Date/Time: Fri, 06 Nov 2026 12:56:03 +0000
Rithmic Direct-DTC connects successfully, but no market data in Quote Board , blank charts
View Count: 604
[2026-06-03 16:12:56]
User294896 - Posts: 3
I am using Sierra Chart v2915 with Rithmic Direct - DTC and a Lucid Trading account.
What I have verified:
R|Trader Pro receives live CME market data correctly.
Sierra Chart connects successfully.
Fresh Sierra Chart installation tested.
Correct Rithmic credentials entered.
Quote Board shows no Bid/Ask/Last and Volume remains 0.
NQM6 charts remain blank.
Relevant log messages:
Historical data service client indicated that downloads are not enabled. Symbol: NQM6.CME
Starting real-time market data updates for: NQM6.CME
Lucid Trading has checked the account and says all data feed requirements are being fulfilled on their end.
Can you identify why Sierra Chart is not receiving market data while R|Trader Pro receives live data correctly?
Thank you.
[2026-06-03 19:55:54]
To begin with, the interface between Sierra Chart and Rithmic has nothing to do with R-Trader. The interface is specific to Sierra Chart and is coded by and owned by Rithmic. So the fact that data works to R-Trader does not mean anything.
In "Global Settings >> Data/Trade Service Settings >> Main Settings" do you have the Username/Password entered for both the "Market Data" and "Historical Data" entries? These must be filled out with the same Rithmic account information in order to get the data from Rithmic.
If those are filled in and you are still having an issue, then get us your Message Log for one symbol for which you are having an issue, by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2026-06-04 12:43:44]
Weirldy I tried doing this yesterday and somehow the quote board was still 0. Happy that now it works.
Even though Lucid trading is saying that the Market Data and Historical Data don't need to be filled in.
Thanks a lot much appreciated!!
[2026-06-04 15:03:42]
If you want to get the data from Rithmic, then those fields need to be filled in.
If you were setup to get your data from our Denali Exchange Data Feed (which you are not), then you would keep those blank.
[2026-06-11 14:01:25]
Everything was going good, I didn't change anything since I had my problem.
That's the image I'm seeing after it was actually going good for a week, I find it really strange. It keeps disconnecting from the data feed and the contracts are 0 on the quoter board.
Let me know if I can do something about it.
[2026-06-11 14:58:16]
You are getting your data from Rithmic.
Keep in mind that you can not connect from multiple locations to a Rithmic account that you are logged into through Sierra Chart. So if you are connected to that account in the R-Trader software, then you will not be able to connect in Sierra Chart, although you should get a connection error message in this case.
Otherwise, there is nothing further we can do to help with data issues from Rithmic. Our recommendation is to change to use our Denali Exchange Data Feed instead. Refer to the following:
Rithmic Trading Platform Service: Rithmic Support Policy
