Date/Time: Tue, 17 Nov 2026 18:08:54 +0000
Real time Data not working Even with Denali Feed (CQG issue)
View Count: 1646
[2025-07-22 15:35:54]
User216722 - Posts: 5
I saw the threads and replies to the issue with the sudden change to real time data for people with CQG webAPI. The replies all said to enable denali feed. I DO have Denali feed enabled for the CME top of book and it is active, was working just fine until today. when I connect I get the message "Real-time market data only supported with Sierra Chart data feed for symbol: F.US.ENQU25. ID:6" click for symbol isn't working. WHen I went to SRVSET and enabled support for sierra chart data feeds, the error message goes away and history is loaded but it doesn't work, it loads the data but stays frozen from that point and doesn't update the price nor chart from the point i connect. Please advise what happened and what I need to do resolve. IF the symbol needs to change please advise which symbol since your symbol look up link didn't work and when I looked it up in chart settings it still shows the same CQG symbols...
[2025-07-22 15:50:41]
Sierra_Chart Engineering - Posts: 25432
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2025-07-22 19:23:09]
i believe i spotted the issue, the message log says my max connections 1 and numcurrentConnectionDifferentDevices=2. The other machine running SC has in the SRVset current service selected "SC-Data all services" and is running different symbols for the same markets. the machine with the issue is using CQGWebApi using my username & password. I am allowed to run 2 instances of Sierra Chart and have not had any problems until today., would I not be allowed to have both instances working? if not then is there some other fee that needs to be paid?
Copied most of the message log below:
2025-07-22 15:10:11.609 | No download requests in the queue to start downloads for.
2025-07-22 15:10:11.609 | Historical data for F.US.ENQU25 is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-07-22 15:10:11.663 | Socket (2) | Socket gracefully closed by remote side.
2025-07-22 15:10:11.663 | Socket (2) | Closed.
2025-07-22 15:10:12.238 | File >> Disconnect selected.
2025-07-22 15:10:12.239 | CQG WebAPI | Sending Web API Logoff message.
2025-07-22 15:10:12.239 | CQG WebSocket socket (1) | CloseSocket call.
2025-07-22 15:10:12.239 | CQG WebSocket | WebSocket closed.
2025-07-22 15:10:12.239 | CQG WebAPI | WebSocket closed.
2025-07-22 15:10:12.239 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0
2025-07-22 15:10:12.239 | DTC Client socket (0) | CloseSocket call.
2025-07-22 15:10:12.239 | Denali Data Feed | Disconnected from the server.
2025-07-22 15:10:12.239 | CQG WebAPI | Disconnected.
2025-07-22 15:10:12.280 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed.
2025-07-22 15:10:12.280 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close.
2025-07-22 15:10:12.324 | CQG WebSocket socket (1) | Socket gracefully closed by remote side.
2025-07-22 15:10:12.324 | CQG WebSocket socket (1) | Closed.
2025-07-22 15:10:14.769 |
2025-07-22 15:10:14.769 | CQG WebAPI | Connecting to server api.cqg.com
2025-07-22 15:10:14.769 | CQG WebSocket | Connecting to WebSocket server api.cqg.com:443
2025-07-22 15:10:14.770 | CQG WebSocket socket (1) | Creating socket. Using TLS 1.2.
2025-07-22 15:10:14.770 | CQG WebSocket socket (1) | New receive buffer size: 0
2025-07-22 15:10:14.770 | CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17.
2025-07-22 15:10:14.819 | CQG WebSocket | Opening WebSocket.
2025-07-22 15:10:14.819 | CQG WebSocket | Sending WebSocket handshake.
2025-07-22 15:10:14.968 | CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols
2025-07-22 15:10:14.968 | CQG WebSocket | Server header | Connection: Upgrade
2025-07-22 15:10:14.968 | CQG WebSocket | Server header | Sec-WebSocket-Accept: BHVlS5Kc9M45pFxH86Remya/g8k=
2025-07-22 15:10:14.968 | CQG WebSocket | Server header | Server: WebSocket++/0.8.2
2025-07-22 15:10:14.968 | CQG WebSocket | Server header | Upgrade: websocket
2025-07-22 15:10:14.968 | CQG WebSocket | Web socket state is now open.
2025-07-22 15:10:14.968 | CQG WebAPI | WebSocket connected.
2025-07-22 15:10:14.968 | CQG WebAPI | Sending market data logon message.
2025-07-22 15:10:15.077 | CQG WebAPI | Base Time: 2025-07-19T04:38:56. 2025-07-19 04:38:56
2025-07-22 15:10:15.077 | CQG WebAPI | Logon successful. Session Token = NhOm/P9TXpAwRe4YbZarrXnDY6YjoGwXrWqKp/4d/Gc2QN9e/3li/9f6bjeAyz5JMb/8a2tQYYa
2025-07-22 15:10:15.077 | CQG WebAPI | Connection to server complete.
2025-07-22 15:10:15.078 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-07-22 15:10:15.078 | Updated verified funded futures trading account ending date to: 2025-08-21 19:10:15
2025-07-22 15:10:15.079 | CQG WebAPI | Sending Trade Accounts request message.
2025-07-22 15:10:15.179 | CQG WebAPI | Brokerage name: StoneX Futures Live. Account Name: ADRT VENTURES LLC | Number times message added: 4
2025-07-22 15:10:15.179 | Updated verified funded futures trading account ending date to: 2025-08-21 19:10:15
2025-07-22 15:10:15.179 | CQG WebAPI | Sending collateral subscribe request.
2025-07-22 15:10:15.315 | CQG WebAPI | Sending positions subscribe request. RequestID: 903408
2025-07-22 15:10:15.315 | CQG WebAPI | Sending orders subscribe request. RequestID: 903409
2025-07-22 15:10:15.425 | Mapping F.US.ENQU25 to NQU25. Service code: cme
2025-07-22 15:10:15.425 | Using symbol data fast lookup vector
2025-07-22 15:10:15.425 | Denali Data Feed | Starting real-time market data updates for: F.US.ENQU25 (NQU25). ID: 1 Service code: cme
2025-07-22 15:10:15.425 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048
2025-07-22 15:10:15.425 | CQG WebAPI | Sending symbol resolution request for F.US.ENQU25. ID: 903410
2025-07-22 15:10:15.425 | Denali Data Feed | Requesting security definition data for: F.US.ENQU25 (NQU25). ID: 1
2025-07-22 15:10:15.425 | Added historical Intraday data request for F.US.ENQU25 to the queue.
2025-07-22 15:10:15.425 | Intraday data recording state for symbol F.US.ENQU25 is set to download 'Pending'.
2025-07-22 15:10:15.425 | Triggering next historical data download in queue.
2025-07-22 15:10:15.425 | DTC Client socket (2) | Creating socket.
2025-07-22 15:10:15.425 | DTC Client socket (2) | New receive buffer size: 0
2025-07-22 15:10:15.425 | DTC Client socket (2) | Connecting to IP: 69.39.70.249.
2025-07-22 15:10:15.435 | Delaying start of download for F.US.ENQU25.
2025-07-22 15:10:15.474 | CQG WebAPI | Received symbol resolution report for symbol F.US.ENQU25. Search Symbol: F.US.ENQU25. Request ID: 903410. Contract ID: 1.
2025-07-22 15:10:15.479 | Denali Data Feed | Network connection to server complete.
2025-07-22 15:10:15.479 | Denali Data Feed | Starting socket receive thread.
2025-07-22 15:10:15.479 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-07-22 15:10:15.555 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-07-22 15:10:15.555 | Denali Data Feed | Sending logon request message.
2025-07-22 15:10:15.977 | Denali Data Feed | Received logon response.
2025-07-22 15:10:15.977 | Denali Data Feed | Server Name: RealTimeServer.
2025-07-22 15:10:15.977 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-07-22 15:10:15.977 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-07-22 15:10:15.977 | Denali Data Feed | Failed connections: 216
2025-07-22 15:10:15.977 | Denali Data Feed | Waiting for socket receive thread to end
2025-07-22 15:10:15.977 | DTC Client socket (2) | CloseSocket call.
2025-07-22 15:10:15.977 | Denali Data Feed | Disconnected from the server.
2025-07-22 15:10:15.977 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-07-22 15:10:15.978 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-07-22 15:10:16.030 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-07-22 15:10:16.030 | DTC Client socket (2) | Closed.
2025-07-22 15:10:46.032 | HD Request # 6 | Downloading Intraday chart data for F.US.ENQU25 to the file F.US.ENQU25.scid. Service: cme
2025-07-22 15:10:46.032 | HD Request # 6 | Download start date-time: 2025-07-22 15:10:08.000000. File last date-time: 2025-07-22 15:10:08.109000
2025-07-22 15:10:46.032 | HD Request # 6 | Using server: ds32.sierracharts.com port 10150
2025-07-22 15:10:46.032 | Socket (2) | Creating socket.
2025-07-22 15:10:46.033 | Socket (2) | New receive buffer size: 0
2025-07-22 15:10:46.033 | Socket (2) | Connecting to IP: 69.39.70.248.
2025-07-22 15:10:46.144 | HD Request # 6 | Setting DTC encoding to Binary VLS
2025-07-22 15:10:46.144 | HD Request # 6 | Sending historical data logon request message.
2025-07-22 15:10:46.243 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-07-22 15:10:08. Record interval: 1. Symbol: NQU25
2025-07-22 15:10:46.296 | HD Request # 6 | Decompressing data.
2025-07-22 15:10:46.350 | HD Request # 6 | Receiving Intraday data for F.US.ENQU25 starting at 2025-07-22 15:10:08.109000
2025-07-22 15:10:46.350 | Socket (2) | CloseSocket call.
2025-07-22 15:10:46.351 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-07-22 15:10:46.351 | Historical data download thread signaled to stop.
2025-07-22 15:10:46.351 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-07-22 15:10:08.109000.
2025-07-22 15:10:46.351 | HD Request # 6 | Received 37 Intraday data records from 2025-07-22 15:10:08.109000 to 2025-07-22 15:10:46.158000 (38.0 seconds. Delay: 0.2 seconds) and wrote 37 records for F.US.ENQU25
2025-07-22 15:10:46.352 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-07-22 19:10:46.158000
2025-07-22 15:10:46.352 | HD Request # 6 | Completion time: 0s.
2025-07-22 15:10:46.352 | HD Request # 6 | Intraday data download complete for F.US.ENQU25. Unique request ID: 6
2025-07-22 15:10:46.352 | Removing historical data download ID 6.
2025-07-22 15:10:46.352 | Real-time Intraday chart data file updates started for F.US.ENQU25
2025-07-22 15:10:46.353 | Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQU25.scid. Thread ID: 10192
2025-07-22 15:10:46.353 | Intraday chart data file opened for F.US.ENQU25
2025-07-22 15:10:46.353 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-07-22 15:10:46.353 | No download requests in the queue to start downloads for.
2025-07-22 15:10:46.353 | Historical data for F.US.ENQU25 is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-07-22 15:10:46.404 | Socket (2) | Socket gracefully closed by remote side.
2025-07-22 15:10:46.404 | Socket (2) | Closed.
2025-07-22 15:11:15.967 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-07-22 15:11:15.968 | DTC Client socket (2) | Creating socket.
2025-07-22 15:11:15.968 | DTC Client socket (2) | New receive buffer size: 0
2025-07-22 15:11:15.968 | DTC Client socket (2) | Connecting to IP: 67.214.125.6.
2025-07-22 15:11:16.021 | Denali Data Feed | Network connection to server complete.
2025-07-22 15:11:16.021 | Denali Data Feed | Starting socket receive thread.
2025-07-22 15:11:16.022 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-07-22 15:11:16.100 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-07-22 15:11:16.100 | Denali Data Feed | Sending logon request message.
2025-07-22 15:11:16.522 | Denali Data Feed | Received logon response.
2025-07-22 15:11:16.522 | Denali Data Feed | Server Name: RealTimeServer.
2025-07-22 15:11:16.522 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-07-22 15:11:16.522 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-07-22 15:11:16.522 | Denali Data Feed | Failed connections: 217
2025-07-22 15:11:16.522 | Denali Data Feed | Waiting for socket receive thread to end
2025-07-22 15:11:16.523 | DTC Client socket (2) | CloseSocket call.
2025-07-22 15:11:16.523 | Denali Data Feed | Disconnected from the server.
2025-07-22 15:11:16.523 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-07-22 15:11:16.523 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-07-22 15:11:16.576 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-07-22 15:11:16.576 | DTC Client socket (2) | Closed.
2025-07-22 15:12:01.403 | File >> Disconnect selected.
2025-07-22 15:12:01.403 | CQG WebAPI | Sending Web API Logoff message.
2025-07-22 15:12:01.403 | CQG WebSocket socket (1) | CloseSocket call.
2025-07-22 15:12:01.403 | CQG WebSocket | WebSocket closed.
2025-07-22 15:12:01.403 | CQG WebAPI | WebSocket closed.
2025-07-22 15:12:01.403 | CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0
2025-07-22 15:12:01.403 | DTC Client socket (0) | CloseSocket call.
2025-07-22 15:12:01.403 | Denali Data Feed | Disconnected from the server.
2025-07-22 15:12:01.403 | CQG WebAPI | Disconnected.
2025-07-22 15:12:01.451 | CQG WebSocket socket (1) | Write has completed. Shutdown being performed.
2025-07-22 15:12:01.451 | CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close.
2025-07-22 15:12:01.500 | CQG WebSocket socket (1) | Socket gracefully closed by remote side.
2025-07-22 15:12:01.500 | CQG WebSocket socket (1) | Closed.
2025-07-22 15:12:02.309 |
[2025-07-22 19:36:15]
I went to the activation page and set the #of systems to 2 and it resolved the data issue. The only question i have now is just wanted to make sure the orders will still be routed to my account the same way. In other words, does enabling support for SC data in the SrvSet affect the order routing?
[2025-07-22 19:55:05]
John - SC Support - Posts: 48555
You have everything correct now. With regards to what you did, the information related to this is here:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
The order routing is NOT affected in any way with regards to the use of Sierra Chart data or other data. The orders are routed to the service that is selected in "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service". Refer to the following:
Denali Exchange Data Feed: Integration with Trading Services
