-07-15 14:42:01.071 | Loaded depth data records for ESH6.CME 2026-02-21 from 2026-02-20 22:21:29.392353 to 2026-02-21 15:00:28.920530. 2026-07-15 14:42:01.224 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-15 14:42:01.277 | ESH6.CME [CBV] Renko 16t #11 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:42:01.289 | ESH6.CME [CBV] Renko 16t #11 | Chart data loading complete. 2026-07-15 14:42:02.561 | Loaded depth data records for ESH6.CME 2026-02-23 from 2026-02-23 08:46:05.677000 to 2026-02-23 17:59:59.959000. 2026-07-15 14:42:04.703 | Loaded depth data records for ESH6.CME 2026-02-24 from 2026-02-23 18:00:00.000000 to 2026-02-24 17:59:59.655000. 2026-07-15 14:42:06.042 | Loaded depth data records for ESH6.CME 2026-02-25 from 2026-02-24 18:00:00.000000 to 2026-02-25 17:59:59.711000. 2026-07-15 14:42:08.194 | Loaded depth data records for ESH6.CME 2026-02-26 from 2026-02-25 18:00:00.000000 to 2026-02-26 17:59:59.345000. 2026-07-15 14:42:10.591 | Loaded depth data records for ESH6.CME 2026-02-27 from 2026-02-26 18:00:00.000000 to 2026-02-27 15:59:59.001000. 2026-07-15 14:42:10.593 | ESH6.CME [CBV] Renko 4t #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-07-15 14:42:10.805 | ESH6.CME [CBV] Renko 4t #9 | Chart data loading complete. 2026-07-15 14:44:44.357 | ESU6.CME 1 Min #1 | Reloading chart. 2026-07-15 14:44:44.364 | ESU6.CME 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid 2026-07-15 14:44:44.365 | ESU6.CME 1 Min #1 | Chart data loading complete. 2026-07-15 14:44:44.852 | Rithmic Direct - DTC | Using primary service for historical data for ESU6.CME 2026-07-15 14:44:44.852 | Historical data service client indicated that downloads are not enabled. Symbol: ESU6.CME. Data Type: Intraday data. 2026-07-15 14:44:44.852 | Historical data download ID 21 not found when removing ID from outstanding request set. 2026-07-15 14:44:44.852 | Real-time Intraday chart data file updates started for ESU6.CME 2026-07-15 14:44:44.852 | Intraday chart data file opened for ESU6.CME 2026-07-15 14:45:02.421 | File >> Disconnect selected. 2026-07-15 14:45:02.421 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-07-15 14:45:02.422 | DTC Client socket (1) | CloseSocket call. 2026-07-15 14:45:02.422 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-07-15 14:45:02.422 | Rithmic Direct - DTC | Disconnected. 2026-07-15 14:45:02.427 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-07-15 14:45:02.427 | DTC Client socket (1) | Closed. 2026-07-15 14:45:10.117 | 2026-07-15 14:45:10.118 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-07-15 14:45:10.118 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-07-15 14:45:10.118 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-07-15 14:45:10.153 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-07-15 14:45:10.153 | DTC Client socket (1) | New receive buffer size: 0 2026-07-15 14:45:10.153 | DTC Client socket (1) | Connecting to IP: 208.97.247.100. 2026-07-15 14:45:10.155 | Rithmic Direct - DTC | Network connection to server complete. 2026-07-15 14:45:10.155 | Rithmic Direct - DTC | Starting socket receive thread. 2026-07-15 14:45:10.155 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-07-15 14:45:10.155 | Rithmic Direct - DTC | Sending logon request message. 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Received logon response. 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Server Name: . 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Successfully connected. 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Trading is supported. 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | OCO Orders supported. 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-07-15 14:45:10.178 | Rithmic Direct - DTC | Connection to server complete. 2026-07-15 14:45:10.179 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-07-15 14:45:10.179 | Using symbol data fast lookup vector 2026-07-15 14:45:10.180 | Rithmic Direct - DTC | Starting real-time market data updates for: F.US.EPU26. ID: 1 2026-07-15 14:45:10.180 | Rithmic Direct - DTC | Requesting security definition data for: F.US.EPU26. ID: 1 2026-07-15 14:45:10.180 | Rithmic Direct - DTC | Using primary service for historical data for F.US.EPU26 2026-07-15 14:45:10.180 | Historical data service client indicated that downloads are not enabled. Symbol: F.US.EPU26. Data Type: Intraday data. 2026-07-15 14:45:10.180 | Historical data download ID 22 not found when removing ID from outstanding request set. 2026-07-15 14:45:10.180 | Real-time Intraday chart data file updates started for F.US.EPU26 2026-07-15 14:45:10.180 | Intraday chart data file opened for F.US.EPU26 2026-07-15 14:45:10.195 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU6.CME. ID: 2 Service code: rithmic.trading 2026-07-15 14:45:10.195 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESU6.CME. 2026-07-15 14:45:10.195 | Rithmic Direct - DTC | Requesting security definition data for: ESU6.CME. ID: 2 2026-07-15 14:45:10.195 | Rithmic Direct - DTC | Using primary service for historical data for ESU6.CME 2026-07-15 14:45:10.195 | Historical data service client indicated that downloads are not enabled. Symbol: ESU6.CME. Data Type: Intraday data. 2026-07-15 14:45:10.195 | Historical data download ID 23 not found when removing ID from outstanding request set. 2026-07-15 14:45:10.195 | Real-time Intraday chart data file updates started for ESU6.CME 2026-07-15 14:45:10.195 | Intraday chart data file opened for ESU6.CME 2026-07-15 14:45:30.163 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Creating socket. Using TLS 1.2. 2026-07-15 14:45:30.163 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | New receive buffer size: 0 2026-07-15 14:45:30.163 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Connecting to IP: 216.66.0.130. 2026-07-15 14:45:30.298 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672 2026-07-15 14:45:30.299 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-07-15 14:45:30.552 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | CloseSocket call. 2026-07-15 14:45:30.553 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Shutdown started. Waiting for graceful close. 2026-07-15 14:45:30.571 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Socket gracefully closed by remote side. 2026-07-15 14:45:30.571 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (2) | Closed. |
| [2026-07-15 16:00:54] |
| John - SC Support - Posts: 48169 |
Your log shows you changing your service from Rithmic to CQG to Rithmic. Do you have accounts that use both Rithmic and CQG? The first item of note with regards to this is that you are not updating the symbols when you change services. Each service uses a different symbology, so when you change services you need to change the symbols. When you select OK on the "Data/Trade Service Settings" window after changing services, you are prompted to update the symbols. You should answer "Yes" to this. If you do not, or if you open a different chartbook later and you need to update the symbols, then you can select "Edit >> Translate Symbols to Current Service". Refer to the following: Edit Menu: Edit >> Translate Symbols To Current Service The next item is that if you are connecting to a CQG account, then you need to understand that Sierra Chart does not have support for data from CQG for the CME Group and EUREX. Therefore, you would have to get that data from our Denali Exchange Data Feed. You did have data setup in February 2026, but it had not renewed. If you need to get your data from us, then you can activate the exchanges for which you want real-time data for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges If you do setup the data from our Denali Exchange Data Feed, then this will probably resolve the issues with Rithmic as well. But, if you want to get the data from Rithmic, then the first thing you need to do is to ensure that all your charts are on the current front contract. Rithmic does not have data for previous contracts, and we see several references to charts for ESH26.CME. These all need to be changed to ESU26.CME. Also, make sure that you have the fields for the "Market Data" and "Historical Data" filled in on the "Data/Trade Service Settings" in order to get the data from Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
