Date/Time: Thu, 19 Nov 2026 13:09:32 +0000
Chart Live data lagging behind
View Count: 1874
| [2024-08-21 08:22:27] |
| User838995 - Posts: 22 |
Hi, I am in Alberta Canada. My computer time is synced and correct. I am exactly 2 hours behind Newyork time. But chart live data is lagging behind at least 1-2 minutes. Please give me step by step instructions so that I can fix it. Thank you. K.A https://www.sierrachart.com/image.php?Image=1724228327990.png https://www.sierrachart.com/image.php?Image=1724227499502.png https://www.sierrachart.com/image.php?Image=1724227313758.png |
| [2024-08-21 19:29:57] |
| Sierra_Chart Engineering - Posts: 25441 |
First make sure your computer's clock is set accurately: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating And then add the Data Delay chart header field: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-29 09:18:36] |
First make sure your computer's clock is set accurately: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Computer clock is set accurately. And then add the Data Delay chart header field: Working With Charts: Region Data Line / Chart Header Second step, What do I exactly do or add here? Thank you |
| [2024-08-29 14:15:10] |
| John - SC Support - Posts: 48583 |
For the Chart Header there is an item named "Data Delay". Add this to the Chart Header and make sure it is in a position that you will be able to view it. Once that is on the chart, then tell us what it shows (the item is prefixed with "DD:". This gives the difference between your computer clock and the timestamps of the data. Tell us what it shows. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-29 19:24:26] |
https://www.sierrachart.com/image.php?Image=172495921861.png first it was 00. Then 12 seconds then 4 seconds. Lagging time varies. Note Everyday, I am learning something new of Sierra chart. Thanks to all of you guys. K.A |
| [2024-08-29 19:37:07] |
This kind of fluctuation is going to imply a latency in your Internet connection to the data feed. This is not something we can help with in general. But, we do have the ability for you to do some troubleshooting of this with Sierra Chart. Refer to the following: Prices / Data Falling Behind: 4.16 - Monitoring Sierra Chart Data Feed Performance from Perspective of Server For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-08-29 21:01:39] |
I will try to do the trouble shooting and get back to you. Thankyou. Another question: I have a Williams Fractal showing as Diamonds at Support and Resistance on my chart. I also have Swing High & low ongoing DASH Line. I want to add/attach Price on Diamond and on Swing High low. How do I accomplish this. Attached image no.1 shows my Chart as it is now. https://www.sierrachart.com/image.php?Image=1724964636808.png To Copy from Below Chart Image. Attached Image no.2 shows navy blue price numbers on Aqua Diamonds and price numbers attached to Green, Aqua Swing Highs & lows. This is what I want to ADD /Copy to my chart. Thank you K.A |
| Attachment Deleted. |
| [2024-08-30 13:57:44] |
We answered your other question at the following post: Chart Live data lagging behind . For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
