Date/Time: Sat, 04 May 2024 23:54:55 +0000
RE: crosshair
View Count: 201
[2023-05-18 15:00:49] |
Jupiter13 - Posts: 1 |
I have 2 unanswered questions. I use 3 external screens with 6 detached charts displayed. 1. How can I minimize all of them? Previously, when I minimized the main Sierrachart window, all the detached windows minimized as well. But now, only the main window minimizes while the detached windows remain open. 2. How do I prevent the crosshair from moving in the past across all detached windows, even with different instruments? Thanks in advance. Dimitri |
[2023-05-18 16:06:27] |
Sierra_Chart Engineering - Posts: 14224 |
1. Refer to this setting: General Settings Window: Minimize / Restore Detached Windows With Main Window (Global Settings >> General Settings >> GUI >> Application GUI) 2. Disable this: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
