Date/Time: Sun, 19 May 2024 00:53:21 +0000
1:1 Crack Spreads
View Count: 108
[2024-04-18 20:02:53] |
User417302 - Posts: 66 |
How can I create 1:1 crack spreads for both RB and HO against CL? Also would want to do a 1:1 spread for NG/CL. Thanks, |
[2024-04-18 21:14:28] |
If the exchange already has these spreads, then you can get the data from the exchange. Refer to the following: Denali Exchange Data Feed: Using Denali Futures Spread Data with Trading Service Otherwise, you can create charts for these by using the "Custom Calculated Symbols" feature. Refer to the following: Custom Calculated Symbols If you want to trade a custom spread, then refer to the following: Spread Order Entry Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
