Date/Time: Tue, 13 Oct 2026 16:41:22 +0000
Lucid Prop firm Rithmic Data for Market profile
View Count: 2913
[2026-04-06 13:26:40]
SurfTrader - Posts: 88
I am trying to connect Lucid Rithmic on their eval to Sierra and all my charts on my chartbook are blank. It says 'historical intraday Data download skipped' after changing global trade setting to Lucids recommended settings and hitting edit>translate symbols to current service. What is the problem? Thanks
[2026-04-06 16:14:24]
John - SC Support - Posts: 48189
Please get us your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2026-04-06 16:46:40]
the message log remains blank when I do this. The only thing it says on the chart is 'historical intraday Data download skipped' and then chart remains blank when I do the above directions. Its showing I have data for US30, USoil, xau, but for ES and NQ It shows the above message of skipping historical download
Date Time Of Last Edit: 2026-04-06 17:02:25
[2026-04-06 19:38:44]
I noticed on the higher time frames it shows the chart loaded but the price is not moving. The lower time frame intraday chart will not load at all and gives the error message I stated above. Still nothing shows on the message log.
imagealgo.png / V - Attached On 2026-04-06 19:36:19 UTC - Size: 57.06 KB - 223 views
[2026-04-06 21:35:39]
Select "Global Settings >> Message Categories" and set all the items in there to "Yes".
Then check your Message Log and see if it is still blank. If it is, then check "Window >> Disable Visible Message Logging" - if there is a checkmark next to this, then select the option to remove the checkmark.
Then check your Message Log again - it should not be blank. If it is, then we would need for you to update to the latest release. Follow these instructions to update:
At this point, you should have information showing in your Message Log. Follow these instructions to get us the log:
[2026-04-06 22:29:43]
sorry about the wall of message log. I probably should have cleared it and then opened chartbook again or something like that?
[2026-04-07 13:27:28]
Tried closing and opening everything again today. Still giving me this long message log.
2026-04-07 09:18:37.205 | Trade activity files set size: 1461
2026-04-07 09:18:37.219 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-04-07 09:18:37.279 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2026-04-07 09:18:37.279 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2026-04-07 09:18:37.279 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89.
2026-04-07 09:18:37.348 | Created the DTC Protocol server.
2026-04-07 09:18:37.348 | DTC Protocol Server listening on port 11099. Address: 0.0.0.0
2026-04-07 09:18:37.348 | Reading Internal Order ID file.
2026-04-07 09:18:37.355 | Reading Trade Orders file.
2026-04-07 09:18:37.361 | Reading Trade Positions file.
2026-04-07 09:18:37.366 | Reading Trade Account Data files.
2026-04-07 09:18:37.374 | UDPListener (1724). Port 22904 | Listening on UDP port 22904.
2026-04-07 09:18:37.374 | Software version: 2813 64-bit
2026-04-07 09:18:37.374 | Primary Thread ID: 14888
2026-04-07 09:18:37.374 | Usage end date: 2026-06-09
2026-04-07 09:18:37.374 | Enabled for: Advanced Features 2.
2026-04-07 09:18:37.374 | Enabled for: Sierra Chart Historical Data Service.
2026-04-07 09:18:37.374 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-04-07 09:18:37.374 | Enabled for: Delayed Denali Exchange Data Feed.
2026-04-07 09:18:37.374 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-04-07 09:18:37.374 | Current selected Data/Trading service: Rithmic Direct - DTC
2026-04-07 09:18:37.374 | Custom symbol settings values: enabled
2026-04-07 09:18:37.374 | Chart Update Interval: 500
2026-04-07 09:18:37.374 | Intraday Data Storage Time Unit: 0
2026-04-07 09:18:37.374 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2026-04-07 09:18:37.374 | 2026-04-07 13:18:37 Local computer time in UTC
2026-04-07 09:18:37.374 | 2026-04-07 09:18:37 Local computer time in SC Time Zone
2026-04-07 09:18:37.374 | 2026-04-07 13:18:25 Server time in UTC
2026-04-07 09:18:37.374 | Local computer UTC time and Server UTC time difference: 0 seconds.
2026-04-07 09:18:37.374 | Program path: C:\SierraChart\
2026-04-07 09:18:37.374 | Data Files path: C:\SierraChart\Data\
2026-04-07 09:18:37.374 | OS Version Number: 10.0
2026-04-07 09:18:37.374 | Locale Setting: C
2026-04-07 09:18:37.374 | Crash reporter started: true
2026-04-07 09:18:37.391 | Created the DTC Protocol historical data server.
2026-04-07 09:18:37.392 | HD Server Manager | Listening on port 11098.
2026-04-07 09:18:37.392 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2026-04-07 09:18:37.393 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-04-07 09:18:37.437 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-04-07 09:18:37.437 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-04-07 09:18:37.539 | Received 5 login tokens.
2026-04-07 09:18:37.661 | Symbol settings MD5 received. Request ID: 1.
2026-04-07 09:18:37.661 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 2.
2026-04-07 09:18:37.799 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1
2026-04-07 09:18:37.801 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115600
2026-04-07 09:18:37.805 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-04-07 09:18:37.805 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2026-04-07 09:18:37.805 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-07 09:18:37.805 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2026-04-07 09:18:38.077 | Symbol settings received. Request ID: 2.
2026-04-07 09:18:39.892 | Requested user files to download.
2026-04-07 09:18:40.201 | File to download: Sierra4.config.new. Action: 0
2026-04-07 09:18:40.259 | File to download: JIM DALTON (2).cht. Action: 0 | Number times message added: 6
2026-04-07 09:18:40.259 | File to download: Sierra4.config.new. Action: 0
2026-04-07 09:18:40.259 | File to download: ES DTS.Cht. Action: 0
2026-04-07 09:18:40.267 | File to download: JIM DALTON (2).cht. Action: 0
2026-04-07 09:18:40.268 | User files to download complete
2026-04-07 09:18:41.891 |
2026-04-07 09:18:41.891 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated
2026-04-07 09:18:41.891 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569
2026-04-07 09:18:41.892 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569
2026-04-07 09:18:41.953 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-04-07 09:18:41.953 | DTC Client socket (1) | New receive buffer size: 0
2026-04-07 09:18:41.953 | DTC Client socket (1) | Connecting to IP: 208.97.247.101.
2026-04-07 09:18:41.981 | Rithmic Direct - DTC | Network connection to server complete.
2026-04-07 09:18:41.981 | Rithmic Direct - DTC | Starting socket receive thread.
2026-04-07 09:18:41.981 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-04-07 09:18:41.981 | Rithmic Direct - DTC | Sending logon request message.
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Received logon response.
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Server Name: .
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Successfully connected.
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Trading is supported.
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | OCO Orders supported.
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-04-07 09:18:42.080 | Rithmic Direct - DTC | Connection to server complete.
2026-04-07 09:18:42.081 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-04-07 09:18:45.128 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2026-04-07 09:18:45.965 | XAUUSD 1 Min #1 | Reloading chart.
2026-04-07 09:18:45.990 | XAUUSD Daily #2 | Reloading chart.
2026-04-07 09:18:46.629 | US30 1 Min #3 | Reloading chart.
2026-04-07 09:18:46.906 | USOil 1 Min #4 | Reloading chart.
2026-04-07 09:18:47.050 | ESZ25_FUT_CME 1 Min #5 | Reloading chart.
2026-04-07 09:18:47.069 | $INX Daily #6 | Reloading chart.
2026-04-07 09:18:47.094 | EURUSD Daily #7 | Reloading chart.
2026-04-07 09:18:47.869 | EURUSD 5 Min #8 | Reloading chart.
2026-04-07 09:18:47.909 | ESZ25_FUT_CME #9 | Reloading chart.
2026-04-07 09:18:48.182 | ESZ25_FUT_CME 1 Min #10 | Reloading chart.
2026-04-07 09:18:48.199 | XAUUSD Daily #2 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2026-04-07 09:18:48.199 | XAUUSD Daily #2 | Chart data loading complete.
2026-04-07 09:18:48.241 | EURUSD Daily #7 | Chart data loading complete.
2026-04-07 09:18:48.251 | $INX Daily #6 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2026-04-07 09:18:48.251 | $INX Daily #6 | Chart data loading complete.
2026-04-07 09:18:48.342 | Using Bid/Ask average for last trade price for XAUUSD
2026-04-07 09:18:48.342 | Using symbol data fast lookup vector
2026-04-07 09:18:48.342 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm
2026-04-07 09:18:48.343 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2026-04-07 09:18:48.343 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1
2026-04-07 09:18:48.343 | Starting DelayedDownloadMonitoringTimer
2026-04-07 09:18:48.343 | Starting HDTimeoutTimer
2026-04-07 09:18:48.343 | Added historical Intraday data request for XAUUSD to the queue.
2026-04-07 09:18:48.343 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'.
2026-04-07 09:18:48.344 | Triggering next historical data download in queue.
2026-04-07 09:18:48.345 | Delaying start of download for XAUUSD.
2026-04-07 09:18:48.346 | Added historical Daily data request for XAUUSD to the queue.
2026-04-07 09:18:48.346 | Triggering next historical data download in queue.
2026-04-07 09:18:48.350 | Using Bid/Ask average for last trade price for US30
2026-04-07 09:18:48.350 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 2 Service code: fxcm
2026-04-07 09:18:48.350 | SC Data with Depth | Requesting security definition data for: US30. ID: 2
2026-04-07 09:18:48.350 | Added historical Intraday data request for US30 to the queue.
2026-04-07 09:18:48.350 | Intraday data recording state for symbol US30 is set to download 'Pending'.
2026-04-07 09:18:48.350 | Triggering next historical data download in queue.
2026-04-07 09:18:48.352 | Using Bid/Ask average for last trade price for USOil
2026-04-07 09:18:48.353 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 3 Service code: fxcm
2026-04-07 09:18:48.353 | SC Data with Depth | Requesting security definition data for: USOil. ID: 3
2026-04-07 09:18:48.353 | Added historical Intraday data request for USOil to the queue.
2026-04-07 09:18:48.353 | Intraday data recording state for symbol USOil is set to download 'Pending'.
2026-04-07 09:18:48.353 | Triggering next historical data download in queue.
2026-04-07 09:18:48.355 | Rithmic Direct - DTC | Starting real-time market data updates for: ESZ25_FUT_CME. ID: 4
2026-04-07 09:18:48.355 | Rithmic Direct - DTC | Requesting security definition data for: ESZ25_FUT_CME. ID: 4
2026-04-07 09:18:48.355 | Rithmic Direct - DTC | Using primary service for historical data for ESZ25_FUT_CME
2026-04-07 09:18:48.355 | Starting DelayedDownloadMonitoringTimer
2026-04-07 09:18:48.355 | Starting HDTimeoutTimer
2026-04-07 09:18:48.355 | Historical data service client indicated that downloads are not enabled. Symbol: ESZ25_FUT_CME. Data Type: Intraday data.
2026-04-07 09:18:48.355 | Historical data download ID 5 not found when removing ID from outstanding request set.
2026-04-07 09:18:48.355 | Real-time Intraday chart data file updates started for ESZ25_FUT_CME
2026-04-07 09:18:48.355 | Intraday chart data file opened for ESZ25_FUT_CME
2026-04-07 09:18:48.358 | Starting DelayedDownloadMonitoringTimer
2026-04-07 09:18:48.358 | Starting HDTimeoutTimer
2026-04-07 09:18:48.358 | Added historical Daily data request for $INX to the queue.
2026-04-07 09:18:48.358 | Triggering next historical data download in queue.
2026-04-07 09:18:48.358 | Rithmic Direct - DTC | Starting real-time market data updates for: $INX. ID: 5
2026-04-07 09:18:48.358 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: $INX.
2026-04-07 09:18:48.358 | Rithmic Direct - DTC | Requesting security definition data for: $INX. ID: 5
2026-04-07 09:18:48.363 | HD Request # 1 | Downloading Historical Daily chart data for $INX. Starting date: 2026-04-01. Service: rithmic_v2.trading
2026-04-07 09:18:48.368 | Added historical Daily data request for EURUSD to the queue.
2026-04-07 09:18:48.368 | Triggering next historical data download in queue.
2026-04-07 09:18:48.368 | Using Bid/Ask average for last trade price for EURUSD
2026-04-07 09:18:48.368 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm
2026-04-07 09:18:48.368 | DTC Client socket (3) | Creating socket.
2026-04-07 09:18:48.368 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 6
2026-04-07 09:18:48.368 | DTC Client socket (3) | New receive buffer size: 0
2026-04-07 09:18:48.368 | DTC Client socket (3) | Connecting to IP: 69.39.70.241.
2026-04-07 09:18:48.373 | Added historical Intraday data request for EURUSD to the queue.
2026-04-07 09:18:48.373 | Intraday data recording state for symbol EURUSD is set to download 'Pending'.
2026-04-07 09:18:48.373 | Triggering next historical data download in queue.
2026-04-07 09:18:48.437 | SC Data with Depth | Network connection to server complete.
2026-04-07 09:18:48.437 | SC Data with Depth | Starting socket receive thread.
2026-04-07 09:18:48.438 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2026-04-07 09:18:48.556 | SC Data with Depth | Setting DTC encoding to Binary VLS
2026-04-07 09:18:48.556 | SC Data with Depth | Sending logon request message.
2026-04-07 09:18:48.640 | HD Request # 1 | Requesting historical Daily data for $INX starting at 2026-03-31. SC External HD service.
2026-04-07 09:18:48.710 | SC Data with Depth | Received logon response.
2026-04-07 09:18:48.710 | SC Data with Depth | Server Name: SC Realtime Server.
2026-04-07 09:18:48.710 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2026-04-07 09:18:48.710 | SC Data with Depth | Successfully connected.
2026-04-07 09:18:48.710 | SC Data with Depth | Trading is not supported.
2026-04-07 09:18:48.710 | SC Data with Depth | MarketDepthIsSupported: 1
2026-04-07 09:18:48.710 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD
2026-04-07 09:18:48.710 | SC Data with Depth | Restarting real-time data updates for symbol: US30
2026-04-07 09:18:48.710 | SC Data with Depth | Restarting real-time data updates for symbol: USOil
2026-04-07 09:18:48.710 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD
2026-04-07 09:18:48.790 | HD Request # 1 | Receiving historical Daily data for $INX starting at 2026-04-01.
2026-04-07 09:18:48.791 | HD Request # 1 | Writing historical Daily data to the file $INX.dly.
2026-04-07 09:18:48.894 | HD Request # 1 | Bytes received: 236
2026-04-07 09:18:48.894 | HD Request # 1 | Received 4 Daily data records from 2026-04-01 00:00:00 to 2026-04-06 00:00:00 (6.0 days) and wrote 3 records for $INX
2026-04-07 09:18:48.894 | HD Request # 1 | Completion time: 0s.
2026-04-07 09:18:48.894 | HD Request # 1 | Daily data download complete for $INX. Unique request ID: 6
2026-04-07 09:18:48.894 | Removing historical data download ID 6.
2026-04-07 09:18:48.894 | No download requests in the queue to start downloads for.
2026-04-07 09:18:48.897 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18
2026-04-07 09:18:48.897 | SC Data with Depth | Received security definition for symbol EURUSD
2026-04-07 09:18:48.897 | SC Data with Depth | Setting external service identifier for symbol US30 to 58
2026-04-07 09:18:48.897 | SC Data with Depth | Received security definition for symbol US30
2026-04-07 09:18:48.897 | SC Data with Depth | Setting external service identifier for symbol USOil to 60
2026-04-07 09:18:48.897 | SC Data with Depth | Received security definition for symbol USOil
2026-04-07 09:18:48.897 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62
2026-04-07 09:18:48.897 | SC Data with Depth | Received security definition for symbol XAUUSD
2026-04-07 09:18:49.099 | $INX Daily #6 | Reloading chart.
2026-04-07 09:18:49.252 | $INX Daily #6 | Chart data loading complete.
2026-04-07 09:18:49.361 | USOil[M] 1 Min #4 | Chart data loading complete.
2026-04-07 09:18:50.188 | EURUSD[M] 5 Min #8 | Chart data loading complete.
2026-04-07 09:18:51.333 | ESZ25_FUT_CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-07 09:18:51.338 | ESZ25_FUT_CME 1 Min #10 | Chart data loading complete.
2026-04-07 09:18:51.517 | ESZ25_FUT_CME #9 | Chart data loading complete.
2026-04-07 09:18:52.514 | US30[M] 1 Min #3 | Chart data loading complete.
2026-04-07 09:18:53.340 | HD Request # 2 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm
2026-04-07 09:18:53.340 | HD Request # 2 | Download start date-time: 2026-04-06 18:23:58.000000. File last date-time: 2026-04-06 18:23:58.273000
2026-04-07 09:18:53.340 | HD Request # 2 | Using server: ds12.sierracharts.com port 10149
2026-04-07 09:18:53.340 | Socket (2) | Creating socket.
2026-04-07 09:18:53.340 | Socket (2) | New receive buffer size: 0
2026-04-07 09:18:53.340 | Socket (2) | Connecting to IP: 69.39.70.241.
2026-04-07 09:18:53.457 | HD Request # 2 | Setting DTC encoding to Binary VLS
2026-04-07 09:18:53.457 | HD Request # 2 | Sending historical data logon request message.
2026-04-07 09:18:53.534 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-04-06 18:23:58. Record interval: 0. Symbol: XAUUSD
2026-04-07 09:18:53.585 | HD Request # 2 | Decompressing data.
2026-04-07 09:18:53.721 | HD Request # 2 | Receiving Intraday data for XAUUSD starting at 2026-04-06 18:23:58.052000
2026-04-07 09:18:53.988 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-04-06 18:23:58.972000.
2026-04-07 09:18:54.795 | ESZ25_FUT_CME 1 Min #5 | Chart data loading complete.
2026-04-07 09:18:56.671 | Socket (2) | CloseSocket call.
2026-04-07 09:18:56.671 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-04-07 09:18:56.673 | Historical data download thread signaled to stop.
2026-04-07 09:18:56.692 | HD Request # 2 | Received 677731 Intraday data records from 2026-04-06 18:23:58.052000 to 2026-04-07 09:18:54.662000 (14.9 hours. Delay: 2.0 seconds) and wrote 677722 records for XAUUSD
2026-04-07 09:18:56.702 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-04-07 13:18:54.662000
2026-04-07 09:18:56.702 | Added 59 Time and Sales records to Intraday data file for XAUUSD after download.
2026-04-07 09:18:56.703 | HD Request # 2 | Completion time: 3s.
2026-04-07 09:18:56.703 | HD Request # 2 | Intraday data download complete for XAUUSD. Unique request ID: 1
2026-04-07 09:18:56.703 | Removing historical data download ID 1.
2026-04-07 09:18:56.703 | Real-time Intraday chart data file updates started for XAUUSD
2026-04-07 09:18:56.703 | Intraday chart data file opened for XAUUSD
2026-04-07 09:18:56.703 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2026-04-07 09:18:56.703 | Triggering next historical data download in queue.
2026-04-07 09:18:56.705 | HD Request # 3 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2026-04-02. Service: fxcm
2026-04-07 09:18:56.705 | HD Request # 3 | Using server: ds4.sierracharts.com port 10150
2026-04-07 09:18:56.721 | Socket (4) | Creating socket.
2026-04-07 09:18:56.721 | Socket (4) | New receive buffer size: 0
2026-04-07 09:18:56.721 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-04-07 09:18:56.726 | Socket (2) | Socket gracefully closed by remote side.
2026-04-07 09:18:56.726 | Socket (2) | Closed.
2026-04-07 09:18:56.810 | HD Request # 3 | Setting DTC encoding to Binary VLS
2026-04-07 09:18:56.810 | HD Request # 3 | Sending historical data logon request message.
2026-04-07 09:18:56.871 | HD Request # 3 | Requesting historical Daily data starting at 2026-04-02.
2026-04-07 09:18:56.906 | HD Request # 3 | Decompressing data.
2026-04-07 09:18:56.969 | HD Request # 3 | Receiving historical Daily data for XAUUSD starting at 2026-04-02.
2026-04-07 09:18:56.970 | HD Request # 3 | Writing historical Daily data to the file XAUUSD.dly.
2026-04-07 09:18:57.010 | Socket (4) | CloseSocket call.
2026-04-07 09:18:57.010 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-04-07 09:18:57.010 | Historical data download thread signaled to stop.
2026-04-07 09:18:57.010 | HD Request # 3 | Received 4 Daily data records from 2026-04-02 00:00:00 to 2026-04-07 00:00:00 (6.0 days) and wrote 4 records for XAUUSD
2026-04-07 09:18:57.010 | HD Request # 3 | Completion time: 1s.
2026-04-07 09:18:57.010 | HD Request # 3 | Daily data download complete for XAUUSD. Unique request ID: 2
2026-04-07 09:18:57.010 | Removing historical data download ID 2.
2026-04-07 09:18:57.010 | Triggering next historical data download in queue.
2026-04-07 09:18:57.010 | HD Request # 4 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm
2026-04-07 09:18:57.010 | HD Request # 4 | Download start date-time: 2026-04-06 18:23:58.000000. File last date-time: 2026-04-06 18:23:58.290000
2026-04-07 09:18:57.010 | HD Request # 4 | Using server: ds12.sierracharts.com port 10149
2026-04-07 09:18:57.011 | Socket (2) | Creating socket.
2026-04-07 09:18:57.011 | Socket (2) | New receive buffer size: 0
2026-04-07 09:18:57.011 | Socket (2) | Connecting to IP: 69.39.70.241.
2026-04-07 09:18:57.044 | Socket (4) | Socket gracefully closed by remote side.
2026-04-07 09:18:57.044 | Socket (4) | Closed.
2026-04-07 09:18:57.111 | XAUUSD[M] Daily #2 | Reloading chart.
2026-04-07 09:18:57.134 | HD Request # 4 | Setting DTC encoding to Binary VLS
2026-04-07 09:18:57.134 | HD Request # 4 | Sending historical data logon request message.
2026-04-07 09:18:57.164 | XAUUSD[M] Daily #2 | Chart data loading complete.
2026-04-07 09:18:57.187 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-04-06 18:23:58. Record interval: 0. Symbol: US30
2026-04-07 09:18:57.248 | HD Request # 4 | Decompressing data.
2026-04-07 09:18:57.390 | HD Request # 4 | Receiving Intraday data for US30 starting at 2026-04-06 18:23:58.017000
2026-04-07 09:18:57.450 | Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 7028
2026-04-07 09:18:57.528 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-04-06 18:23:58.585000.
2026-04-07 09:18:57.907 | XAUUSD[M] 1 Min #1 | Chart data loading complete.
2026-04-07 09:18:58.345 | Socket (2) | CloseSocket call.
2026-04-07 09:18:58.345 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-04-07 09:18:58.345 | Historical data download thread signaled to stop.
2026-04-07 09:18:58.345 | HD Request # 4 | Received 291193 Intraday data records from 2026-04-06 18:23:58.017000 to 2026-04-07 09:18:54.456000 (14.9 hours. Delay: 3.9 seconds) and wrote 291177 records for US30
2026-04-07 09:18:58.357 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-04-07 13:18:54.456000
2026-04-07 09:18:58.357 | Added 57 Time and Sales records to Intraday data file for US30 after download.
2026-04-07 09:18:58.357 | HD Request # 4 | Completion time: 1s.
2026-04-07 09:18:58.357 | HD Request # 4 | Intraday data download complete for US30. Unique request ID: 3
2026-04-07 09:18:58.357 | Removing historical data download ID 3.
2026-04-07 09:18:58.357 | Real-time Intraday chart data file updates started for US30
2026-04-07 09:18:58.357 | Intraday chart data file opened for US30
2026-04-07 09:18:58.357 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2026-04-07 09:18:58.357 | Triggering next historical data download in queue.
2026-04-07 09:18:58.357 | HD Request # 5 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm
2026-04-07 09:18:58.357 | HD Request # 5 | Download start date-time: 2026-04-06 18:23:56.000000. File last date-time: 2026-04-06 18:23:56.109000
2026-04-07 09:18:58.357 | HD Request # 5 | Using server: ds4.sierracharts.com port 10150
2026-04-07 09:18:58.357 | Socket (4) | Creating socket.
2026-04-07 09:18:58.358 | Socket (4) | New receive buffer size: 0
2026-04-07 09:18:58.358 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-04-07 09:18:58.402 | Socket (2) | Socket gracefully closed by remote side.
2026-04-07 09:18:58.403 | Socket (2) | Closed.
2026-04-07 09:18:58.442 | HD Request # 5 | Setting DTC encoding to Binary VLS
2026-04-07 09:18:58.442 | HD Request # 5 | Sending historical data logon request message.
2026-04-07 09:18:58.477 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-04-06 18:23:56. Record interval: 0. Symbol: USOil
2026-04-07 09:18:58.514 | HD Request # 5 | Decompressing data.
2026-04-07 09:18:58.657 | HD Request # 5 | Receiving Intraday data for USOil starting at 2026-04-06 18:23:56.061000
2026-04-07 09:18:58.803 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-04-06 18:23:58.479000.
2026-04-07 09:18:59.209 | Socket (4) | CloseSocket call.
2026-04-07 09:18:59.209 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-04-07 09:18:59.209 | Historical data download thread signaled to stop.
2026-04-07 09:18:59.209 | HD Request # 5 | Received 145542 Intraday data records from 2026-04-06 18:23:56.061000 to 2026-04-07 09:18:57.612000 (14.9 hours. Delay: 1.6 seconds) and wrote 145538 records for USOil
2026-04-07 09:18:59.221 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-04-07 13:18:57.612000
2026-04-07 09:18:59.221 | Added 3 Time and Sales records to Intraday data file for USOil after download.
2026-04-07 09:18:59.221 | HD Request # 5 | Completion time: 1s.
2026-04-07 09:18:59.221 | HD Request # 5 | Intraday data download complete for USOil. Unique request ID: 4
2026-04-07 09:18:59.221 | Removing historical data download ID 4.
2026-04-07 09:18:59.221 | Real-time Intraday chart data file updates started for USOil
2026-04-07 09:18:59.221 | Intraday chart data file opened for USOil
2026-04-07 09:18:59.221 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2026-04-07 09:18:59.221 | Triggering next historical data download in queue.
2026-04-07 09:18:59.222 | HD Request # 6 | Downloading Historical Daily chart data for EURUSD. Starting date: 2026-04-03. Service: fxcm
2026-04-07 09:18:59.223 | HD Request # 6 | Using server: ds12.sierracharts.com port 10149
2026-04-07 09:18:59.223 | Socket (2) | Creating socket.
2026-04-07 09:18:59.223 | Socket (2) | New receive buffer size: 0
2026-04-07 09:18:59.223 | Socket (2) | Connecting to IP: 69.39.70.241.
2026-04-07 09:18:59.250 | Socket (4) | Socket gracefully closed by remote side.
2026-04-07 09:18:59.250 | Socket (4) | Closed.
2026-04-07 09:18:59.345 | HD Request # 6 | Setting DTC encoding to Binary VLS
2026-04-07 09:18:59.345 | HD Request # 6 | Sending historical data logon request message.
2026-04-07 09:18:59.400 | HD Request # 6 | Requesting historical Daily data starting at 2026-04-03.
2026-04-07 09:18:59.472 | HD Request # 6 | Decompressing data.
2026-04-07 09:18:59.487 | HD Request # 6 | Receiving historical Daily data for EURUSD starting at 2026-04-03.
2026-04-07 09:18:59.487 | HD Request # 6 | Writing historical Daily data to the file EURUSD.dly.
2026-04-07 09:18:59.565 | Socket (2) | CloseSocket call.
2026-04-07 09:18:59.566 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-04-07 09:18:59.566 | Historical data download thread signaled to stop.
2026-04-07 09:18:59.566 | HD Request # 6 | Received 3 Daily data records from 2026-04-03 00:00:00 to 2026-04-07 00:00:00 (5.0 days) and wrote 3 records for EURUSD
2026-04-07 09:18:59.566 | HD Request # 6 | Completion time: 0s.
2026-04-07 09:18:59.566 | HD Request # 6 | Daily data download complete for EURUSD. Unique request ID: 7
2026-04-07 09:18:59.566 | Removing historical data download ID 7.
2026-04-07 09:18:59.566 | Triggering next historical data download in queue.
2026-04-07 09:18:59.566 | HD Request # 7 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm
2026-04-07 09:18:59.566 | HD Request # 7 | Download start date-time: 2026-04-06 18:23:58.000000. File last date-time: 2026-04-06 18:23:58.317000
2026-04-07 09:18:59.566 | HD Request # 7 | Using server: ds4.sierracharts.com port 10150
2026-04-07 09:18:59.566 | Socket (4) | Creating socket.
2026-04-07 09:18:59.566 | Socket (4) | New receive buffer size: 0
2026-04-07 09:18:59.566 | Socket (4) | Connecting to IP: 64.152.155.113.
2026-04-07 09:18:59.620 | Socket (2) | Socket gracefully closed by remote side.
2026-04-07 09:18:59.620 | Socket (2) | Closed.
2026-04-07 09:18:59.684 | HD Request # 7 | Setting DTC encoding to Binary VLS
2026-04-07 09:18:59.684 | HD Request # 7 | Sending historical data logon request message.
2026-04-07 09:18:59.702 | EURUSD[M] Daily #7 | Reloading chart.
2026-04-07 09:18:59.725 | HD Request # 7 | Requesting Intraday data. Start date-time: 2026-04-06 18:23:58. Record interval: 0. Symbol: EURUSD
2026-04-07 09:18:59.759 | HD Request # 7 | Decompressing data.
2026-04-07 09:18:59.812 | EURUSD[M] Daily #7 | Chart data loading complete.
2026-04-07 09:18:59.860 | HD Request # 7 | Receiving Intraday data for EURUSD starting at 2026-04-06 18:23:58.053000
2026-04-07 09:18:59.995 | HD Request # 7 | Timestamp of first Intraday data file record written: 2026-04-06 18:23:58.499000.
2026-04-07 09:19:00.357 | Socket (4) | CloseSocket call.
2026-04-07 09:19:00.357 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-04-07 09:19:00.357 | Historical data download thread signaled to stop.
2026-04-07 09:19:00.358 | HD Request # 7 | Received 125472 Intraday data records from 2026-04-06 18:23:58.053000 to 2026-04-07 09:18:58.677000 (14.9 hours. Delay: 1.7 seconds) and wrote 125469 records for EURUSD
2026-04-07 09:19:00.385 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2026-04-07 13:18:58.677000
2026-04-07 09:19:00.385 | HD Request # 7 | Completion time: 1s.
2026-04-07 09:19:00.385 | HD Request # 7 | Intraday data download complete for EURUSD. Unique request ID: 8
2026-04-07 09:19:00.385 | Removing historical data download ID 8.
2026-04-07 09:19:00.385 | Real-time Intraday chart data file updates started for EURUSD
2026-04-07 09:19:00.385 | Intraday chart data file opened for EURUSD
2026-04-07 09:19:00.385 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2026-04-07 09:19:00.385 | No download requests in the queue to start downloads for.
2026-04-07 09:19:00.396 | Socket (4) | Socket gracefully closed by remote side.
2026-04-07 09:19:00.396 | Socket (4) | Closed.
2026-04-07 09:19:01.887 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2.
2026-04-07 09:19:01.888 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0
2026-04-07 09:19:01.888 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 38.79.0.89.
2026-04-07 09:19:02.354 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | Number times message added: 1
2026-04-07 09:19:02.355 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115600
2026-04-07 09:19:02.355 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-04-07 09:19:02.356 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call.
2026-04-07 09:19:02.356 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-04-07 09:19:02.356 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed.
2026-04-07 09:19:02.528 | Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 7028
2026-04-07 09:19:02.529 | Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 7028
2026-04-07 09:19:02.530 | Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 7028
2026-04-07 09:19:06.193 | ESU6.CME #1 | Reloading chart.
2026-04-07 09:19:06.207 | SIK6.COMEX #4 | Reloading chart.
2026-04-07 09:19:06.218 | GC-202606-COMEX #5 | Reloading chart.
2026-04-07 09:19:06.232 | ESH6.CME [CB] #16 | Reloading chart.
2026-04-07 09:19:06.250 | Rithmic Direct - DTC | Using primary service for historical data for ESM5.CME
2026-04-07 09:19:06.250 | Historical data service client indicated that downloads are not enabled. Symbol: ESM5.CME. Data Type: Intraday data.
2026-04-07 09:19:06.250 | Historical data download ID 9 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.250 | Real-time Intraday chart data file updates started for ESM5.CME
2026-04-07 09:19:06.250 | Intraday chart data file opened for ESM5.CME
2026-04-07 09:19:06.266 | Rithmic Direct - DTC | Using primary service for historical data for ESU5.CME
2026-04-07 09:19:06.266 | Historical data service client indicated that downloads are not enabled. Symbol: ESU5.CME. Data Type: Intraday data.
2026-04-07 09:19:06.266 | Historical data download ID 10 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.266 | Real-time Intraday chart data file updates started for ESU5.CME
2026-04-07 09:19:06.266 | Intraday chart data file opened for ESU5.CME
2026-04-07 09:19:06.280 | Rithmic Direct - DTC | Using primary service for historical data for ESZ5.CME
2026-04-07 09:19:06.280 | Historical data service client indicated that downloads are not enabled. Symbol: ESZ5.CME. Data Type: Intraday data.
2026-04-07 09:19:06.280 | Historical data download ID 11 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.280 | Real-time Intraday chart data file updates started for ESZ5.CME
2026-04-07 09:19:06.280 | Intraday chart data file opened for ESZ5.CME
2026-04-07 09:19:06.293 | Rithmic Direct - DTC | Using primary service for historical data for ESH6.CME
2026-04-07 09:19:06.293 | Historical data service client indicated that downloads are not enabled. Symbol: ESH6.CME. Data Type: Intraday data.
2026-04-07 09:19:06.293 | Historical data download ID 12 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.293 | Real-time Intraday chart data file updates started for ESH6.CME
2026-04-07 09:19:06.293 | Intraday chart data file opened for ESH6.CME
2026-04-07 09:19:06.325 | ESH6.CME [CB] #16 | Performing continuous chart historical Daily data download for symbol ESH6.CME starting at last date in file.
2026-04-07 09:19:06.325 | Added historical Daily data request for ESH6.CME to the queue.
2026-04-07 09:19:06.325 | Triggering next historical data download in queue.
2026-04-07 09:19:06.422 | ESH6.CME [CB] #16 | Waiting for historical downloads to complete with the IDs: 13,
2026-04-07 09:19:06.449 | ESM6.CME #10 | Reloading chart.
2026-04-07 09:19:06.472 | NQM6.CME #6 | Reloading chart.
2026-04-07 09:19:06.486 | NQH6.CME [CB] #9 | Reloading chart.
2026-04-07 09:19:06.503 | Rithmic Direct - DTC | Using primary service for historical data for NQM5.CME
2026-04-07 09:19:06.503 | Historical data service client indicated that downloads are not enabled. Symbol: NQM5.CME. Data Type: Intraday data.
2026-04-07 09:19:06.503 | Historical data download ID 14 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.503 | Real-time Intraday chart data file updates started for NQM5.CME
2026-04-07 09:19:06.503 | Intraday chart data file opened for NQM5.CME
2026-04-07 09:19:06.521 | Rithmic Direct - DTC | Using primary service for historical data for NQU5.CME
2026-04-07 09:19:06.521 | Historical data service client indicated that downloads are not enabled. Symbol: NQU5.CME. Data Type: Intraday data.
2026-04-07 09:19:06.521 | Historical data download ID 15 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.521 | Real-time Intraday chart data file updates started for NQU5.CME
2026-04-07 09:19:06.521 | Intraday chart data file opened for NQU5.CME
2026-04-07 09:19:06.537 | Rithmic Direct - DTC | Using primary service for historical data for NQZ5.CME
2026-04-07 09:19:06.537 | Historical data service client indicated that downloads are not enabled. Symbol: NQZ5.CME. Data Type: Intraday data.
2026-04-07 09:19:06.537 | Historical data download ID 16 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.537 | Real-time Intraday chart data file updates started for NQZ5.CME
2026-04-07 09:19:06.537 | Intraday chart data file opened for NQZ5.CME
2026-04-07 09:19:06.551 | Rithmic Direct - DTC | Using primary service for historical data for NQH6.CME
2026-04-07 09:19:06.551 | Historical data service client indicated that downloads are not enabled. Symbol: NQH6.CME. Data Type: Intraday data.
2026-04-07 09:19:06.551 | Historical data download ID 17 not found when removing ID from outstanding request set.
2026-04-07 09:19:06.551 | Real-time Intraday chart data file updates started for NQH6.CME
2026-04-07 09:19:06.551 | Intraday chart data file opened for NQH6.CME
2026-04-07 09:19:06.563 | NQH6.CME [CB] #9 | Performing continuous chart historical Daily data download for symbol NQH6.CME starting at last date in file.
2026-04-07 09:19:06.563 | Added historical Daily data request for NQH6.CME to the queue.
2026-04-07 09:19:06.665 | NQH6.CME [CB] #9 | Waiting for historical downloads to complete with the IDs: 18,
2026-04-07 09:19:06.689 | RTYM6.CME #11 | Reloading chart.
2026-04-07 09:19:06.742 | ESH6.CME Rev. 5t #14 | Reloading chart.
2026-04-07 09:19:06.747 | Loading market depth data.
2026-04-07 09:19:06.777 | NQM6.CME #3 | Reloading chart.
2026-04-07 09:19:06.808 | ESH6.CME 30 Min #26 | Reloading chart.
2026-04-07 09:19:06.821 | Searching for files containing JoboPinch returned empty result.
2026-04-07 09:19:06.821 | Error loading: C:\SierraChart\Data\JoboPinch.dll. File not found or may be missing SCDLLName line.
2026-04-07 09:19:06.824 | Searching for files containing VolumeTickerComparison returned empty result.
2026-04-07 09:19:06.824 | Error loading: C:\SierraChart\Data\VolumeTickerComparison.dll. File not found or may be missing SCDLLName line.
2026-04-07 09:19:07.041 | MGCM4.COMEX [CB] 5000 Trades #8 | Reloading chart.
2026-04-07 09:19:07.041 | Rithmic Direct - DTC | Using primary service for historical data for MGCM4.COMEX
2026-04-07 09:19:07.041 | Historical data service client indicated that downloads are not enabled. Symbol: MGCM4.COMEX. Data Type: Intraday data.
2026-04-07 09:19:07.041 | Historical data download ID 19 not found when removing ID from outstanding request set.
2026-04-07 09:19:07.041 | Real-time Intraday chart data file updates started for MGCM4.COMEX
2026-04-07 09:19:07.041 | Intraday chart data file opened for MGCM4.COMEX
2026-04-07 09:19:07.058 | MGCM4.COMEX [CB] 5000 Trades #8 | Performing continuous chart historical Daily data download for symbol MGCM4.COMEX starting at last date in file.
2026-04-07 09:19:07.058 | Added historical Daily data request for MGCM4.COMEX to the queue.
2026-04-07 09:19:07.074 | MGCM4.COMEX [CB] 5000 Trades #8 | Waiting for historical downloads to complete with the IDs: 20,
2026-04-07 09:19:07.103 | NQM6.CME 3 Min 20 Sec #22 | Reloading chart.
2026-04-07 09:19:07.316 | MNQM6.CME #12 | Reloading chart.
2026-04-07 09:19:07.348 | MESH6.CME [CB] #2 | Reloading chart.
2026-04-07 09:19:07.374 | Rithmic Direct - DTC | Using primary service for historical data for MESH6.CME
2026-04-07 09:19:07.374 | Historical data service client indicated that downloads are not enabled. Symbol: MESH6.CME. Data Type: Intraday data.
2026-04-07 09:19:07.374 | Historical data download ID 21 not found when removing ID from outstanding request set.
2026-04-07 09:19:07.374 | Real-time Intraday chart data file updates started for MESH6.CME
2026-04-07 09:19:07.374 | Intraday chart data file opened for MESH6.CME
2026-04-07 09:19:07.425 | MESH6.CME [CB] #2 | Performing continuous chart historical Daily data download for symbol MESH6.CME starting at last date in file.
2026-04-07 09:19:07.425 | Added historical Daily data request for MESH6.CME to the queue.
2026-04-07 09:19:07.462 | MESH6.CME [CB] #2 | Waiting for historical downloads to complete with the IDs: 22,
2026-04-07 09:19:07.490 | MESH6.CME Rev. 16t-32 #7 | Reloading chart.
2026-04-07 09:19:07.547 | MESH6.CME Rev. 16t-20 #13 | Reloading chart.
2026-04-07 09:19:07.561 | MESH6.CME Rev. 16t-20 #15 | Reloading chart.
2026-04-07 09:19:07.572 | MESH6.CME 240 Min #17 | Reloading chart.
2026-04-07 09:19:07.583 | MESH6.CME 15 Min #18 | Reloading chart.
2026-04-07 09:19:07.842 | MESM4.CME [CB] 5000 Trades #19 | Reloading chart.
2026-04-07 09:19:07.843 | Rithmic Direct - DTC | Using primary service for historical data for MESM4.CME
2026-04-07 09:19:07.843 | Historical data service client indicated that downloads are not enabled. Symbol: MESM4.CME. Data Type: Intraday data.
2026-04-07 09:19:07.843 | Historical data download ID 23 not found when removing ID from outstanding request set.
2026-04-07 09:19:07.843 | Real-time Intraday chart data file updates started for MESM4.CME
2026-04-07 09:19:07.843 | Intraday chart data file opened for MESM4.CME
2026-04-07 09:19:07.869 | MESM4.CME [CB] 5000 Trades #19 | Performing continuous chart historical Daily data download for symbol MESM4.CME starting at last date in file.
2026-04-07 09:19:07.869 | Added historical Daily data request for MESM4.CME to the queue.
2026-04-07 09:19:07.888 | MESM4.CME [CB] 5000 Trades #19 | Waiting for historical downloads to complete with the IDs: 24,
2026-04-07 09:19:07.900 | CLK6.NYMEX #21 | Reloading chart.
2026-04-07 09:19:07.930 | NQH6.CME 30 Min #24 | Reloading chart.
2026-04-07 09:19:07.936 | ESU6.CME #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU6.CME.scid
2026-04-07 09:19:07.945 | ESU6.CME #1 | Chart data loading complete.
2026-04-07 09:19:07.947 | SIK6.COMEX #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\SIK6.COMEX.scid
2026-04-07 09:19:07.948 | SIK6.COMEX #4 | Chart data loading complete.
2026-04-07 09:19:07.949 | GC-202606-COMEX #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GC-202606-COMEX.scid
2026-04-07 09:19:07.950 | GC-202606-COMEX #5 | Chart data loading complete.
2026-04-07 09:19:07.953 | HD Request # 8 | Downloading Historical Daily chart data for ESH6.CME. Starting date: 2026-03-18. Service: rithmic.trading
2026-04-07 09:19:07.990 | ESM6.CME #10 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2026-04-07 09:19:07.990 | ESM6.CME #10 | Chart data loading complete.
2026-04-07 09:19:08.174 | NQM6.CME #6 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2026-04-07 09:19:08.174 | NQM6.CME #6 | Chart data loading complete.
2026-04-07 09:19:08.194 | RTYM6.CME #11 | >= 1 Day from current Date to last Date in file. Downloading historical Daily data
2026-04-07 09:19:08.194 | RTYM6.CME #11 | Chart data loading complete.
2026-04-07 09:19:08.195 | ESH6.CME Rev. 5t #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6.CME.scid
2026-04-07 09:19:08.195 | ESH6.CME Rev. 5t #14 | Chart data loading complete.
2026-04-07 09:19:08.197 | NQM6.CME #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQM6.CME.scid
2026-04-07 09:19:08.197 | NQM6.CME #3 | Chart data loading complete.
2026-04-07 09:19:08.198 | ESH6.CME 30 Min #26 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6.CME.scid
2026-04-07 09:19:08.198 | ESH6.CME 30 Min #26 | Chart data loading complete.
2026-04-07 09:19:08.202 | NQM6.CME 3 Min 20 Sec #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQM6.CME.scid
2026-04-07 09:19:08.203 | NQM6.CME 3 Min 20 Sec #22 | Chart data loading complete.
2026-04-07 09:19:08.214 | MNQM6.CME #12 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-04-07 09:19:08.214 | MNQM6.CME #12 | Chart data loading complete.
2026-04-07 09:19:08.217 | MESH6.CME Rev. 16t-32 #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:08.217 | MESH6.CME Rev. 16t-32 #7 | Chart data loading complete.
2026-04-07 09:19:08.218 | MESH6.CME Rev. 16t-20 #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:08.218 | MESH6.CME Rev. 16t-20 #13 | Chart data loading complete.
2026-04-07 09:19:08.219 | MESH6.CME Rev. 16t-20 #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:08.220 | MESH6.CME Rev. 16t-20 #15 | Chart data loading complete.
2026-04-07 09:19:08.221 | MESH6.CME 240 Min #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:08.221 | MESH6.CME 240 Min #17 | Chart data loading complete.
2026-04-07 09:19:08.222 | MESH6.CME 15 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:08.222 | MESH6.CME 15 Min #18 | Chart data loading complete.
2026-04-07 09:19:08.227 | CLK6.NYMEX #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLK6.NYMEX.scid
2026-04-07 09:19:08.227 | CLK6.NYMEX #21 | Chart data loading complete.
2026-04-07 09:19:08.229 | NQH6.CME 30 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6.CME.scid
2026-04-07 09:19:08.229 | NQH6.CME 30 Min #24 | Chart data loading complete.
2026-04-07 09:19:08.260 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU6.CME. ID: 18 Service code: rithmic.trading
2026-04-07 09:19:08.260 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESU6.CME.
2026-04-07 09:19:08.260 | Rithmic Direct - DTC | Requesting security definition data for: ESU6.CME. ID: 18
2026-04-07 09:19:08.260 | Rithmic Direct - DTC | Using primary service for historical data for ESU6.CME
2026-04-07 09:19:08.260 | Historical data service client indicated that downloads are not enabled. Symbol: ESU6.CME. Data Type: Intraday data.
2026-04-07 09:19:08.260 | Historical data download ID 25 not found when removing ID from outstanding request set.
2026-04-07 09:19:08.260 | Real-time Intraday chart data file updates started for ESU6.CME
2026-04-07 09:19:08.260 | Intraday chart data file opened for ESU6.CME
2026-04-07 09:19:08.263 | Rithmic Direct - DTC | Starting real-time market data updates for: SIK6.COMEX. ID: 19 Service code: rithmic.trading
2026-04-07 09:19:08.263 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: SIK6.COMEX.
2026-04-07 09:19:08.263 | Rithmic Direct - DTC | Requesting security definition data for: SIK6.COMEX. ID: 19
2026-04-07 09:19:08.263 | Rithmic Direct - DTC | Using primary service for historical data for SIK6.COMEX
2026-04-07 09:19:08.263 | Historical data service client indicated that downloads are not enabled. Symbol: SIK6.COMEX. Data Type: Intraday data.
2026-04-07 09:19:08.263 | Historical data download ID 26 not found when removing ID from outstanding request set.
2026-04-07 09:19:08.263 | Real-time Intraday chart data file updates started for SIK6.COMEX
2026-04-07 09:19:08.263 | Intraday chart data file opened for SIK6.COMEX
2026-04-07 09:19:08.264 | Rithmic Direct - DTC | Starting real-time market data updates for: GC-202606-COMEX. ID: 20
2026-04-07 09:19:08.264 | Rithmic Direct - DTC | Requesting security definition data for: GC-202606-COMEX. ID: 20
2026-04-07 09:19:08.264 | Rithmic Direct - DTC | Using primary service for historical data for GC-202606-COMEX
2026-04-07 09:19:08.264 | Historical data service client indicated that downloads are not enabled. Symbol: GC-202606-COMEX. Data Type: Intraday data.
2026-04-07 09:19:08.264 | Historical data download ID 27 not found when removing ID from outstanding request set.
2026-04-07 09:19:08.264 | Real-time Intraday chart data file updates started for GC-202606-COMEX
2026-04-07 09:19:08.264 | Intraday chart data file opened for GC-202606-COMEX
2026-04-07 09:19:08.264 | Added historical Daily data request for ESM6.CME to the queue.
2026-04-07 09:19:08.264 | Triggering next historical data download in queue.
2026-04-07 09:19:08.264 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM6.CME. ID: 21 Service code: rithmic.trading
2026-04-07 09:19:08.264 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESM6.CME.
2026-04-07 09:19:08.264 | Rithmic Direct - DTC | Requesting security definition data for: ESM6.CME. ID: 21
2026-04-07 09:19:08.266 | Added historical Daily data request for NQM6.CME to the queue.
2026-04-07 09:19:08.266 | Triggering next historical data download in queue.
2026-04-07 09:19:08.267 | Rithmic Direct - DTC | Starting real-time market data updates for: NQM6.CME. ID: 22 Service code: rithmic.trading
2026-04-07 09:19:08.267 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: NQM6.CME.
2026-04-07 09:19:08.267 | Rithmic Direct - DTC | Requesting security definition data for: NQM6.CME. ID: 22
2026-04-07 09:19:08.270 | Added historical Daily data request for RTYM6.CME to the queue.
2026-04-07 09:19:08.270 | Triggering next historical data download in queue.
2026-04-07 09:19:08.270 | Rithmic Direct - DTC | Starting real-time market data updates for: RTYM6.CME. ID: 23 Service code: rithmic.trading
2026-04-07 09:19:08.270 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: RTYM6.CME.
2026-04-07 09:19:08.270 | Rithmic Direct - DTC | Requesting security definition data for: RTYM6.CME. ID: 23
2026-04-07 09:19:08.272 | Rithmic Direct - DTC | Starting real-time market data updates for: ESH6.CME. ID: 10 Service code: rithmic.trading
2026-04-07 09:19:08.272 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESH6.CME.
2026-04-07 09:19:08.272 | Rithmic Direct - DTC | Requesting security definition data for: ESH6.CME. ID: 10
2026-04-07 09:19:08.272 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=100
2026-04-07 09:19:08.272 | Separate subscription for market depth updates not supported. ESH6.CME
2026-04-07 09:19:08.272 | Rithmic Direct - DTC | Using primary service for historical data for NQM6.CME
2026-04-07 09:19:08.272 | Historical data service client indicated that downloads are not enabled. Symbol: NQM6.CME. Data Type: Intraday data.
2026-04-07 09:19:08.272 | Historical data download ID 31 not found when removing ID from outstanding request set.
2026-04-07 09:19:08.272 | Real-time Intraday chart data file updates started for NQM6.CME
2026-04-07 09:19:08.272 | Intraday chart data file opened for NQM6.CME
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Starting real-time market data updates for: MNQM6.CME. ID: 24 Service code: rithmic.trading
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: MNQM6.CME.
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Requesting security definition data for: MNQM6.CME. ID: 24
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Using primary service for historical data for MNQM6.CME
2026-04-07 09:19:08.274 | Historical data service client indicated that downloads are not enabled. Symbol: MNQM6.CME. Data Type: Intraday data.
2026-04-07 09:19:08.274 | Historical data download ID 32 not found when removing ID from outstanding request set.
2026-04-07 09:19:08.274 | Real-time Intraday chart data file updates started for MNQM6.CME
2026-04-07 09:19:08.274 | Intraday chart data file opened for MNQM6.CME
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Starting real-time market data updates for: MESH6.CME. ID: 16 Service code: rithmic.trading
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: MESH6.CME.
2026-04-07 09:19:08.274 | Rithmic Direct - DTC | Requesting security definition data for: MESH6.CME. ID: 16
2026-04-07 09:19:08.406 | Rithmic Direct - DTC | Starting real-time market data updates for: CLK6.NYMEX. ID: 25 Service code: rithmic.trading
2026-04-07 09:19:08.406 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: CLK6.NYMEX.
2026-04-07 09:19:08.406 | Rithmic Direct - DTC | Requesting security definition data for: CLK6.NYMEX. ID: 25
2026-04-07 09:19:08.406 | Rithmic Direct - DTC | Using primary service for historical data for CLK6.NYMEX
2026-04-07 09:19:08.406 | Historical data service client indicated that downloads are not enabled. Symbol: CLK6.NYMEX. Data Type: Intraday data.
2026-04-07 09:19:08.406 | Historical data download ID 33 not found when removing ID from outstanding request set.
2026-04-07 09:19:08.406 | Real-time Intraday chart data file updates started for CLK6.NYMEX
2026-04-07 09:19:08.406 | Intraday chart data file opened for CLK6.NYMEX
2026-04-07 09:19:08.422 | Rithmic Direct - DTC | Starting real-time market data updates for: NQH6.CME. ID: 14 Service code: rithmic.trading
2026-04-07 09:19:08.422 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: NQH6.CME.
2026-04-07 09:19:08.422 | Rithmic Direct - DTC | Requesting security definition data for: NQH6.CME. ID: 14
2026-04-07 09:19:08.438 | HD Request # 8 | Requesting historical Daily data for ESH26 starting at 2026-03-17. SC External HD service.
2026-04-07 09:19:08.601 | HD Request # 8 | Receiving historical Daily data for ESH6.CME starting at 2026-03-18.
2026-04-07 09:19:08.601 | HD Request # 8 | Writing historical Daily data to the file ESH6.CME.dly.
2026-04-07 09:19:08.607 | HD Request # 8 | Bytes received: 225
2026-04-07 09:19:08.607 | HD Request # 8 | Received 4 Daily data records from 2026-03-18 00:00:00 to 2026-03-20 00:00:00 (3.0 days) and wrote 3 records for ESH6.CME
2026-04-07 09:19:08.608 | HD Request # 8 | Completion time: 1s.
2026-04-07 09:19:08.608 | HD Request # 8 | Daily data download complete for ESH6.CME. Unique request ID: 13
2026-04-07 09:19:08.608 | Removing historical data download ID 13.
2026-04-07 09:19:08.608 | Triggering next historical data download in queue.
2026-04-07 09:19:08.610 | HD Request # 9 | Downloading Historical Daily chart data for NQH6.CME. Starting date: 2026-03-18. Service: rithmic.trading
2026-04-07 09:19:08.748 | ESH6.CME [CB] #16 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-07 09:19:08.749 | ESH6.CME [CB] #16 | Reloading chart.
2026-04-07 09:19:08.839 | ESH6.CME [CB] #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6.CME.scid
2026-04-07 09:19:08.839 | ESH6.CME [CB] #16 | Chart data loading complete.
2026-04-07 09:19:08.849 | HD Request # 9 | Requesting historical Daily data for NQH26 starting at 2026-03-17. SC External HD service.
2026-04-07 09:19:08.957 | HD Request # 9 | Receiving historical Daily data for NQH6.CME starting at 2026-03-18.
2026-04-07 09:19:08.957 | HD Request # 9 | Writing historical Daily data to the file NQH6.CME.dly.
2026-04-07 09:19:08.961 | HD Request # 9 | Bytes received: 232
2026-04-07 09:19:08.961 | HD Request # 9 | Received 4 Daily data records from 2026-03-18 00:00:00 to 2026-03-20 00:00:00 (3.0 days) and wrote 3 records for NQH6.CME
2026-04-07 09:19:08.961 | HD Request # 9 | Completion time: 0s.
2026-04-07 09:19:08.961 | HD Request # 9 | Daily data download complete for NQH6.CME. Unique request ID: 18
2026-04-07 09:19:08.961 | Removing historical data download ID 18.
2026-04-07 09:19:08.961 | Triggering next historical data download in queue.
2026-04-07 09:19:08.963 | HD Request # 10 | Downloading Historical Daily chart data for MGCM4.COMEX. Starting date: 2024-06-24. Service: rithmic.trading
2026-04-07 09:19:09.013 | NQH6.CME [CB] #9 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-07 09:19:09.013 | NQH6.CME [CB] #9 | Reloading chart.
2026-04-07 09:19:09.066 | NQH6.CME [CB] #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6.CME.scid
2026-04-07 09:19:09.066 | NQH6.CME [CB] #9 | Chart data loading complete.
2026-04-07 09:19:09.192 | HD Request # 10 | Requesting historical Daily data for GRM24 starting at 2024-06-23. SC External HD service.
2026-04-07 09:19:09.247 | ESH6.CME [CB] #16 | Reloading chart.
2026-04-07 09:19:09.409 | HD Request # 10 | Receiving historical Daily data for MGCM4.COMEX starting at 2024-06-24.
2026-04-07 09:19:09.409 | HD Request # 10 | Writing historical Daily data to the file MGCM4.COMEX.dly.
2026-04-07 09:19:09.436 | HD Request # 10 | Bytes received: 144
2026-04-07 09:19:09.436 | HD Request # 10 | Received 3 Daily data records from 2024-06-24 00:00:00 to 2024-06-26 00:00:00 (3.0 days) and wrote 3 records for MGCM4.COMEX
2026-04-07 09:19:09.436 | HD Request # 10 | Completion time: 1s.
2026-04-07 09:19:09.436 | HD Request # 10 | Daily data download complete for MGCM4.COMEX. Unique request ID: 20
2026-04-07 09:19:09.436 | Removing historical data download ID 20.
2026-04-07 09:19:09.436 | Triggering next historical data download in queue.
2026-04-07 09:19:09.436 | ESH6.CME [CB] #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH6.CME.scid
2026-04-07 09:19:09.437 | ESH6.CME [CB] #16 | Chart data loading complete.
2026-04-07 09:19:09.439 | HD Request # 11 | Downloading Historical Daily chart data for MESH6.CME. Starting date: 2026-03-18. Service: rithmic.trading
2026-04-07 09:19:09.515 | NQH6.CME [CB] #9 | Reloading chart.
2026-04-07 09:19:09.662 | MGCM4.COMEX [CB] 5000 Trades #8 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-07 09:19:09.662 | MGCM4.COMEX [CB] 5000 Trades #8 | Reloading chart.
2026-04-07 09:19:09.664 | NQH6.CME [CB] #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQH6.CME.scid
2026-04-07 09:19:09.664 | NQH6.CME [CB] #9 | Chart data loading complete.
2026-04-07 09:19:09.665 | Loading market depth data.
2026-04-07 09:19:09.666 | MGCM4.COMEX [CB] 5000 Trades #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MGCM4.COMEX.scid
2026-04-07 09:19:09.666 | MGCM4.COMEX [CB] 5000 Trades #8 | Chart data loading complete.
2026-04-07 09:19:09.684 | HD Request # 11 | Requesting historical Daily data for ETH26 starting at 2026-03-17. SC External HD service.
2026-04-07 09:19:09.790 | HD Request # 11 | Receiving historical Daily data for MESH6.CME starting at 2026-03-18.
2026-04-07 09:19:09.791 | HD Request # 11 | Writing historical Daily data to the file MESH6.CME.dly.
2026-04-07 09:19:09.800 | HD Request # 11 | Bytes received: 229
2026-04-07 09:19:09.800 | HD Request # 11 | Received 4 Daily data records from 2026-03-18 00:00:00 to 2026-03-20 00:00:00 (3.0 days) and wrote 3 records for MESH6.CME
2026-04-07 09:19:09.800 | HD Request # 11 | Completion time: 0s.
2026-04-07 09:19:09.800 | HD Request # 11 | Daily data download complete for MESH6.CME. Unique request ID: 22
2026-04-07 09:19:09.800 | Removing historical data download ID 22.
2026-04-07 09:19:09.800 | Triggering next historical data download in queue.
2026-04-07 09:19:09.802 | HD Request # 12 | Downloading Historical Daily chart data for MESM4.CME. Starting date: 2024-06-18. Service: rithmic.trading
2026-04-07 09:19:09.844 | MESH6.CME [CB] #2 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-07 09:19:09.844 | MESH6.CME [CB] #2 | Reloading chart.
2026-04-07 09:19:09.857 | MESH6.CME [CB] #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:09.857 | MESH6.CME [CB] #2 | Chart data loading complete.
2026-04-07 09:19:10.021 | HD Request # 12 | Requesting historical Daily data for ETM24 starting at 2024-06-17. SC External HD service.
2026-04-07 09:19:10.106 | HD Request # 12 | Receiving historical Daily data for MESM4.CME starting at 2024-06-18.
2026-04-07 09:19:10.106 | HD Request # 12 | Writing historical Daily data to the file MESM4.CME.dly.
2026-04-07 09:19:10.127 | HD Request # 12 | Bytes received: 225
2026-04-07 09:19:10.127 | HD Request # 12 | Received 4 Daily data records from 2024-06-18 00:00:00 to 2024-06-21 00:00:00 (4.0 days) and wrote 3 records for MESM4.CME
2026-04-07 09:19:10.127 | HD Request # 12 | Completion time: 1s.
2026-04-07 09:19:10.127 | HD Request # 12 | Daily data download complete for MESM4.CME. Unique request ID: 24
2026-04-07 09:19:10.127 | Removing historical data download ID 24.
2026-04-07 09:19:10.127 | Triggering next historical data download in queue.
2026-04-07 09:19:10.129 | HD Request # 13 | Downloading Historical Daily chart data for ESM6.CME. Starting date: 2026-04-02. Service: rithmic.trading
2026-04-07 09:19:10.172 | MGCM4.COMEX [CB] 5000 Trades #8 | Reloading chart.
2026-04-07 09:19:10.190 | Loading market depth data.
2026-04-07 09:19:10.191 | MGCM4.COMEX [CB] 5000 Trades #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MGCM4.COMEX.scid
2026-04-07 09:19:10.191 | MGCM4.COMEX [CB] 5000 Trades #8 | Chart data loading complete.
2026-04-07 09:19:10.345 | MESH6.CME [CB] #2 | Reloading chart.
2026-04-07 09:19:10.418 | HD Request # 13 | Requesting historical Daily data for ESM26 starting at 2026-04-01. SC External HD service.
2026-04-07 09:19:10.419 | MESH6.CME [CB] #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESH6.CME.scid
2026-04-07 09:19:10.419 | MESH6.CME [CB] #2 | Chart data loading complete.
2026-04-07 09:19:10.419 | MESM4.CME [CB] 5000 Trades #19 | Download is complete for all contract months in chart. Proceeding with data load.
2026-04-07 09:19:10.420 | MESM4.CME [CB] 5000 Trades #19 | Reloading chart.
2026-04-07 09:19:10.422 | Loading market depth data.
2026-04-07 09:19:10.423 | MESM4.CME [CB] 5000 Trades #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESM4.CME.scid
2026-04-07 09:19:10.423 | MESM4.CME [CB] 5000 Trades #19 | Chart data loading complete.
2026-04-07 09:19:10.519 | HD Request # 13 | Receiving historical Daily data for ESM6.CME starting at 2026-04-02.
2026-04-07 09:19:10.519 | HD Request # 13 | Writing historical Daily data to the file ESM6.CME.dly.
2026-04-07 09:19:10.525 | HD Request # 13 | Bytes received: 285
2026-04-07 09:19:10.525 | HD Request # 13 | Received 5 Daily data records from 2026-04-02 00:00:00 to 2026-04-07 00:00:00 (6.0 days) and wrote 4 records for ESM6.CME
2026-04-07 09:19:10.525 | HD Request # 13 | Completion time: 0s.
2026-04-07 09:19:10.525 | HD Request # 13 | Daily data download complete for ESM6.CME. Unique request ID: 28
2026-04-07 09:19:10.525 | Removing historical data download ID 28.
2026-04-07 09:19:10.526 |
2026-04-07 09:19:10.526 | Triggering next historical data download in queue.
2026-04-07 09:19:10.528 | HD Request # 14 | Downloading Historical Daily chart data for NQM6.CME. Starting date: 2026-04-02. Service: rithmic.trading
2026-04-07 09:19:10.669 | Rithmic Direct - DTC | Starting real-time market data updates for: MGCM4.COMEX. ID: 15 Service code: rithmic.trading
2026-04-07 09:19:10.669 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: MGCM4.COMEX.
2026-04-07 09:19:10.670 | Rithmic Direct - DTC | Requesting security definition data for: MGCM4.COMEX. ID: 15
2026-04-07 09:19:10.670 | Requesting market depth updates for: MGCM4.COMEX if supported. NumLevels=100
2026-04-07 09:19:10.670 | Separate subscription for market depth updates not supported. MGCM4.COMEX
2026-04-07 09:19:10.786 | HD Request # 14 | Requesting historical Daily data for NQM26 starting at 2026-04-01. SC External HD service.
2026-04-07 09:19:10.906 | HD Request # 14 | Receiving historical Daily data for NQM6.CME starting at 2026-04-02.
2026-04-07 09:19:10.906 | HD Request # 14 | Writing historical Daily data to the file NQM6.CME.dly.
2026-04-07 09:19:10.909 | HD Request # 14 | Bytes received: 295
2026-04-07 09:19:10.909 | HD Request # 14 | Received 5 Daily data records from 2026-04-02 00:00:00 to 2026-04-07 00:00:00 (6.0 days) and wrote 4 records for NQM6.CME
2026-04-07 09:19:10.910 | HD Request # 14 | Completion time: 0s.
2026-04-07 09:19:10.910 | HD Request # 14 | Daily data download complete for NQM6.CME. Unique request ID: 29
2026-04-07 09:19:10.910 | Removing historical data download ID 29.
2026-04-07 09:19:10.910 | Triggering next historical data download in queue.
2026-04-07 09:19:10.912 | HD Request # 15 | Downloading Historical Daily chart data for RTYM6.CME. Starting date: 2026-04-02. Service: rithmic.trading
2026-04-07 09:19:10.921 | MESM4.CME [CB] 5000 Trades #19 | Reloading chart.
2026-04-07 09:19:10.943 | Loading market depth data.
2026-04-07 09:19:10.944 | MESM4.CME [CB] 5000 Trades #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESM4.CME.scid
2026-04-07 09:19:10.944 | MESM4.CME [CB] 5000 Trades #19 | Chart data loading complete.
2026-04-07 09:19:10.984 | ESM6.CME #10 | Reloading chart.
2026-04-07 09:19:10.988 | NQM6.CME #6 | Reloading chart.
2026-04-07 09:19:11.015 | ESM6.CME #10 | Chart data loading complete.
2026-04-07 09:19:11.196 | NQM6.CME #6 | Chart data loading complete.
2026-04-07 09:19:11.197 | HD Request # 15 | Requesting historical Daily data for QRM26 starting at 2026-04-01. SC External HD service.
2026-04-07 09:19:11.292 | HD Request # 15 | Receiving historical Daily data for RTYM6.CME starting at 2026-04-02.
2026-04-07 09:19:11.293 | HD Request # 15 | Writing historical Daily data to the file RTYM6.CME.dly.
2026-04-07 09:19:11.305 | HD Request # 15 | Bytes received: 280
2026-04-07 09:19:11.305 | HD Request # 15 | Received 5 Daily data records from 2026-04-02 00:00:00 to 2026-04-07 00:00:00 (6.0 days) and wrote 4 records for RTYM6.CME
2026-04-07 09:19:11.305 | HD Request # 15 | Completion time: 1s.
2026-04-07 09:19:11.305 | HD Request # 15 | Daily data download complete for RTYM6.CME. Unique request ID: 30
2026-04-07 09:19:11.305 | Removing historical data download ID 30.
2026-04-07 09:19:11.306 |
2026-04-07 09:19:11.306 | No download requests in the queue to start downloads for.
2026-04-07 09:19:11.423 | Rithmic Direct - DTC | Starting real-time market data updates for: MESM4.CME. ID: 17 Service code: rithmic.trading
2026-04-07 09:19:11.423 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: MESM4.CME.
2026-04-07 09:19:11.423 | Rithmic Direct - DTC | Requesting security definition data for: MESM4.CME. ID: 17
2026-04-07 09:19:11.423 | Requesting market depth updates for: MESM4.CME if supported. NumLevels=100
2026-04-07 09:19:11.423 | Separate subscription for market depth updates not supported. MESM4.CME
2026-04-07 09:19:11.752 | RTYM6.CME #11 | Reloading chart.
2026-04-07 09:19:11.773 | RTYM6.CME #11 | Chart data loading complete.
2026-04-07 09:19:12.077 | Requesting market depth updates for: MNQM6.CME if supported. NumLevels=100
2026-04-07 09:19:12.077 | Separate subscription for market depth updates not supported. MNQM6.CME
2026-04-07 09:20:06.169 | ESM6.CME #9 | Reloading chart.
2026-04-07 09:20:06.199 | ESM6.CME #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM6.CME.scid
2026-04-07 09:20:06.200 | ESM6.CME #9 | Chart data loading complete.
2026-04-07 09:20:06.654 | Rithmic Direct - DTC | Using primary service for historical data for ESM6.CME
2026-04-07 09:20:06.654 | Historical data service client indicated that downloads are not enabled. Symbol: ESM6.CME. Data Type: Intraday data.
2026-04-07 09:20:06.654 | Historical data download ID 34 not found when removing ID from outstanding request set.
2026-04-07 09:20:06.654 | Real-time Intraday chart data file updates started for ESM6.CME
2026-04-07 09:20:06.654 | Intraday chart data file opened for ESM6.CME
2026-04-07 09:23:37.839 | ESM6.CME #1 | Reloading chart.
2026-04-07 09:23:37.874 | ESM6.CME #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM6.CME.scid
2026-04-07 09:23:37.876 | ESM6.CME #1 | Chart data loading complete.
[2026-04-07 13:47:27]
Sierra_Chart Engineering - Posts: 25163
You need to activate the exchanges you need market data for, here:
Date Time Of Last Edit: 2026-04-07 13:47:38
[2026-04-07 13:58:46]
SurfTrader - Posts: 88
Does lucids rithmic data not cover ES and NQ?
[2026-04-07 16:58:18]
John - SC Support - Posts: 48189
You are trying to get data for expired contracts - for instance we see a reference to "MESM4.CME" in your log. Rithmic has a lack of historical data in general, and does not supply any data for expired contracts. Hence the reason you would need to get your data from our Denali Exchange Data Feed. Refer to the following:
Rithmic Trading Platform Service: Rithmic Support Policy
If those symbols are not there on purpose, then you can remove those references and be able to get the real-time data from Rithmic. We also recommend removing any symbol that is not Rithmic specific - such as "XAUUSD". Refer to the following regarding this:
Rithmic Trading Platform Service: Frequent Reconnections
If you do want to get your data from our Denali Exchange Data Feed for the CME Group at the non-professional rates, then keep in mind that you need to have a live, funded, futures trading account and you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Once you have the above worked out, then you can setup the data by following these instructions:
