Date/Time: Sat, 07 Nov 2026 05:21:55 +0000
time and sales window clears when switching to other chartbook
View Count: 929
| [2026-03-04 16:20:58] |
| User568229 - Posts: 8 |
Hi, before the update this morning it used to work fine. I assume some default setting got triggered again. Sorry but I fail to figure out which one. I have several chartbooks setup for different symbols. Each one of them has a Time and Sales window (do not know if it used to be attached or always visible). When I now switch from one chart book to another all the data clears. How do I prevent this from happening? Thanks |
| [2026-03-04 16:48:38] |
| John - SC Support - Posts: 48459 |
We are not able to reproduce what we think you are seeing. We have two chartbooks open (Chartbook1 and Chartbook2) and we open the Time and Sales window for ESH26-CME in Chartbook1. We then change to Chartbook2 and the Time and Sales window disappears (which is correct functioning, since it is associated with Chartbook1). When we go back to Chartbook1 the Time and Sales window is open again and it shows all the data that it had previously. If you are seeing something different from the above workflow, then let us know what exactly is different. If your workflow to reproduce this is also different, then we need to know exactly what you are doing when this occurs. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-04 17:07:05] |
Thanks for your quick response. My workflow is exactely according to your description. The difficulty I am having is that when I switch back to i.e. chartbook1, all the data is gone. It seems to matter how much time I spend on chartbook2 though. When I switch back almost instantly, some data is still there but not all. When I linger for more than say 1 minute or more on chartbook2, then go back to chartbook1, ALL the data is gone. It is like I would hit "clear". Before the update it used to work just the way you described. I could switch back and forth, spend the entire day on whatever chartbook and all the Time & Sales data were gathered on all the other chartbooks too. |
| [2026-03-04 17:25:57] |
Although we do not think this is related, we want to point out that you are not setup to get any real-time data from us. And it looks like you have your "Current Selected Service" set to "Teton". Therefore, you would HAVE to get the real-time data from us, as there is no other choice when using Teton. But the last time you had real-time data from us for the CME Group was in November 2025. So we are not sure if this is just an oversight, or done on purpose. If you want to get the real-time data for the CME Group, then you can activate the exchange(s) you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges If you do activate an exchange, then let us know if this resolves the issue with Time and Sales. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-04 19:25:20] |
| Sierra_Chart Engineering - Posts: 25393 |
We think we might know the reason for the problem. We want to know what this setting is set to: Data/Trade Service Settings: Number of Stored Time and Sales Records (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-04 19:25:47
| [2026-03-05 11:59:10] |
Thanks for your support on the matter. I am aware of the above mentioned data feed and had that considered as well. The number is currently set to 8'000. It was set to 4'000 after the update but I am not aware where it was set to before the update. Thanks again |
| [2026-03-05 13:54:52] |
Are there filter settings you are using in the Time and Sales window? Increase the number of stored Time and Sales records. We think that is going to solve the problem. And you probably are also using filter settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-05 13:55:11
| [2026-03-05 14:17:35] |
Yes I am using filter settings. Does it store the filterd only? looks like you found the solution. It works like it used to. Thanks again for your help |
| [2026-03-05 14:18:51] |
The number of stored Time and Sales records, affects all records. Filtering has no relevancy to that setting.
| [2026-07-02 19:45:26] |
| User584421 - Posts: 6 |
I am getting the same issue, but my "number of stored time and sales records" is set to 10,000 and the window still clears. It only affects the time and sales windows that are filtered. Also my "maximum number of records to display" is set to 2000 and I have tried switching to 10000 and 0 and still get the issue. Any other ways to fix this? Edit: I'm using the ARM version on parallels. Date Time Of Last Edit: 2026-07-02 19:46:37
| [2026-07-02 20:49:20] |
We have tested this again per the workflow we stated in post #2 and are not seeing any issues with this. Please give us the exact workflow you are following where this occurs. And tell us how your Time and Sales settings are setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-07 21:56:13] |
Thanks for your response. My workflow is exactly the same as you described in post #2, the only difference is that I have 3 time and sales windows open for chart book 1. The first has no filter and does not lose data when switching to chart book 2 and back to chart book 1, the second has a filter set to 10 which sometimes loses all data and sometimes loses partial data when switching to another chart book and back, and the last one has a filter set to 50 which loses all the data every time I switch chart books and switch back. Time and Sales Settings for the one filtered at 50 is: General: Do not combine No, yes, yes, yes, yes, yes, 0, 2000, 1, 1 Columns: No, yes, yes, yes, yes, no, no, no, no, no Filtering: Input Filtering -> Volume >=(min): 50 Alerts: Volume, >=, 50, yes, no alert sound, no alert sound |
| [2026-07-13 13:54:01] |
The simple solution is to increase this setting even more: but my "number of stored time and sales records" is set to 10,000 and the window still clears. I
Regarding all of the settings given in post #12 there is a simple way to provide those settings instead of manually typing them: Make sure you are running a current version of Sierra Chart. ( Help >> Download Current Version) Right-click on any row of the Time and Sales Settings >>Filtering Tab and select a Copy Name and Value - All Settings. This will be an example of what you get: "Input Filtering"
Volume >= (min): 10 Price >= (min): {} Volume <= (max): {} Price <= (max): {} Ask Size >= (min): {} Bid Size >= (min): {} Ask Size <= (max): {} Bid Size <= (max): {} "Combined Filtering" Volume >= (min): {} Trades >= (min): {} Volume <= (max): {} Trades <= (max): {} Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-07-13 14:06:39
| [2026-07-13 14:21:42] |
| BA_Trades - Posts: 22 |
This happens to me as well. Here are my copied settings. I am only using a min 100 filter. "Input Filtering" Volume >= (min): 100 Price >= (min): Volume <= (max): Price <= (max): Ask Size >= (min): Bid Size >= (min): Ask Size <= (max): Bid Size <= (max): "Combined Filtering" Volume >= (min): Trades >= (min): Volume <= (max): Trades <= (max): |
| [2026-08-02 23:04:37] |
We do not have a solution to this at this time other than recommending to increase the number of stored Time and Sales records. This is high: I am only using a min 100 filter.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-02 23:04:53
| [2026-08-03 14:54:02] |
Thanks for the update. I increased my Time and Sales stored records to 50,000 and it will still erase when switching back and forth between 2 chartbooks.
| [2026-08-03 20:25:41] |
I also increased my time and sales stored records and it didn't change anything. I also don't see how that would make any difference as there's like a maximum of maybe two hundred time and sales lines on my filtered time and sales window throughout the entire day. Thanks for the response explaining you have no solution though. Date Time Of Last Edit: 2026-08-03 20:26:01
| [2026-08-04 00:58:36] |
We will implement a temporary solution to this. It is not as efficient but it will work the way it did before.
