Date/Time: Thu, 19 Nov 2026 11:17:02 +0000
fOOTPRINT
View Count: 808
[2024-11-21 21:27:51]
User785536 - Posts: 12
hELLO,
I AM TRYING TO USE FOOTPRINT FOR SPY. THE NUMBERS ARE TIGHTLY BUNCHED WITHIN THE CANDLES. ANY SUGGESTIONS?
https://www.sierrachart.com/image.php?Image=1732224412727.png
imageScreenshot 2024-11-21 141529.png / V - Attached On 2024-11-21 21:16:16 UTC - Size: 71.91 KB - 164 views
[2024-11-21 22:18:25]
Refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
[2024-11-25 23:01:16]
I recently decided to join top step. I am reaching out to see what I need from them or you in order to trade footprint.
[2024-11-26 00:07:44]
I mean what data subscription package do I need with sierra charts or from them.
[2024-11-26 14:43:57]
You are currently on the Integrated Advanced package, so you are fine with this package to connect to TopStep and get data.
TopStep uses Rithmic, so you can get your data either from Rithmic or from us. We do recommend using our data, as Rithmic has a lack of historical data.
The one thing you need to keep in mind if you want to get your data from us is that you need to have a live, funded, futures trading account in order to qualify for the non-professional exchange fees for the CME Group. And you need to connect your Sierra Chart software to that account at least once a month for verification. Note that Prop Firm accounts like TopStep do not count towards this requirement. Refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Once you have worked out the above, then you can follow the instructions at the following link to setup the data:
