Date/Time: Sun, 05 May 2024 04:40:13 +0000
Data problems and chart problems
View Count: 1642
[2014-08-03 11:22:20] |
User86586 - Posts: 5 |
Hello I have just paid for 3 months level 5 access, CME full data, and ICE data with the SC data service. I have the following questions which I have not been able to resolve myself. I am moving from using TWS and trying your package for the next 3 months. At the moment what is being presented n screen just does not make sense to me. My issues are as follows and I would appreciate if you could assist me with understand the issues; 1 I have 4 e-mini contracts on screen. ES, YM, and NQ. I have tried to add TF but it doesn't seen to exist in your search facility. Instead there is a RJU14 contract. Is this the e-mini TF? 2 the charts only display until the following dates; ES until 25-7-14 @ 2:19. YM chart until 25-7-14 @ 5:28, NQ chart until 27-7-14 @ 24:00. I have turned on full session data. Where is the rest of the data and missing days and sessions? 3 In your literature it states M will display when using SC real time data. I cannot see this mark anywhere to indicate real time access is enabled. 4 All 4 charts on screen show different days and times, and scales. It is impossible to monitor and compare the 4 contracts together simultaneously. I have tried to configure scale and time frames but have not been able to achieve any meaningful synchronisation between them. 5 I am very confused about what time is being displayed at the bottom of the chart. I am located in Japan, however want all charts to display New York time. I have changed setting in global settings but i do not know if this is actually reflected in the chart screens, as there is no indication of what chart is on what time. I cannot match any of the displayed times to any time, local or otherwise. I am due to start test the software for 3 months starting on Monday at NY market cash open, but currently I cannot understand what is being displayed on the 4 charts or synchronise the time and scale between them, so I'm not able to currently use the package for my trade plan. Could you lease help me solve these issues. I will continue to search for a solution to my questions on your support sites, but I have been messing with this a couple of days, and still don't have a set up on screen that is useful to me. I have sent the log to you directly from the software. I would appreciate the help. Yours Faithfully Neil Hawke. |
[2014-08-04 07:08:46] |
1, 2, 3. You need to set the Global Settings >> Data/Trade Service Settings >> Service to "Interactive Brokers" to access the CME data. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Otherwise you have to pay substantially higher exchange fees. If you no longer have an Interactive Brokers account or with another trading service, you will have to pay substantially for CME data. The symbols you need to use in Sierra Chart must correspond to the Data or Trading service you are using. So in this case you need to use the Interactive Broker symbols you find in File >> Find Symbol. You will still get the data from the Sierra Chart data feed. 4. This is too vague for us to understand. Provide an image of 2, but not more, of the charts, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image 5. If you have set the time zone to New York time, then the timescale of the charts most certainly will be that time. However, charts can be independently set to any time zone separate from the global time zone setting. All of this is covered in the time zone documentation: https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html We had a look at the Message Log and your computer time zone and clock settings are correct: Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-03 06:12:34 2014-08-03 19:12:34 Local computer clock time | 2014-08-03 06:12:34 2014-08-03 10:12:34 GMT time | 2014-08-03 06:12:34 2014-08-03 06:12:34 Time zone adjusted time | 2014-08-03 06:12:34 Time difference to server time: 1 seconds. | 2014-08-03 06:12:34 Most likely if you still it are confused about the timescale, the issue is not related to the time zone but something with the Session Times and the time frame per bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-04 07:10:06
[2014-08-04 07:12:24] |
One note about exchange fees, if these are the only CME symbols you need: ES, YM, and NQ Then you only need the mini exchange fees if you do not have a funded trading account. These are currently not supported by the Sierra Chart Exchange Data Feed. However, in this case you could subscribe to the Barchart Data service which supports the lower-cost exchange fees. So we can help you get this worked out one way or another. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-04 07:13:50
[2014-08-05 01:43:00] |
Hi SC thanks for the response. I've sorted most of it out by doing the following; 1. Turned off data in TWS. Now just getting indexes 2. Changed provider to interactive brokers 3. I signed up to bar chart CME data and the SC feed along with ICE for the TF contract Now have the following issues; A. The is an [M] on the TF contract, but not on ES, YM, or NQ. Is this real time data now coming from bar chart? How do I know this? B. when I attempt to download historic data I only get data back to May 2014, how do I get daily bars back to 2009? Apart from that all is going well. It's worth noting that your package is the only one that works reliably with a Mac book pro retina on multi screen through parallels. So nice work! Had all sorts of problems with other packages with this set up. So thanks! Also do you have any references for specific C++ programming in Sierra charts or C++ for trading packages; or know of any? I can use C++ but struggling with the programming specifics related to charting packages. Any advice or links to appropriate references would be appreciated. Kind Regards Neil. |
[2014-08-05 02:30:56] |
What exactly did you do in regards to this?: 3. I signed up to bar chart CME data
Before doing anything that involves money, please consult with us. Any mistakes with subscriptions or exchange fees, create costly problems for the user and for us and we want to avoid them to begin with. As long as you can connect to Interactive Brokers, you will get the CME data that you have activated through the Sierra Chart Exchange Data Feed. B. when I attempt to download historic data I only get data back to May 2014, how do I get daily bars back to 2009?
Refer to help topic 42.1 here:Http://www.sierrachart.com/index.php?page=doc/helpdetails42.html This page contains links to the relevant C++ references: http://www.sierrachart.com/index.php?page=doc/doc_Contents.php#AdvancedCustomStudySystemInterfaceandLanguage The Sierra Chart website has all the information that you should need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-05 03:02:07] |
Hi 3. I activated the data feed in SC for the following services i. SC feed ii. ice data iii. Full CME group data I have an active IB account. Should the charts from CME group display the [M] because I'm not seeing it. If this is ok then no problem. I have attached a screen shot of the activation screen. B. I will review the topics you suggest. Thanks and Regards Neil. |
Attachment Deleted. |
[2014-08-05 04:31:23] |
What you did is correct. You should definitely see the [M] at the top of the charts for CME Symbols. We want you to update the Symbol Settings and reconnect to the data feed. Here are the instructions: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps If you still do not see the [M], then post a copy of the Message Log, by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-05 23:33:51] |
Hi I did as instructed still no [M]. Below is the message log. Neil. Software version: 1157 | 2014-08-05 19:21:08 Usage end date: 2014-10-27 | 2014-08-05 19:21:08 Enabled for: Advanced Features. | 2014-08-05 19:21:08 Enabled for: Advanced Features 2. | 2014-08-05 19:21:08 Enabled for: Sierra Chart Historical Data Service. | 2014-08-05 19:21:08 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-08-05 19:21:08 Enabled for: CME, CBOT, NYMEX, COMEX exchanges for trading accounts. | 2014-08-05 19:21:08 Received 1 data feed usernames. | 2014-08-05 19:21:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-08-05 19:21:08 Active service: Interactive Brokers | 2014-08-05 19:21:08 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-08-05 19:21:08 2014-08-06 08:21:08 Local computer clock time | 2014-08-05 19:21:08 2014-08-05 23:21:08 GMT time | 2014-08-05 19:21:08 2014-08-05 19:21:08 Time zone adjusted time | 2014-08-05 19:21:08 Time difference to server time: 0 seconds. | 2014-08-05 19:21:08 Program path: C:\SierraChart\ | 2014-08-05 19:21:08 Data Files path: C:\SierraChart\Data\ | 2014-08-05 19:21:08 OS Version Number: 6.2 | 2014-08-05 19:21:08 Checking for new symbol settings for ib | 2014-08-05 19:21:08 Symbol settings are up-to-date for ib | 2014-08-05 19:21:08 Limiting the number of days back for the continuous futures chart to 6.9979466 years based on the account type. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200709-GLOBEX to next contract occurs at 2007-09-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200712-GLOBEX to next contract occurs at 2007-12-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200803-GLOBEX to next contract occurs at 2008-03-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200806-GLOBEX to next contract occurs at 2008-06-12. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200809-GLOBEX to next contract occurs at 2008-09-11. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200812-GLOBEX to next contract occurs at 2008-12-11. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200903-GLOBEX to next contract occurs at 2009-03-12. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200906-GLOBEX to next contract occurs at 2009-06-11. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200909-GLOBEX to next contract occurs at 2009-09-10. | 2014-08-05 19:21:11 Date rule based rollover from NQ-200912-GLOBEX to next contract occurs at 2009-12-10. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201003-GLOBEX to next contract occurs at 2010-03-11. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201006-GLOBEX to next contract occurs at 2010-06-10. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201009-GLOBEX to next contract occurs at 2010-09-09. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201012-GLOBEX to next contract occurs at 2010-12-09. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201103-GLOBEX to next contract occurs at 2011-03-10. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201106-GLOBEX to next contract occurs at 2011-06-09. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201109-GLOBEX to next contract occurs at 2011-09-08. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201112-GLOBEX to next contract occurs at 2011-12-08. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201203-GLOBEX to next contract occurs at 2012-03-08. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201206-GLOBEX to next contract occurs at 2012-06-07. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201209-GLOBEX to next contract occurs at 2012-09-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201212-GLOBEX to next contract occurs at 2012-12-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201303-GLOBEX to next contract occurs at 2013-03-07. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201306-GLOBEX to next contract occurs at 2013-06-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201309-GLOBEX to next contract occurs at 2013-09-12. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201312-GLOBEX to next contract occurs at 2013-12-12. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201403-GLOBEX to next contract occurs at 2014-03-13. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201406-GLOBEX to next contract occurs at 2014-06-12. | 2014-08-05 19:21:11 Date rule based rollover from NQ-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-08-05 19:21:11 Intraday data file for NQ-200709-GLOBEX exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for NQ-200712-GLOBEX exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for NQ-200803-GLOBEX exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200806-GLOBEX for the date range from 2008-03-13 to 2008-06-12. | 2014-08-05 19:21:11 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200809-GLOBEX for the date range from 2008-06-12 to 2008-09-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200812-GLOBEX for the date range from 2008-09-11 to 2008-12-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200903-GLOBEX for the date range from 2008-12-11 to 2009-03-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200906-GLOBEX for the date range from 2009-03-12 to 2009-06-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200909-GLOBEX for the date range from 2009-06-11 to 2009-09-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-200912-GLOBEX for the date range from 2009-09-10 to 2009-12-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201003-GLOBEX for the date range from 2009-12-10 to 2010-03-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201006-GLOBEX for the date range from 2010-03-11 to 2010-06-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201009-GLOBEX for the date range from 2010-06-10 to 2010-09-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201012-GLOBEX for the date range from 2010-09-09 to 2010-12-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201103-GLOBEX for the date range from 2010-12-09 to 2011-03-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201106-GLOBEX for the date range from 2011-03-10 to 2011-06-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201109-GLOBEX for the date range from 2011-06-09 to 2011-09-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201112-GLOBEX for the date range from 2011-09-08 to 2011-12-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201203-GLOBEX for the date range from 2011-12-08 to 2012-03-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201206-GLOBEX for the date range from 2012-03-08 to 2012-06-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201209-GLOBEX for the date range from 2012-06-07 to 2012-09-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201212-GLOBEX for the date range from 2012-09-13 to 2012-12-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201303-GLOBEX for the date range from 2012-12-13 to 2013-03-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201306-GLOBEX for the date range from 2013-03-07 to 2013-06-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201309-GLOBEX for the date range from 2013-06-13 to 2013-09-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201312-GLOBEX for the date range from 2013-09-12 to 2013-12-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201403-GLOBEX for the date range from 2013-12-12 to 2014-03-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201406-GLOBEX for the date range from 2014-03-13 to 2014-06-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol NQ-201409-GLOBEX for the date range from 2014-06-12 to 0. | 2014-08-05 19:21:11 Symbols used for NQ-201409-GLOBEX continuous contract chart: | 2014-08-05 19:21:11 NQ-200709-GLOBEX | 2014-08-05 19:21:11 NQ-200712-GLOBEX | 2014-08-05 19:21:11 NQ-200803-GLOBEX | 2014-08-05 19:21:11 NQ-200806-GLOBEX | 2014-08-05 19:21:11 NQ-200809-GLOBEX | 2014-08-05 19:21:11 NQ-200812-GLOBEX | 2014-08-05 19:21:11 NQ-200903-GLOBEX | 2014-08-05 19:21:11 NQ-200906-GLOBEX | 2014-08-05 19:21:11 NQ-200909-GLOBEX | 2014-08-05 19:21:11 NQ-200912-GLOBEX | 2014-08-05 19:21:11 NQ-201003-GLOBEX | 2014-08-05 19:21:11 NQ-201006-GLOBEX | 2014-08-05 19:21:11 NQ-201009-GLOBEX | 2014-08-05 19:21:11 NQ-201012-GLOBEX | 2014-08-05 19:21:11 NQ-201103-GLOBEX | 2014-08-05 19:21:11 NQ-201106-GLOBEX | 2014-08-05 19:21:11 NQ-201109-GLOBEX | 2014-08-05 19:21:11 NQ-201112-GLOBEX | 2014-08-05 19:21:11 NQ-201203-GLOBEX | 2014-08-05 19:21:11 NQ-201206-GLOBEX | 2014-08-05 19:21:11 NQ-201209-GLOBEX | 2014-08-05 19:21:11 NQ-201212-GLOBEX | 2014-08-05 19:21:11 NQ-201303-GLOBEX | 2014-08-05 19:21:11 NQ-201306-GLOBEX | 2014-08-05 19:21:11 NQ-201309-GLOBEX | 2014-08-05 19:21:11 NQ-201312-GLOBEX | 2014-08-05 19:21:11 NQ-201403-GLOBEX | 2014-08-05 19:21:11 NQ-201406-GLOBEX | 2014-08-05 19:21:11 NQ-201409-GLOBEX | 2014-08-05 19:21:11 Limiting the number of days back for the continuous futures chart to 6.9979466 years based on the account type. | 2014-08-05 19:21:11 Date rule based rollover from YM-200709-ECBOT to next contract occurs at 2007-09-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-200712-ECBOT to next contract occurs at 2007-12-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-200803-ECBOT to next contract occurs at 2008-03-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-200806-ECBOT to next contract occurs at 2008-06-12. | 2014-08-05 19:21:11 Date rule based rollover from YM-200809-ECBOT to next contract occurs at 2008-09-11. | 2014-08-05 19:21:11 Date rule based rollover from YM-200812-ECBOT to next contract occurs at 2008-12-11. | 2014-08-05 19:21:11 Date rule based rollover from YM-200903-ECBOT to next contract occurs at 2009-03-12. | 2014-08-05 19:21:11 Date rule based rollover from YM-200906-ECBOT to next contract occurs at 2009-06-11. | 2014-08-05 19:21:11 Date rule based rollover from YM-200909-ECBOT to next contract occurs at 2009-09-10. | 2014-08-05 19:21:11 Date rule based rollover from YM-200912-ECBOT to next contract occurs at 2009-12-10. | 2014-08-05 19:21:11 Date rule based rollover from YM-201003-ECBOT to next contract occurs at 2010-03-11. | 2014-08-05 19:21:11 Date rule based rollover from YM-201006-ECBOT to next contract occurs at 2010-06-10. | 2014-08-05 19:21:11 Date rule based rollover from YM-201009-ECBOT to next contract occurs at 2010-09-09. | 2014-08-05 19:21:11 Date rule based rollover from YM-201012-ECBOT to next contract occurs at 2010-12-09. | 2014-08-05 19:21:11 Date rule based rollover from YM-201103-ECBOT to next contract occurs at 2011-03-10. | 2014-08-05 19:21:11 Date rule based rollover from YM-201106-ECBOT to next contract occurs at 2011-06-09. | 2014-08-05 19:21:11 Date rule based rollover from YM-201109-ECBOT to next contract occurs at 2011-09-08. | 2014-08-05 19:21:11 Date rule based rollover from YM-201112-ECBOT to next contract occurs at 2011-12-08. | 2014-08-05 19:21:11 Date rule based rollover from YM-201203-ECBOT to next contract occurs at 2012-03-08. | 2014-08-05 19:21:11 Date rule based rollover from YM-201206-ECBOT to next contract occurs at 2012-06-07. | 2014-08-05 19:21:11 Date rule based rollover from YM-201209-ECBOT to next contract occurs at 2012-09-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-201212-ECBOT to next contract occurs at 2012-12-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-201303-ECBOT to next contract occurs at 2013-03-07. | 2014-08-05 19:21:11 Date rule based rollover from YM-201306-ECBOT to next contract occurs at 2013-06-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-201309-ECBOT to next contract occurs at 2013-09-12. | 2014-08-05 19:21:11 Date rule based rollover from YM-201312-ECBOT to next contract occurs at 2013-12-12. | 2014-08-05 19:21:11 Date rule based rollover from YM-201403-ECBOT to next contract occurs at 2014-03-13. | 2014-08-05 19:21:11 Date rule based rollover from YM-201406-ECBOT to next contract occurs at 2014-06-12. | 2014-08-05 19:21:11 Date rule based rollover from YM-201409-ECBOT to next contract occurs at 2014-09-11. | 2014-08-05 19:21:11 Intraday data file for YM-200709-ECBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for YM-200712-ECBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for YM-200803-ECBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for YM-200806-ECBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for YM-200809-ECBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for YM-200812-ECBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-200903-ECBOT for the date range from 2008-12-11 to 2009-03-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-200906-ECBOT for the date range from 2009-03-12 to 2009-06-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-200909-ECBOT for the date range from 2009-06-11 to 2009-09-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-200912-ECBOT for the date range from 2009-09-10 to 2009-12-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201003-ECBOT for the date range from 2009-12-10 to 2010-03-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201006-ECBOT for the date range from 2010-03-11 to 2010-06-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201009-ECBOT for the date range from 2010-06-10 to 2010-09-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201012-ECBOT for the date range from 2010-09-09 to 2010-12-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201103-ECBOT for the date range from 2010-12-09 to 2011-03-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201106-ECBOT for the date range from 2011-03-10 to 2011-06-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201109-ECBOT for the date range from 2011-06-09 to 2011-09-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201112-ECBOT for the date range from 2011-09-08 to 2011-12-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201203-ECBOT for the date range from 2011-12-08 to 2012-03-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201206-ECBOT for the date range from 2012-03-08 to 2012-06-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201209-ECBOT for the date range from 2012-06-07 to 2012-09-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201212-ECBOT for the date range from 2012-09-13 to 2012-12-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201303-ECBOT for the date range from 2012-12-13 to 2013-03-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201306-ECBOT for the date range from 2013-03-07 to 2013-06-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201309-ECBOT for the date range from 2013-06-13 to 2013-09-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201312-ECBOT for the date range from 2013-09-12 to 2013-12-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201403-ECBOT for the date range from 2013-12-12 to 2014-03-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201406-ECBOT for the date range from 2014-03-13 to 2014-06-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol YM-201409-ECBOT for the date range from 2014-06-12 to 0. | 2014-08-05 19:21:11 Symbols used for YM-201409-ECBOT continuous contract chart: | 2014-08-05 19:21:11 YM-200709-ECBOT | 2014-08-05 19:21:11 YM-200712-ECBOT | 2014-08-05 19:21:11 YM-200803-ECBOT | 2014-08-05 19:21:11 YM-200806-ECBOT | 2014-08-05 19:21:11 YM-200809-ECBOT | 2014-08-05 19:21:11 YM-200812-ECBOT | 2014-08-05 19:21:11 YM-200903-ECBOT | 2014-08-05 19:21:11 YM-200906-ECBOT | 2014-08-05 19:21:11 YM-200909-ECBOT | 2014-08-05 19:21:11 YM-200912-ECBOT | 2014-08-05 19:21:11 YM-201003-ECBOT | 2014-08-05 19:21:11 YM-201006-ECBOT | 2014-08-05 19:21:11 YM-201009-ECBOT | 2014-08-05 19:21:11 YM-201012-ECBOT | 2014-08-05 19:21:11 YM-201103-ECBOT | 2014-08-05 19:21:11 YM-201106-ECBOT | 2014-08-05 19:21:11 YM-201109-ECBOT | 2014-08-05 19:21:11 YM-201112-ECBOT | 2014-08-05 19:21:11 YM-201203-ECBOT | 2014-08-05 19:21:11 YM-201206-ECBOT | 2014-08-05 19:21:11 YM-201209-ECBOT | 2014-08-05 19:21:11 YM-201212-ECBOT | 2014-08-05 19:21:11 YM-201303-ECBOT | 2014-08-05 19:21:11 YM-201306-ECBOT | 2014-08-05 19:21:11 YM-201309-ECBOT | 2014-08-05 19:21:11 YM-201312-ECBOT | 2014-08-05 19:21:11 YM-201403-ECBOT | 2014-08-05 19:21:11 YM-201406-ECBOT | 2014-08-05 19:21:11 YM-201409-ECBOT | 2014-08-05 19:21:11 Limiting the number of days back for the continuous futures chart to 6.9979466 years based on the account type. | 2014-08-05 19:21:11 Date rule based rollover from TF-200709-NYBOT to next contract occurs at 2007-09-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-200712-NYBOT to next contract occurs at 2007-12-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-200803-NYBOT to next contract occurs at 2008-03-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-200806-NYBOT to next contract occurs at 2008-06-12. | 2014-08-05 19:21:11 Date rule based rollover from TF-200809-NYBOT to next contract occurs at 2008-09-11. | 2014-08-05 19:21:11 Date rule based rollover from TF-200812-NYBOT to next contract occurs at 2008-12-11. | 2014-08-05 19:21:11 Date rule based rollover from TF-200903-NYBOT to next contract occurs at 2009-03-12. | 2014-08-05 19:21:11 Date rule based rollover from TF-200906-NYBOT to next contract occurs at 2009-06-11. | 2014-08-05 19:21:11 Date rule based rollover from TF-200909-NYBOT to next contract occurs at 2009-09-10. | 2014-08-05 19:21:11 Date rule based rollover from TF-200912-NYBOT to next contract occurs at 2009-12-10. | 2014-08-05 19:21:11 Date rule based rollover from TF-201003-NYBOT to next contract occurs at 2010-03-11. | 2014-08-05 19:21:11 Date rule based rollover from TF-201006-NYBOT to next contract occurs at 2010-06-10. | 2014-08-05 19:21:11 Date rule based rollover from TF-201009-NYBOT to next contract occurs at 2010-09-09. | 2014-08-05 19:21:11 Date rule based rollover from TF-201012-NYBOT to next contract occurs at 2010-12-09. | 2014-08-05 19:21:11 Date rule based rollover from TF-201103-NYBOT to next contract occurs at 2011-03-10. | 2014-08-05 19:21:11 Date rule based rollover from TF-201106-NYBOT to next contract occurs at 2011-06-09. | 2014-08-05 19:21:11 Date rule based rollover from TF-201109-NYBOT to next contract occurs at 2011-09-08. | 2014-08-05 19:21:11 Date rule based rollover from TF-201112-NYBOT to next contract occurs at 2011-12-08. | 2014-08-05 19:21:11 Date rule based rollover from TF-201203-NYBOT to next contract occurs at 2012-03-08. | 2014-08-05 19:21:11 Date rule based rollover from TF-201206-NYBOT to next contract occurs at 2012-06-07. | 2014-08-05 19:21:11 Date rule based rollover from TF-201209-NYBOT to next contract occurs at 2012-09-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-201212-NYBOT to next contract occurs at 2012-12-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-201303-NYBOT to next contract occurs at 2013-03-07. | 2014-08-05 19:21:11 Date rule based rollover from TF-201306-NYBOT to next contract occurs at 2013-06-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-201309-NYBOT to next contract occurs at 2013-09-12. | 2014-08-05 19:21:11 Date rule based rollover from TF-201312-NYBOT to next contract occurs at 2013-12-12. | 2014-08-05 19:21:11 Date rule based rollover from TF-201403-NYBOT to next contract occurs at 2014-03-13. | 2014-08-05 19:21:11 Date rule based rollover from TF-201406-NYBOT to next contract occurs at 2014-06-12. | 2014-08-05 19:21:11 Date rule based rollover from TF-201409-NYBOT to next contract occurs at 2014-09-11. | 2014-08-05 19:21:11 Intraday data file for TF-200709-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-200712-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-200803-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-200806-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-200809-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-200812-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-200903-NYBOT for the date range from 2008-12-11 to 2009-03-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-200906-NYBOT for the date range from 2009-03-12 to 2009-06-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-200909-NYBOT for the date range from 2009-06-11 to 2009-09-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-200912-NYBOT for the date range from 2009-09-10 to 2009-12-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201003-NYBOT for the date range from 2009-12-10 to 2010-03-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201006-NYBOT for the date range from 2010-03-11 to 2010-06-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201009-NYBOT for the date range from 2010-06-10 to 2010-09-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201012-NYBOT for the date range from 2010-09-09 to 2010-12-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201103-NYBOT for the date range from 2010-12-09 to 2011-03-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201106-NYBOT for the date range from 2011-03-10 to 2011-06-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201109-NYBOT for the date range from 2011-06-09 to 2011-09-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201112-NYBOT for the date range from 2011-09-08 to 2011-12-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201203-NYBOT for the date range from 2011-12-08 to 2012-03-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201206-NYBOT for the date range from 2012-03-08 to 2012-06-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201209-NYBOT for the date range from 2012-06-07 to 2012-09-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201212-NYBOT for the date range from 2012-09-13 to 2012-12-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201303-NYBOT for the date range from 2012-12-13 to 2013-03-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201306-NYBOT for the date range from 2013-03-07 to 2013-06-13. | 2014-08-05 19:21:11 Intraday data file for TF-201309-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-201312-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-201403-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for TF-201406-NYBOT exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Checking Intraday data file for symbol TF-201409-NYBOT for the date range from 2014-06-12 to 0. | 2014-08-05 19:21:11 Symbols used for TF-201409-NYBOT continuous contract chart: | 2014-08-05 19:21:11 TF-200709-NYBOT | 2014-08-05 19:21:11 TF-200712-NYBOT | 2014-08-05 19:21:11 TF-200803-NYBOT | 2014-08-05 19:21:11 TF-200806-NYBOT | 2014-08-05 19:21:11 TF-200809-NYBOT | 2014-08-05 19:21:11 TF-200812-NYBOT | 2014-08-05 19:21:11 TF-200903-NYBOT | 2014-08-05 19:21:11 TF-200906-NYBOT | 2014-08-05 19:21:11 TF-200909-NYBOT | 2014-08-05 19:21:11 TF-200912-NYBOT | 2014-08-05 19:21:11 TF-201003-NYBOT | 2014-08-05 19:21:11 TF-201006-NYBOT | 2014-08-05 19:21:11 TF-201009-NYBOT | 2014-08-05 19:21:11 TF-201012-NYBOT | 2014-08-05 19:21:11 TF-201103-NYBOT | 2014-08-05 19:21:11 TF-201106-NYBOT | 2014-08-05 19:21:11 TF-201109-NYBOT | 2014-08-05 19:21:11 TF-201112-NYBOT | 2014-08-05 19:21:11 TF-201203-NYBOT | 2014-08-05 19:21:11 TF-201206-NYBOT | 2014-08-05 19:21:11 TF-201209-NYBOT | 2014-08-05 19:21:11 TF-201212-NYBOT | 2014-08-05 19:21:11 TF-201303-NYBOT | 2014-08-05 19:21:11 TF-201306-NYBOT | 2014-08-05 19:21:11 TF-201309-NYBOT | 2014-08-05 19:21:11 TF-201312-NYBOT | 2014-08-05 19:21:11 TF-201403-NYBOT | 2014-08-05 19:21:11 TF-201406-NYBOT | 2014-08-05 19:21:11 TF-201409-NYBOT | 2014-08-05 19:21:11 Limiting the number of days back for the continuous futures chart to 6.9979466 years based on the account type. | 2014-08-05 19:21:11 Date rule based rollover from ES-200709-GLOBEX to next contract occurs at 2007-09-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-200712-GLOBEX to next contract occurs at 2007-12-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-200803-GLOBEX to next contract occurs at 2008-03-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-200806-GLOBEX to next contract occurs at 2008-06-12. | 2014-08-05 19:21:11 Date rule based rollover from ES-200809-GLOBEX to next contract occurs at 2008-09-11. | 2014-08-05 19:21:11 Date rule based rollover from ES-200812-GLOBEX to next contract occurs at 2008-12-11. | 2014-08-05 19:21:11 Date rule based rollover from ES-200903-GLOBEX to next contract occurs at 2009-03-12. | 2014-08-05 19:21:11 Date rule based rollover from ES-200906-GLOBEX to next contract occurs at 2009-06-11. | 2014-08-05 19:21:11 Date rule based rollover from ES-200909-GLOBEX to next contract occurs at 2009-09-10. | 2014-08-05 19:21:11 Date rule based rollover from ES-200912-GLOBEX to next contract occurs at 2009-12-10. | 2014-08-05 19:21:11 Date rule based rollover from ES-201003-GLOBEX to next contract occurs at 2010-03-11. | 2014-08-05 19:21:11 Date rule based rollover from ES-201006-GLOBEX to next contract occurs at 2010-06-10. | 2014-08-05 19:21:11 Date rule based rollover from ES-201009-GLOBEX to next contract occurs at 2010-09-09. | 2014-08-05 19:21:11 Date rule based rollover from ES-201012-GLOBEX to next contract occurs at 2010-12-09. | 2014-08-05 19:21:11 Date rule based rollover from ES-201103-GLOBEX to next contract occurs at 2011-03-10. | 2014-08-05 19:21:11 Date rule based rollover from ES-201106-GLOBEX to next contract occurs at 2011-06-09. | 2014-08-05 19:21:11 Date rule based rollover from ES-201109-GLOBEX to next contract occurs at 2011-09-08. | 2014-08-05 19:21:11 Date rule based rollover from ES-201112-GLOBEX to next contract occurs at 2011-12-08. | 2014-08-05 19:21:11 Date rule based rollover from ES-201203-GLOBEX to next contract occurs at 2012-03-08. | 2014-08-05 19:21:11 Date rule based rollover from ES-201206-GLOBEX to next contract occurs at 2012-06-07. | 2014-08-05 19:21:11 Date rule based rollover from ES-201209-GLOBEX to next contract occurs at 2012-09-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-201212-GLOBEX to next contract occurs at 2012-12-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-201303-GLOBEX to next contract occurs at 2013-03-07. | 2014-08-05 19:21:11 Date rule based rollover from ES-201306-GLOBEX to next contract occurs at 2013-06-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-201309-GLOBEX to next contract occurs at 2013-09-12. | 2014-08-05 19:21:11 Date rule based rollover from ES-201312-GLOBEX to next contract occurs at 2013-12-12. | 2014-08-05 19:21:11 Date rule based rollover from ES-201403-GLOBEX to next contract occurs at 2014-03-13. | 2014-08-05 19:21:11 Date rule based rollover from ES-201406-GLOBEX to next contract occurs at 2014-06-12. | 2014-08-05 19:21:11 Date rule based rollover from ES-201409-GLOBEX to next contract occurs at 2014-09-11. | 2014-08-05 19:21:11 Intraday data file for ES-200709-GLOBEX exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for ES-200712-GLOBEX exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Intraday data file for ES-200803-GLOBEX exists and is empty. Skipping Intraday data download. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200806-GLOBEX for the date range from 2008-03-13 to 2008-06-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200809-GLOBEX for the date range from 2008-06-12 to 2008-09-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200812-GLOBEX for the date range from 2008-09-11 to 2008-12-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200903-GLOBEX for the date range from 2008-12-11 to 2009-03-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200906-GLOBEX for the date range from 2009-03-12 to 2009-06-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200909-GLOBEX for the date range from 2009-06-11 to 2009-09-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-200912-GLOBEX for the date range from 2009-09-10 to 2009-12-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201003-GLOBEX for the date range from 2009-12-10 to 2010-03-11. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201006-GLOBEX for the date range from 2010-03-11 to 2010-06-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201009-GLOBEX for the date range from 2010-06-10 to 2010-09-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201012-GLOBEX for the date range from 2010-09-09 to 2010-12-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201103-GLOBEX for the date range from 2010-12-09 to 2011-03-10. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201106-GLOBEX for the date range from 2011-03-10 to 2011-06-09. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201109-GLOBEX for the date range from 2011-06-09 to 2011-09-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201112-GLOBEX for the date range from 2011-09-08 to 2011-12-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201203-GLOBEX for the date range from 2011-12-08 to 2012-03-08. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201206-GLOBEX for the date range from 2012-03-08 to 2012-06-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201209-GLOBEX for the date range from 2012-06-07 to 2012-09-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201212-GLOBEX for the date range from 2012-09-13 to 2012-12-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201303-GLOBEX for the date range from 2012-12-13 to 2013-03-07. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201306-GLOBEX for the date range from 2013-03-07 to 2013-06-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201309-GLOBEX for the date range from 2013-06-13 to 2013-09-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201312-GLOBEX for the date range from 2013-09-12 to 2013-12-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201403-GLOBEX for the date range from 2013-12-12 to 2014-03-13. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201406-GLOBEX for the date range from 2014-03-13 to 2014-06-12. | 2014-08-05 19:21:11 Checking Intraday data file for symbol ES-201409-GLOBEX for the date range from 2014-06-12 to 0. | 2014-08-05 19:21:11 Symbols used for ES-201409-GLOBEX continuous contract chart: | 2014-08-05 19:21:11 ES-200709-GLOBEX | 2014-08-05 19:21:11 ES-200712-GLOBEX | 2014-08-05 19:21:11 ES-200803-GLOBEX | 2014-08-05 19:21:11 ES-200806-GLOBEX | 2014-08-05 19:21:11 ES-200809-GLOBEX | 2014-08-05 19:21:11 ES-200812-GLOBEX | 2014-08-05 19:21:11 ES-200903-GLOBEX | 2014-08-05 19:21:11 ES-200906-GLOBEX | 2014-08-05 19:21:11 ES-200909-GLOBEX | 2014-08-05 19:21:11 ES-200912-GLOBEX | 2014-08-05 19:21:11 ES-201003-GLOBEX | 2014-08-05 19:21:11 ES-201006-GLOBEX | 2014-08-05 19:21:11 ES-201009-GLOBEX | 2014-08-05 19:21:11 ES-201012-GLOBEX | 2014-08-05 19:21:11 ES-201103-GLOBEX | 2014-08-05 19:21:11 ES-201106-GLOBEX | 2014-08-05 19:21:11 ES-201109-GLOBEX | 2014-08-05 19:21:11 ES-201112-GLOBEX | 2014-08-05 19:21:11 ES-201203-GLOBEX | 2014-08-05 19:21:11 ES-201206-GLOBEX | 2014-08-05 19:21:11 ES-201209-GLOBEX | 2014-08-05 19:21:11 ES-201212-GLOBEX | 2014-08-05 19:21:11 ES-201303-GLOBEX | 2014-08-05 19:21:11 ES-201306-GLOBEX | 2014-08-05 19:21:11 ES-201309-GLOBEX | 2014-08-05 19:21:11 ES-201312-GLOBEX | 2014-08-05 19:21:11 ES-201403-GLOBEX | 2014-08-05 19:21:11 ES-201406-GLOBEX | 2014-08-05 19:21:11 ES-201409-GLOBEX | 2014-08-05 19:21:11 Mapping NQ-200806-GLOBEX to NQM8. Service code: cme | 2014-08-05 19:21:11 HD Request # 2 - Downloading Intraday chart data for NQ-200806-GLOBEX to the file NQ-200806-GLOBEX.scid. Service: cme | 2014-08-05 19:21:11 HD Request # 2 - Truncating file to starting Date-Time of 2008-03-10 20:00:00 | 2014-08-05 19:21:11 HD Request # 2 - Download start Date-Time: 2008-03-10 19:59:59.0 | 2014-08-05 19:21:11 HD Request # 2 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:21:11 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:21:11 Socket (2136) - Connected. | 2014-08-05 19:21:11 HD Request # 2 - Sending historical data logon request message. | 2014-08-05 19:21:11 Mapping TF-201409-NYBOT to RJU14. Service code: ice.us | 2014-08-05 19:21:11 Socket (2024) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-05 19:21:12 Socket (2024) - Shutdown and closed. | 2014-08-05 19:21:12 Failed to connect to the data and trade server. | 2014-08-05 19:21:12 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-05 19:21:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-05 19:21:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-05 19:21:12 Disconnected from IB. | 2014-08-05 19:21:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-05 19:21:12 HD Request # 2 - Requesting Intraday data. Start Date-Time: 2008-03-10 19:59:59. Record interval: 1. Symbol: NQM8 | 2014-08-05 19:21:12 HD Request # 2 - Decompressing data. | 2014-08-05 19:21:12 HD Request # 2 - Receiving Intraday data for NQ-200806-GLOBEX starting at 2008-05-04 18:00:00 | 2014-08-05 19:21:12 HD Request # 2 - Timestamp of first Intraday data file record written: 2008-05-04 18:00:00 | 2014-08-05 19:21:12 Socket (2136) - Shutdown and closed. | 2014-08-05 19:21:13 The network socket for historical data has been closed. | 2014-08-05 19:21:13 HD Request # 2 - Historical data for NQ-200806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:13 HD Request # 2 - Received 32079 records from 2008-05-04 18:00:00 to 2008-06-20 14:20:00 (46.8 days) and wrote 32079 records for NQ-200806-GLOBEX | 2014-08-05 19:21:13 HD Request # 2 - Intraday download COMPLETE for NQ-200806-GLOBEX. Completion time: 2s | 2014-08-05 19:21:13 HD Request # 2 - Reloading Intraday charts for symbol. | 2014-08-05 19:21:13 Reloading all charts with filename: NQ-200806-GLOBEX.scid | 2014-08-05 19:21:13 Mapping YM-200903-ECBOT to YMH9. Service code: cbot | 2014-08-05 19:21:13 HD Request # 3 - Downloading Intraday chart data for YM-200903-ECBOT to the file YM-200903-ECBOT.scid. Service: cbot | 2014-08-05 19:21:13 HD Request # 3 - Truncating file to starting Date-Time of 2008-12-08 19:00:00 | 2014-08-05 19:21:13 HD Request # 3 - Download start Date-Time: 2008-12-08 18:59:59.0 | 2014-08-05 19:21:13 HD Request # 3 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:21:13 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:21:13 Socket (692) - Connected. | 2014-08-05 19:21:14 HD Request # 3 - Sending historical data logon request message. | 2014-08-05 19:21:14 NQ-201409-GLOBEX [C] 1 Min #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-08-05 19:21:14 Mapping NQ-201409-GLOBEX to NQU4. Service code: cme | 2014-08-05 19:21:14 HD Request # 3 - Requesting Intraday data. Start Date-Time: 2008-12-08 18:59:59. Record interval: 1. Symbol: YMH9 | 2014-08-05 19:21:15 Starting TWS auto-login thread. | 2014-08-05 19:21:15 HD Request # 3 - Decompressing data. | 2014-08-05 19:21:15 HD Request # 3 - Receiving Intraday data for YM-200903-ECBOT starting at 2008-12-28 19:01:00 | 2014-08-05 19:21:15 HD Request # 3 - Timestamp of first Intraday data file record written: 2008-12-28 19:01:00 | 2014-08-05 19:21:15 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-05 19:21:17 TWS auto-login thread ending. | 2014-08-05 19:21:17 HD Request # 3 - Historical data for YM-200903-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:17 Socket (692) - Shutdown and closed. | 2014-08-05 19:21:17 The network socket for historical data has been closed. | 2014-08-05 19:21:17 HD Request # 3 - Received 67664 records from 2008-12-28 19:01:00 to 2009-03-20 09:29:00 (81.6 days) and wrote 67664 records for YM-200903-ECBOT | 2014-08-05 19:21:17 HD Request # 3 - Intraday download COMPLETE for YM-200903-ECBOT. Completion time: 4s | 2014-08-05 19:21:17 HD Request # 3 - Reloading Intraday charts for symbol. | 2014-08-05 19:21:17 Reloading all charts with filename: YM-200903-ECBOT.scid | 2014-08-05 19:21:17 Mapping YM-200906-ECBOT to YMM9. Service code: cbot | 2014-08-05 19:21:17 HD Request # 4 - Downloading Intraday chart data for YM-200906-ECBOT to the file YM-200906-ECBOT.scid. Service: cbot | 2014-08-05 19:21:17 HD Request # 4 - Truncating file to starting Date-Time of 2009-03-09 20:00:00 | 2014-08-05 19:21:17 HD Request # 4 - Download start Date-Time: 2009-03-09 19:59:59.0 | 2014-08-05 19:21:17 HD Request # 4 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:21:17 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:21:17 Socket (2092) - Connected. | 2014-08-05 19:21:17 HD Request # 4 - Sending historical data logon request message. | 2014-08-05 19:21:17 HD Request # 4 - Requesting Intraday data. Start Date-Time: 2009-03-09 19:59:59. Record interval: 1. Symbol: YMM9 | 2014-08-05 19:21:17 HD Request # 4 - Decompressing data. | 2014-08-05 19:21:17 HD Request # 4 - Receiving Intraday data for YM-200906-ECBOT starting at 2009-03-29 20:00:00 | 2014-08-05 19:21:17 HD Request # 4 - Timestamp of first Intraday data file record written: 2009-03-29 20:00:00 | 2014-08-05 19:21:17 Socket (2024) - Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-08-05 19:21:18 Socket (2024) - Shutdown and closed. | 2014-08-05 19:21:18 Failed to connect to the data and trade server. | 2014-08-05 19:21:18 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-08-05 19:21:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-08-05 19:21:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-08-05 19:21:18 Disconnected from IB. | 2014-08-05 19:21:18 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-08-05 19:21:18 Socket (2092) - Shutdown and closed. | 2014-08-05 19:21:19 The network socket for historical data has been closed. | 2014-08-05 19:21:19 HD Request # 4 - Historical data for YM-200906-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:20 HD Request # 4 - Received 68098 records from 2009-03-29 20:00:00 to 2009-06-19 09:29:00 (81.6 days) and wrote 68098 records for YM-200906-ECBOT | 2014-08-05 19:21:20 HD Request # 4 - Intraday download COMPLETE for YM-200906-ECBOT. Completion time: 3s | 2014-08-05 19:21:20 HD Request # 4 - Reloading Intraday charts for symbol. | 2014-08-05 19:21:20 Reloading all charts with filename: YM-200906-ECBOT.scid | 2014-08-05 19:21:20 Mapping YM-200909-ECBOT to YMU9. Service code: cbot | 2014-08-05 19:21:20 HD Request # 5 - Downloading Intraday chart data for YM-200909-ECBOT to the file YM-200909-ECBOT.scid. Service: cbot | 2014-08-05 19:21:20 HD Request # 5 - Truncating file to starting Date-Time of 2009-06-08 20:00:00 | 2014-08-05 19:21:20 HD Request # 5 - Download start Date-Time: 2009-06-08 19:59:59.0 | 2014-08-05 19:21:20 HD Request # 5 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:21:20 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:21:20 Starting TWS auto-login thread. | 2014-08-05 19:21:20 Socket (2196) - Connected. | 2014-08-05 19:21:21 HD Request # 5 - Sending historical data logon request message. | 2014-08-05 19:21:21 HD Request # 5 - Requesting Intraday data. Start Date-Time: 2009-06-08 19:59:59. Record interval: 1. Symbol: YMU9 | 2014-08-05 19:21:21 TWS auto-login thread ending. | 2014-08-05 19:21:21 HD Request # 5 - Decompressing data. | 2014-08-05 19:21:21 HD Request # 5 - Receiving Intraday data for YM-200909-ECBOT starting at 2009-06-29 20:00:00 | 2014-08-05 19:21:21 HD Request # 5 - Timestamp of first Intraday data file record written: 2009-06-29 20:00:00 | 2014-08-05 19:21:21 Socket (2196) - Shutdown and closed. | 2014-08-05 19:21:23 The network socket for historical data has been closed. | 2014-08-05 19:21:23 HD Request # 5 - Historical data for YM-200909-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:25 HD Request # 5 - Received 64639 records from 2009-06-29 20:00:00 to 2009-09-18 09:29:00 (80.6 days) and wrote 64639 records for YM-200909-ECBOT | 2014-08-05 19:21:25 HD Request # 5 - Intraday download COMPLETE for YM-200909-ECBOT. Completion time: 5s | 2014-08-05 19:21:25 HD Request # 5 - Reloading Intraday charts for symbol. | 2014-08-05 19:21:25 Reloading all charts with filename: YM-200909-ECBOT.scid | 2014-08-05 19:21:25 Mapping YM-200912-ECBOT to YMZ9. Service code: cbot | 2014-08-05 19:21:25 HD Request # 6 - Downloading Intraday chart data for YM-200912-ECBOT to the file YM-200912-ECBOT.scid. Service: cbot | 2014-08-05 19:21:25 HD Request # 6 - Truncating file to starting Date-Time of 2009-09-07 20:00:00 | 2014-08-05 19:21:25 HD Request # 6 - Download start Date-Time: 2009-09-07 19:59:59.0 | 2014-08-05 19:21:25 HD Request # 6 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:21:25 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:21:25 File >> Disconnect selected. | 2014-08-05 19:21:25 Disconnected from IB. | 2014-08-05 19:21:25 Socket (2124) - Connected. | 2014-08-05 19:21:25 HD Request # 6 - Sending historical data logon request message. | 2014-08-05 19:21:25 HD Request # 6 - Requesting Intraday data. Start Date-Time: 2009-09-07 19:59:59. Record interval: 1. Symbol: YMZ9 | 2014-08-05 19:21:26 HD Request # 6 - Decompressing data. | 2014-08-05 19:21:26 HD Request # 6 - Receiving Intraday data for YM-200912-ECBOT starting at 2009-09-29 20:00:00 | 2014-08-05 19:21:26 HD Request # 6 - Timestamp of first Intraday data file record written: 2009-09-29 20:00:00 | 2014-08-05 19:21:26 HD Request # 6 - Historical data for YM-200912-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:28 Socket (2124) - Shutdown and closed. | 2014-08-05 19:21:28 The network socket for historical data has been closed. | 2014-08-05 19:21:28 HD Request # 6 - Received 64275 records from 2009-09-29 20:00:00 to 2009-12-18 09:27:00 (79.6 days) and wrote 64275 records for YM-200912-ECBOT | 2014-08-05 19:21:28 HD Request # 6 - Intraday download COMPLETE for YM-200912-ECBOT. Completion time: 3s | 2014-08-05 19:21:28 HD Request # 6 - Reloading Intraday charts for symbol. | 2014-08-05 19:21:28 Reloading all charts with filename: YM-200912-ECBOT.scid | 2014-08-05 19:21:28 Mapping ES-200806-GLOBEX to ESM8. Service code: cme | 2014-08-05 19:21:28 HD Request # 7 - Downloading Intraday chart data for ES-200806-GLOBEX to the file ES-200806-GLOBEX.scid. Service: cme | 2014-08-05 19:21:28 HD Request # 7 - Truncating file to starting Date-Time of 2008-03-10 20:00:00 | 2014-08-05 19:21:28 HD Request # 7 - Download start Date-Time: 2008-03-10 19:59:59.0 | 2014-08-05 19:21:28 HD Request # 7 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:21:28 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:21:28 Socket (2124) - Connected. | 2014-08-05 19:21:28 HD Request # 7 - Sending historical data logon request message. | 2014-08-05 19:21:28 HD Request # 7 - Requesting Intraday data. Start Date-Time: 2008-03-10 19:59:59. Record interval: 1. Symbol: ESM8 | 2014-08-05 19:21:28 YM-201409-ECBOT [C] 1 Min #4: Download is complete for all contract months in chart. Proceeding with data load. | 2014-08-05 19:21:28 HD Request # 7 - Decompressing data. | 2014-08-05 19:21:28 HD Request # 7 - Receiving Intraday data for ES-200806-GLOBEX starting at 2008-05-04 18:00:00 | 2014-08-05 19:21:28 HD Request # 7 - Timestamp of first Intraday data file record written: 2008-05-04 18:00:00 | 2014-08-05 19:21:28 Mapping YM-201409-ECBOT to YMU4. Service code: cbot | 2014-08-05 19:21:28 HD Request # 7 - Historical data for ES-200806-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:29 Socket (2124) - Shutdown and closed. | 2014-08-05 19:21:29 The network socket for historical data has been closed. | 2014-08-05 19:21:29 HD Request # 7 - Received 43442 records from 2008-05-04 18:00:00 to 2008-06-20 14:20:00 (46.8 days) and wrote 43442 records for ES-200806-GLOBEX | 2014-08-05 19:21:29 HD Request # 7 - Intraday download COMPLETE for ES-200806-GLOBEX. Completion time: 0s | 2014-08-05 19:21:29 HD Request # 7 - Reloading Intraday charts for symbol. | 2014-08-05 19:21:29 Reloading all charts with filename: ES-200806-GLOBEX.scid | 2014-08-05 19:21:29 HD Request # 8 - Downloading Intraday chart data for TF-201409-NYBOT to the file TF-201409-NYBOT.scid. Service: ice.us | 2014-08-05 19:21:29 HD Request # 8 - Download start Date-Time: 2014-08-05 17:59:57.0 | 2014-08-05 19:21:29 HD Request # 8 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:21:29 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:21:29 ES-201409-GLOBEX [C] 1 Min #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-08-05 19:21:29 Socket (2152) - Connected. | 2014-08-05 19:21:29 HD Request # 8 - Sending historical data logon request message. | 2014-08-05 19:21:29 HD Request # 8 - Requesting Intraday data. Start Date-Time: 2014-08-05 17:59:57. Record interval: 1. Symbol: RJU14 | 2014-08-05 19:21:30 HD Request # 8 - Decompressing data. | 2014-08-05 19:21:30 HD Request # 8 - Receiving Intraday data for TF-201409-NYBOT starting at 2014-08-05 17:59:57 | 2014-08-05 19:21:30 HD Request # 8 - Timestamp of first Intraday data file record written: 2014-08-05 17:59:57 | 2014-08-05 19:21:30 Socket (2152) - Shutdown and closed. | 2014-08-05 19:21:30 HD Request # 8 - Historical data for TF-201409-NYBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:30 The network socket for historical data has been closed. | 2014-08-05 19:21:30 HD Request # 8 - Received 1 record from 2014-08-05 17:59:57 to 2014-08-05 17:59:57 (0.0 seconds) and wrote 1 record for TF-201409-NYBOT | 2014-08-05 19:21:30 HD Request # 8 - Intraday download COMPLETE for TF-201409-NYBOT. Completion time: 1s | 2014-08-05 19:21:30 HD Request # 9 - Downloading Intraday chart data for NQ-201409-GLOBEX to the file NQ-201409-GLOBEX.scid. Service: cme | 2014-08-05 19:21:30 HD Request # 9 - Download start Date-Time: 2014-08-05 18:46:30.0 | 2014-08-05 19:21:30 HD Request # 9 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:21:30 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:21:30 Mapping ES-201409-GLOBEX to ESU4. Service code: cme | 2014-08-05 19:21:30 Socket (2052) - Connected. | 2014-08-05 19:21:30 HD Request # 9 - Sending historical data logon request message. | 2014-08-05 19:21:30 HD Request # 9 - Requesting Intraday data. Start Date-Time: 2014-08-05 18:46:30. Record interval: 1. Symbol: NQU4 | 2014-08-05 19:21:30 HD Request # 9 - Decompressing data. | 2014-08-05 19:21:30 HD Request # 9 - Receiving Intraday data for NQ-201409-GLOBEX starting at 2014-08-05 18:46:32 | 2014-08-05 19:21:30 HD Request # 9 - Timestamp of first Intraday data file record written: 2014-08-05 18:46:32 | 2014-08-05 19:21:30 HD Request # 9 - Historical data for NQ-201409-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:30 Socket (2052) - Shutdown and closed. | 2014-08-05 19:21:30 The network socket for historical data has been closed. | 2014-08-05 19:21:30 HD Request # 9 - Received 63 records from 2014-08-05 18:46:32 to 2014-08-05 19:10:42 (24.2 minutes) and wrote 63 records for NQ-201409-GLOBEX | 2014-08-05 19:21:30 HD Request # 9 - Intraday download COMPLETE for NQ-201409-GLOBEX. Completion time: 1s | 2014-08-05 19:21:31 HD Request # 10 - Downloading Intraday chart data for YM-201409-ECBOT to the file YM-201409-ECBOT.scid. Service: cbot | 2014-08-05 19:21:31 HD Request # 10 - Download start Date-Time: 2014-08-05 18:46:30.0 | 2014-08-05 19:21:31 HD Request # 10 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:21:31 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:21:31 Socket (2248) - Connected. | 2014-08-05 19:21:31 HD Request # 10 - Sending historical data logon request message. | 2014-08-05 19:21:31 HD Request # 10 - Requesting Intraday data. Start Date-Time: 2014-08-05 18:46:30. Record interval: 1. Symbol: YMU4 | 2014-08-05 19:21:31 HD Request # 10 - Decompressing data. | 2014-08-05 19:21:31 HD Request # 10 - Receiving Intraday data for YM-201409-ECBOT starting at 2014-08-05 18:46:35 | 2014-08-05 19:21:31 HD Request # 10 - Timestamp of first Intraday data file record written: 2014-08-05 18:46:35 | 2014-08-05 19:21:31 HD Request # 10 - Historical data for YM-201409-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:31 Socket (2248) - Shutdown and closed. | 2014-08-05 19:21:31 The network socket for historical data has been closed. | 2014-08-05 19:21:31 HD Request # 10 - Received 36 records from 2014-08-05 18:46:35 to 2014-08-05 19:10:45 (24.2 minutes) and wrote 36 records for YM-201409-ECBOT | 2014-08-05 19:21:31 HD Request # 10 - Intraday download COMPLETE for YM-201409-ECBOT. Completion time: 0s | 2014-08-05 19:21:31 HD Request # 11 - Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: cme | 2014-08-05 19:21:31 HD Request # 11 - Download start Date-Time: 2014-08-05 18:46:30.0 | 2014-08-05 19:21:31 HD Request # 11 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:21:31 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:21:31 Socket (2248) - Connected. | 2014-08-05 19:21:31 HD Request # 11 - Sending historical data logon request message. | 2014-08-05 19:21:31 HD Request # 11 - Requesting Intraday data. Start Date-Time: 2014-08-05 18:46:30. Record interval: 1. Symbol: ESU4 | 2014-08-05 19:21:32 HD Request # 11 - Decompressing data. | 2014-08-05 19:21:32 HD Request # 11 - Receiving Intraday data for ES-201409-GLOBEX starting at 2014-08-05 18:46:32 | 2014-08-05 19:21:32 HD Request # 11 - Timestamp of first Intraday data file record written: 2014-08-05 18:46:32 | 2014-08-05 19:21:32 HD Request # 11 - Historical data for ES-201409-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-08-05 19:21:32 Socket (2248) - Shutdown and closed. | 2014-08-05 19:21:32 The network socket for historical data has been closed. | 2014-08-05 19:21:32 HD Request # 11 - Received 149 records from 2014-08-05 18:46:32 to 2014-08-05 19:11:02 (24.5 minutes) and wrote 149 records for ES-201409-GLOBEX | 2014-08-05 19:21:32 HD Request # 11 - Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 0s | 2014-08-05 19:21:32 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-05 19:22:39 Socket (1368) - Connected. | 2014-08-05 19:22:39 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-08-05 19:22:39 TWS server version: 71 | 2014-08-05 19:22:41 IB: Connected. Waiting for account information. | 2014-08-05 19:22:41 IB Account information received. | 2014-08-05 19:22:41 Connected to IB Demo or Simulated account. | 2014-08-05 19:22:41 Not previously connected to Live account. | 2014-08-05 19:22:41 Interactive Brokers: Requesting Trade Positions for account: DU189735 | 2014-08-05 19:22:41 Next valid order ID: 1 | 2014-08-05 19:22:41 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:22:42 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:22:42 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:22:42 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:22:42 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-08-05 19:22:42 Next valid order ID: 1 | 2014-08-05 19:22:42 IB Account information received. | 2014-08-05 19:22:42 Connected to IB Demo or Simulated account. | 2014-08-05 19:22:42 Not previously connected to Live account. | 2014-08-05 19:22:42 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2014-08-05 19:22:42 Interactive Brokers: Received Trade Positions download end message for account DU189735 | 2014-08-05 19:22:42 Interactive Brokers - Starting real-time market data updates for: NQ-201409-GLOBEX. ID: 1 | 2014-08-05 19:22:42 Subscribing to real-time True Data for symbol: NQ SecType: FUT Exchange: GLOBEX Currency: | 2014-08-05 19:22:42 Subscribing to symbol: NQ SecType: FUT Expiry: 201409 Exchange: GLOBEX Currency: Multiplier: | 2014-08-05 19:22:42 HD Request # 12 - Downloading Intraday chart data for NQ-201409-GLOBEX to the file NQ-201409-GLOBEX.scid. Service: cme | 2014-08-05 19:22:42 HD Request # 12 - Download start Date-Time: 2014-08-05 19:10:42.0 | 2014-08-05 19:22:42 HD Request # 12 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:22:42 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:22:42 Interactive Brokers - Starting real-time market data updates for: ES-201409-GLOBEX. ID: 2 | 2014-08-05 19:22:42 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2014-08-05 19:22:42 Subscribing to symbol: ES SecType: FUT Expiry: 201409 Exchange: GLOBEX Currency: Multiplier: | 2014-08-05 19:22:42 Interactive Brokers - Starting real-time market data updates for: YM-201409-ECBOT. ID: 3 | 2014-08-05 19:22:42 Subscribing to real-time True Data for symbol: YM SecType: FUT Exchange: ECBOT Currency: | 2014-08-05 19:22:42 Subscribing to symbol: YM SecType: FUT Expiry: 201409 Exchange: ECBOT Currency: Multiplier: | 2014-08-05 19:22:42 Mapping TF-201409-NYBOT to RJU14. Service code: ice.us | 2014-08-05 19:22:42 SC Exchange Data - Starting real-time market data updates for: RJU14. ID: 4 | 2014-08-05 19:22:42 Using username 0 | 2014-08-05 19:22:42 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-08-05 19:22:42 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:22:42 Socket (1384) - Connected. | 2014-08-05 19:22:42 HD Request # 12 - Sending historical data logon request message. | 2014-08-05 19:22:42 Socket (1364) - Connected. | 2014-08-05 19:22:42 SC Exchange Data: Connected to server. | 2014-08-05 19:22:42 SC Exchange Data: Sending logon request message. | 2014-08-05 19:22:42 HD Request # 12 - Requesting Intraday data. Start Date-Time: 2014-08-05 19:10:42. Record interval: 30. Symbol: NQU4 | 2014-08-05 19:22:42 HD Request # 12 - Decompressing data. | 2014-08-05 19:22:42 HD Request # 12 - Receiving Intraday data for NQ-201409-GLOBEX starting at 2014-08-05 19:10:42 | 2014-08-05 19:22:42 HD Request # 12 - Timestamp of first Intraday data file record written: 2014-08-05 19:10:42 | 2014-08-05 19:22:42 Socket (1384) - Shutdown and closed. | 2014-08-05 19:22:42 The network socket for historical data has been closed. | 2014-08-05 19:22:42 HD Request # 12 - Received 3 records from 2014-08-05 19:10:42 to 2014-08-05 19:12:41 (119.0 seconds) and wrote 3 records for NQ-201409-GLOBEX | 2014-08-05 19:22:42 HD Request # 12 - Intraday download COMPLETE for NQ-201409-GLOBEX. Completion time: 0s | 2014-08-05 19:22:42 Real-time Intraday chart data file updates started for NQ-201409-GLOBEX | 2014-08-05 19:22:42 HD Request # 13 - Downloading Intraday chart data for NQ-201409-GLOBEX to the file NQ-201409-GLOBEX.scid. Service: ib | 2014-08-05 19:22:42 HD Request # 13 - Download start Date-Time: 2014-08-05 19:12:41.0 | 2014-08-05 19:22:42 HD Request # 13 - Requesting a total of 0 days and 5401 seconds. | 2014-08-05 19:22:42 HD Request # 13 - IB Backfill - Seconds requested: 5401. Seconds Remaining: 0. | 2014-08-05 19:22:42 HD Request # 13 - Requesting 5401 Seconds of data at 30 secs with ending Date-Time at 2014-08-05 20:32:42 for NQ-201409-GLOBEX | 2014-08-05 19:22:42 HD Request # 14 - Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: cme | 2014-08-05 19:22:42 HD Request # 14 - Download start Date-Time: 2014-08-05 19:11:02.0 | 2014-08-05 19:22:42 HD Request # 14 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:22:42 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:22:42 Socket (1344) - Connected. | 2014-08-05 19:22:43 HD Request # 14 - Sending historical data logon request message. | 2014-08-05 19:22:43 HD Request # 14 - Requesting Intraday data. Start Date-Time: 2014-08-05 19:11:02. Record interval: 30. Symbol: ESU4 | 2014-08-05 19:22:43 HD Request # 13 - Processing historical data message from TWS | 2014-08-05 19:22:43 HD Request # 13 - Receiving Intraday data for NQ-201409-GLOBEX starting at 2014-08-05 19:03:00 | 2014-08-05 19:22:43 HD Request # 13 - Timestamp of first Intraday data file record written: 2014-08-05 19:13:00 | 2014-08-05 19:22:43 HD Request # 13 - Received 41 records and wrote 20 records from 2014-08-05 19:02:30 to 2014-08-05 19:22:30. | 2014-08-05 19:22:43 SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-08-05 19:22:43 SC Exchange Data - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-05 19:22:43 SC Exchange Data - Successfully connected. | 2014-08-05 19:22:43 HD Request # 14 - Decompressing data. | 2014-08-05 19:22:43 SC Exchange Data - Restarting real-time data updates for symbol: TF-201409-NYBOT -> RJU14 | 2014-08-05 19:22:43 HD Request # 14 - Receiving Intraday data for ES-201409-GLOBEX starting at 2014-08-05 19:11:02 | 2014-08-05 19:22:43 HD Request # 14 - Timestamp of first Intraday data file record written: 2014-08-05 19:11:02 | 2014-08-05 19:22:43 Socket (1344) - Shutdown and closed. | 2014-08-05 19:22:43 The network socket for historical data has been closed. | 2014-08-05 19:22:43 HD Request # 14 - Received 3 records from 2014-08-05 19:11:02 to 2014-08-05 19:12:06 (64.0 seconds) and wrote 3 records for ES-201409-GLOBEX | 2014-08-05 19:22:43 HD Request # 14 - Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 1s | 2014-08-05 19:22:43 Real-time Intraday chart data file updates started for ES-201409-GLOBEX | 2014-08-05 19:22:43 HD Request # 15 - Downloading Intraday chart data for YM-201409-ECBOT to the file YM-201409-ECBOT.scid. Service: cbot | 2014-08-05 19:22:43 HD Request # 15 - Download start Date-Time: 2014-08-05 19:10:45.0 | 2014-08-05 19:22:43 HD Request # 15 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:22:43 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:22:43 Socket (2284) - Connected. | 2014-08-05 19:22:43 HD Request # 15 - Sending historical data logon request message. | 2014-08-05 19:22:43 HD Request # 15 - Requesting Intraday data. Start Date-Time: 2014-08-05 19:10:45. Record interval: 30. Symbol: YMU4 | 2014-08-05 19:22:43 HD Request # 15 - Decompressing data. | 2014-08-05 19:22:44 HD Request # 15 - Receiving Intraday data for YM-201409-ECBOT starting at 2014-08-05 19:10:45 | 2014-08-05 19:22:44 HD Request # 15 - Timestamp of first Intraday data file record written: 2014-08-05 19:10:45 | 2014-08-05 19:22:44 Socket (2284) - Shutdown and closed. | 2014-08-05 19:22:44 The network socket for historical data has been closed. | 2014-08-05 19:22:44 HD Request # 15 - Received 4 records from 2014-08-05 19:10:45 to 2014-08-05 19:12:35 (110.0 seconds) and wrote 4 records for YM-201409-ECBOT | 2014-08-05 19:22:44 HD Request # 15 - Intraday download COMPLETE for YM-201409-ECBOT. Completion time: 0s | 2014-08-05 19:22:44 Real-time Intraday chart data file updates started for YM-201409-ECBOT | 2014-08-05 19:22:44 HD Request # 16 - Downloading Intraday chart data for TF-201409-NYBOT to the file TF-201409-NYBOT.scid. Service: ice.us | 2014-08-05 19:22:44 HD Request # 16 - Download start Date-Time: 2014-08-05 17:59:57.0 | 2014-08-05 19:22:44 HD Request # 16 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:22:44 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:22:44 Socket (2036) - Connected. | 2014-08-05 19:22:44 HD Request # 16 - Sending historical data logon request message. | 2014-08-05 19:22:44 HD Request # 13 - Received 41 records from 2014-08-05 19:03:00 to 2014-08-05 19:22:30 (19.5 minutes) and wrote 20 records for NQ-201409-GLOBEX | 2014-08-05 19:22:44 HD Request # 13 - Intraday download COMPLETE for NQ-201409-GLOBEX. Completion time: 2s | 2014-08-05 19:22:44 Real-time Intraday chart data file updates started for NQ-201409-GLOBEX | 2014-08-05 19:22:44 HD Request # 17 - Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: ib | 2014-08-05 19:22:44 HD Request # 17 - Download start Date-Time: 2014-08-05 19:12:06.0 | 2014-08-05 19:22:44 HD Request # 17 - Requesting a total of 0 days and 5438 seconds. | 2014-08-05 19:22:44 HD Request # 17 - IB Backfill - Seconds requested: 5438. Seconds Remaining: 0. | 2014-08-05 19:22:44 HD Request # 17 - Requesting 5438 Seconds of data at 30 secs with ending Date-Time at 2014-08-05 20:32:44 for ES-201409-GLOBEX | 2014-08-05 19:22:44 HD Request # 16 - Requesting Intraday data. Start Date-Time: 2014-08-05 17:59:57. Record interval: 1. Symbol: RJU14 | 2014-08-05 19:22:44 HD Request # 16 - Decompressing data. | 2014-08-05 19:22:44 HD Request # 16 - Receiving Intraday data for TF-201409-NYBOT starting at 2014-08-05 17:59:57 | 2014-08-05 19:22:44 HD Request # 16 - Timestamp of first Intraday data file record written: 2014-08-05 17:59:57 | 2014-08-05 19:22:44 Socket (2036) - Shutdown and closed. | 2014-08-05 19:22:44 The network socket for historical data has been closed. | 2014-08-05 19:22:44 HD Request # 16 - Received 1 record from 2014-08-05 17:59:57 to 2014-08-05 17:59:57 (0.0 seconds) and wrote 1 record for TF-201409-NYBOT | 2014-08-05 19:22:44 HD Request # 16 - Intraday download COMPLETE for TF-201409-NYBOT. Completion time: 0s | 2014-08-05 19:22:44 Real-time Intraday chart data file updates started for TF-201409-NYBOT | 2014-08-05 19:22:44 HD Request # 17 - Processing historical data message from TWS | 2014-08-05 19:22:44 HD Request # 17 - Receiving Intraday data for ES-201409-GLOBEX starting at 2014-08-05 19:02:30 | 2014-08-05 19:22:44 HD Request # 17 - Timestamp of first Intraday data file record written: 2014-08-05 19:12:30 | 2014-08-05 19:22:44 HD Request # 17 - Received 42 records and wrote 21 records from 2014-08-05 19:02:00 to 2014-08-05 19:22:30. | 2014-08-05 19:22:44 HD Request # 17 - Received 42 records from 2014-08-05 19:02:30 to 2014-08-05 19:22:30 (20.0 minutes) and wrote 21 records for ES-201409-GLOBEX | 2014-08-05 19:22:45 HD Request # 17 - Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 1s | 2014-08-05 19:22:45 Real-time Intraday chart data file updates started for ES-201409-GLOBEX | 2014-08-05 19:22:45 HD Request # 18 - Downloading Intraday chart data for YM-201409-ECBOT to the file YM-201409-ECBOT.scid. Service: ib | 2014-08-05 19:22:45 HD Request # 18 - Download start Date-Time: 2014-08-05 19:12:35.0 | 2014-08-05 19:22:45 HD Request # 18 - Requesting a total of 0 days and 5410 seconds. | 2014-08-05 19:22:45 HD Request # 18 - IB Backfill - Seconds requested: 5410. Seconds Remaining: 0. | 2014-08-05 19:22:45 HD Request # 18 - Requesting 5410 Seconds of data at 30 secs with ending Date-Time at 2014-08-05 20:32:45 for YM-201409-ECBOT | 2014-08-05 19:22:45 HD Request # 18 - Processing historical data message from TWS | 2014-08-05 19:22:46 HD Request # 18 - Receiving Intraday data for YM-201409-ECBOT starting at 2014-08-05 19:03:00 | 2014-08-05 19:22:46 HD Request # 18 - Timestamp of first Intraday data file record written: 2014-08-05 19:13:00 | 2014-08-05 19:22:46 HD Request # 18 - Received 41 records and wrote 20 records from 2014-08-05 19:02:30 to 2014-08-05 19:22:30. | 2014-08-05 19:22:46 IB: Requesting historical order fills for account DU189735 | 2014-08-05 19:22:47 Interactive Brokers: Received Open orders end message. | 2014-08-05 19:22:47 HD Request # 18 - Received 41 records from 2014-08-05 19:03:00 to 2014-08-05 19:22:30 (19.5 minutes) and wrote 20 records for YM-201409-ECBOT | 2014-08-05 19:22:47 HD Request # 18 - Intraday download COMPLETE for YM-201409-ECBOT. Completion time: 2s | 2014-08-05 19:22:47 Real-time Intraday chart data file updates started for YM-201409-ECBOT | 2014-08-05 19:22:47 Requesting symbol settings for ib. Overwrite = on. | 2014-08-05 19:24:19 Symbol settings received. | 2014-08-05 19:24:22 Processed received symbol settings | 2014-08-05 19:24:22 File >> Disconnect selected. | 2014-08-05 19:24:52 Socket (1368) - Shutdown and closed. | 2014-08-05 19:24:52 Socket (1364) - Shutdown and closed. | 2014-08-05 19:24:52 SC Exchange Data: Disconnected from the server. | 2014-08-05 19:24:52 Disconnected from IB. | 2014-08-05 19:24:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-08-05 19:24:59 Socket (2208) - Connected. | 2014-08-05 19:24:59 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-08-05 19:24:59 TWS server version: 71 | 2014-08-05 19:25:01 IB: Connected. Waiting for account information. | 2014-08-05 19:25:01 IB Account information received. | 2014-08-05 19:25:01 Connected to IB Demo or Simulated account. | 2014-08-05 19:25:01 Not previously connected to Live account. | 2014-08-05 19:25:01 Interactive Brokers: Requesting Trade Positions for account: DU189735 | 2014-08-05 19:25:01 Next valid order ID: 1 | 2014-08-05 19:25:01 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:25:01 Message from IB: Market data farm connection is OK:usfuture.us. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:25:01 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:25:01 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2014-08-05 19:25:01 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-08-05 19:25:01 Next valid order ID: 1 | 2014-08-05 19:25:01 IB Account information received. | 2014-08-05 19:25:01 Connected to IB Demo or Simulated account. | 2014-08-05 19:25:01 Not previously connected to Live account. | 2014-08-05 19:25:01 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2014-08-05 19:25:01 Interactive Brokers - Starting real-time market data updates for: ES-201409-GLOBEX. ID: 1 | 2014-08-05 19:25:01 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2014-08-05 19:25:01 Subscribing to symbol: ES SecType: FUT Expiry: 201409 Exchange: GLOBEX Currency: Multiplier: | 2014-08-05 19:25:01 HD Request # 19 - Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: cme | 2014-08-05 19:25:01 HD Request # 19 - Download start Date-Time: 2014-08-05 19:24:45.0 | 2014-08-05 19:25:01 HD Request # 19 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:25:01 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:25:01 Interactive Brokers - Starting real-time market data updates for: YM-201409-ECBOT. ID: 2 | 2014-08-05 19:25:01 Subscribing to real-time True Data for symbol: YM SecType: FUT Exchange: ECBOT Currency: | 2014-08-05 19:25:01 Subscribing to symbol: YM SecType: FUT Expiry: 201409 Exchange: ECBOT Currency: Multiplier: | 2014-08-05 19:25:01 Interactive Brokers: Received Trade Positions download end message for account DU189735 | 2014-08-05 19:25:01 Mapping TF-201409-NYBOT to RJU14. Service code: ice.us | 2014-08-05 19:25:01 SC Exchange Data - Starting real-time market data updates for: RJU14. ID: 3 | 2014-08-05 19:25:01 Using username 0 | 2014-08-05 19:25:01 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-08-05 19:25:01 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:25:01 Interactive Brokers - Starting real-time market data updates for: NQ-201409-GLOBEX. ID: 4 | 2014-08-05 19:25:01 Subscribing to real-time True Data for symbol: NQ SecType: FUT Exchange: GLOBEX Currency: | 2014-08-05 19:25:01 Subscribing to symbol: NQ SecType: FUT Expiry: 201409 Exchange: GLOBEX Currency: Multiplier: | 2014-08-05 19:25:01 Socket (2064) - Connected. | 2014-08-05 19:25:01 HD Request # 19 - Sending historical data logon request message. | 2014-08-05 19:25:01 Socket (2328) - Connected. | 2014-08-05 19:25:01 SC Exchange Data: Connected to server. | 2014-08-05 19:25:01 SC Exchange Data: Sending logon request message. | 2014-08-05 19:25:01 HD Request # 19 - Requesting Intraday data. Start Date-Time: 2014-08-05 19:24:45. Record interval: 30. Symbol: ESU4 | 2014-08-05 19:25:01 HD Request # 19 - Decompressing data. | 2014-08-05 19:25:01 Socket (2064) - Shutdown and closed. | 2014-08-05 19:25:01 The network socket for historical data has been closed. | 2014-08-05 19:25:01 HD Request # 19 - Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201409-GLOBEX | 2014-08-05 19:25:01 HD Request # 19 - Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 0s | 2014-08-05 19:25:01 Real-time Intraday chart data file updates started for ES-201409-GLOBEX | 2014-08-05 19:25:01 HD Request # 20 - Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: ib | 2014-08-05 19:25:01 HD Request # 20 - Download start Date-Time: 2014-08-05 19:24:45.0 | 2014-08-05 19:25:01 HD Request # 20 - Requesting a total of 0 days and 4816 seconds. | 2014-08-05 19:25:01 HD Request # 20 - IB Backfill - Seconds requested: 4816. Seconds Remaining: 0. | 2014-08-05 19:25:01 HD Request # 20 - Requesting 4816 Seconds of data at 30 secs with ending Date-Time at 2014-08-05 20:35:01 for ES-201409-GLOBEX | 2014-08-05 19:25:01 HD Request # 21 - Downloading Intraday chart data for YM-201409-ECBOT to the file YM-201409-ECBOT.scid. Service: cbot | 2014-08-05 19:25:01 HD Request # 21 - Download start Date-Time: 2014-08-05 19:24:45.0 | 2014-08-05 19:25:01 HD Request # 21 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:25:01 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:25:01 Socket (2264) - Connected. | 2014-08-05 19:25:02 HD Request # 21 - Sending historical data logon request message. | 2014-08-05 19:25:02 HD Request # 21 - Requesting Intraday data. Start Date-Time: 2014-08-05 19:24:45. Record interval: 30. Symbol: YMU4 | 2014-08-05 19:25:02 HD Request # 20 - Processing historical data message from TWS | 2014-08-05 19:25:02 HD Request # 20 - Receiving Intraday data for ES-201409-GLOBEX starting at 2014-08-05 19:15:00 | 2014-08-05 19:25:02 HD Request # 20 - Received 21 records and wrote 0 records from 2014-08-05 19:14:30 to 2014-08-05 19:24:30. | 2014-08-05 19:25:02 HD Request # 21 - Decompressing data. | 2014-08-05 19:25:02 Socket (2264) - Shutdown and closed. | 2014-08-05 19:25:02 The network socket for historical data has been closed. | 2014-08-05 19:25:02 HD Request # 21 - Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201409-ECBOT | 2014-08-05 19:25:02 HD Request # 21 - Intraday download COMPLETE for YM-201409-ECBOT. Completion time: 0s | 2014-08-05 19:25:02 Real-time Intraday chart data file updates started for YM-201409-ECBOT | 2014-08-05 19:25:02 HD Request # 22 - Downloading Intraday chart data for TF-201409-NYBOT to the file TF-201409-NYBOT.scid. Service: ice.us | 2014-08-05 19:25:02 HD Request # 22 - Download start Date-Time: 2014-08-05 17:59:57.0 | 2014-08-05 19:25:02 HD Request # 22 - Using server: scdf1.sierracharts.com port 10149 | 2014-08-05 19:25:02 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-08-05 19:25:02 SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-08-05 19:25:02 SC Exchange Data - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-08-05 19:25:02 SC Exchange Data - Successfully connected. | 2014-08-05 19:25:02 SC Exchange Data - Restarting real-time data updates for symbol: TF-201409-NYBOT -> RJU14 | 2014-08-05 19:25:02 Socket (2348) - Connected. | 2014-08-05 19:25:02 HD Request # 22 - Sending historical data logon request message. | 2014-08-05 19:25:02 HD Request # 22 - Requesting Intraday data. Start Date-Time: 2014-08-05 17:59:57. Record interval: 1. Symbol: RJU14 | 2014-08-05 19:25:02 HD Request # 22 - Decompressing data. | 2014-08-05 19:25:02 HD Request # 22 - Receiving Intraday data for TF-201409-NYBOT starting at 2014-08-05 17:59:57 | 2014-08-05 19:25:02 HD Request # 22 - Timestamp of first Intraday data file record written: 2014-08-05 17:59:57 | 2014-08-05 19:25:02 Socket (2348) - Shutdown and closed. | 2014-08-05 19:25:02 The network socket for historical data has been closed. | 2014-08-05 19:25:02 HD Request # 22 - Received 1 record from 2014-08-05 17:59:57 to 2014-08-05 17:59:57 (0.0 seconds) and wrote 1 record for TF-201409-NYBOT | 2014-08-05 19:25:02 HD Request # 22 - Intraday download COMPLETE for TF-201409-NYBOT. Completion time: 0s | 2014-08-05 19:25:02 Real-time Intraday chart data file updates started for TF-201409-NYBOT | 2014-08-05 19:25:02 HD Request # 23 - Downloading Intraday chart data for NQ-201409-GLOBEX to the file NQ-201409-GLOBEX.scid. Service: cme | 2014-08-05 19:25:02 HD Request # 23 - Download start Date-Time: 2014-08-05 19:24:45.0 | 2014-08-05 19:25:02 HD Request # 23 - Using server: scdf2.sierracharts.com port 10149 | 2014-08-05 19:25:02 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-08-05 19:25:02 Socket (2332) - Connected. | 2014-08-05 19:25:03 HD Request # 23 - Sending historical data logon request message. | 2014-08-05 19:25:03 HD Request # 20 - Received 21 records from 2014-08-05 19:15:00 to 2014-08-05 19:24:30 (9.5 minutes) and wrote 0 records for ES-201409-GLOBEX | 2014-08-05 19:25:03 HD Request # 23 - Requesting Intraday data. Start Date-Time: 2014-08-05 19:24:45. Record interval: 30. Symbol: NQU4 | 2014-08-05 19:25:03 HD Request # 20 - Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 2s | 2014-08-05 19:25:03 Real-time Intraday chart data file updates started for ES-201409-GLOBEX | 2014-08-05 19:25:03 HD Request # 24 - Downloading Intraday chart data for YM-201409-ECBOT to the file YM-201409-ECBOT.scid. Service: ib | 2014-08-05 19:25:03 HD Request # 24 - Download start Date-Time: 2014-08-05 19:24:45.0 | 2014-08-05 19:25:03 HD Request # 24 - Requesting a total of 0 days and 4818 seconds. | 2014-08-05 19:25:03 HD Request # 24 - IB Backfill - Seconds requested: 4818. Seconds Remaining: 0. | 2014-08-05 19:25:03 HD Request # 24 - Requesting 4818 Seconds of data at 30 secs with ending Date-Time at 2014-08-05 20:35:03 for YM-201409-ECBOT | 2014-08-05 19:25:03 Socket (2332) - Shutdown and closed. | 2014-08-05 19:25:03 The network socket for historical data has been closed. | 2014-08-05 19:25:03 HD Request # 23 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201409-GLOBEX | 2014-08-05 19:25:03 HD Request # 23 - Intraday download COMPLETE for NQ-201409-GLOBEX. Completion time: 1s | 2014-08-05 19:25:03 Real-time Intraday chart data file updates started for NQ-201409-GLOBEX | 2014-08-05 19:25:03 HD Request # 24 - Processing historical data message from TWS | 2014-08-05 19:25:03 HD Request # 24 - Receiving Intraday data for YM-201409-ECBOT starting at 2014-08-05 19:15:00 | 2014-08-05 19:25:03 HD Request # 24 - Received 21 records and wrote 0 records from 2014-08-05 19:14:30 to 2014-08-05 19:24:30. | 2014-08-05 19:25:03 HD Request # 24 - Received 21 records from 2014-08-05 19:15:00 to 2014-08-05 19:24:30 (9.5 minutes) and wrote 0 records for YM-201409-ECBOT | 2014-08-05 19:25:04 HD Request # 24 - Intraday download COMPLETE for YM-201409-ECBOT. Completion time: 0s | 2014-08-05 19:25:04 Real-time Intraday chart data file updates started for YM-201409-ECBOT | 2014-08-05 19:25:04 HD Request # 25 - Downloading Intraday chart data for NQ-201409-GLOBEX to the file NQ-201409-GLOBEX.scid. Service: ib | 2014-08-05 19:25:04 HD Request # 25 - Download start Date-Time: 2014-08-05 19:24:45.0 | 2014-08-05 19:25:04 HD Request # 25 - Requesting a total of 0 days and 4819 seconds. | 2014-08-05 19:25:04 HD Request # 25 - IB Backfill - Seconds requested: 4819. Seconds Remaining: 0. | 2014-08-05 19:25:04 HD Request # 25 - Requesting 4819 Seconds of data at 30 secs with ending Date-Time at 2014-08-05 20:35:04 for NQ-201409-GLOBEX | 2014-08-05 19:25:04 HD Request # 25 - Processing historical data message from TWS | 2014-08-05 19:25:05 HD Request # 25 - Receiving Intraday data for NQ-201409-GLOBEX starting at 2014-08-05 19:15:00 | 2014-08-05 19:25:05 HD Request # 25 - Received 21 records and wrote 0 records from 2014-08-05 19:14:30 to 2014-08-05 19:24:30. | 2014-08-05 19:25:05 HD Request # 25 - Received 21 records from 2014-08-05 19:15:00 to 2014-08-05 19:24:30 (9.5 minutes) and wrote 0 records for NQ-201409-GLOBEX | 2014-08-05 19:25:06 HD Request # 25 - Intraday download COMPLETE for NQ-201409-GLOBEX. Completion time: 2s | 2014-08-05 19:25:06 Real-time Intraday chart data file updates started for NQ-201409-GLOBEX | 2014-08-05 19:25:06 IB: Requesting historical order fills for account DU189735 | 2014-08-05 19:25:06 Interactive Brokers: Received Open orders end message. | 2014-08-05 19:25:06 |
[2014-08-06 01:04:49] |
This is the problem: Connected to IB Demo or Simulated account. | 2014-08-05 19:22:42
Not previously connected to Live account. | 2014-08-05 19:22:42 NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2014-08-05 19:22:42 You need to connect to your IB Live account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
