Date/Time: Tue, 07 May 2024 16:45:23 +0000
Connecting .....
View Count: 1323
[2014-06-09 19:56:59] |
bronson - Posts: 13 |
Hello, for several weeks / months I have big problems with connections on my account simulation and more on my real account infinity on sierra chart. My broker is infinity and I have no problem to connect on their platform but the connection between sierra chart and infinity is a big problem every time i open sierra chart . There is no problem with my firewall and my antivirus because when i disconnect them , problem is still there . Can I send you the message log for analysis? |
[2014-06-09 21:50:44] |
Restart Sierra Chart. Wait about two minutes so we can see several connection attempts and then provide the Message Log, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-11 11:22:37] |
Hello, see below the copy log (message log) ....i can't connect on my account BUT earlier in the morning I am connected without problem .... Once it's working...once it don't work ....i'm tired with this problem.... Software version: 1137 | 2014-06-11 13:09:44 Usage end date: 2014-06-24 | 2014-06-11 13:09:44 Enabled for: Advanced Features. | 2014-06-11 13:09:44 Enabled for: Advanced Features 2. | 2014-06-11 13:09:44 Enabled for: Sierra Chart Historical Data Service. | 2014-06-11 13:09:44 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-06-11 13:09:44 Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-06-11 13:09:44 Enabled for: EUREX exchange. | 2014-06-11 13:09:44 Enabled for: NYSE INDEXES exchange. | 2014-06-11 13:09:44 Received 1 data feed usernames. | 2014-06-11 13:09:44 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-11 13:09:44 Active service: TransAct | 2014-06-11 13:09:44 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-06-11 13:09:44 2014-06-11 13:09:44 Local computer clock time | 2014-06-11 13:09:44 2014-06-11 11:09:44 GMT time | 2014-06-11 13:09:44 2014-06-11 13:09:44 Time zone adjusted time | 2014-06-11 13:09:44 Time difference to server time: 4 seconds. | 2014-06-11 13:09:44 Program path: C:\SierraChart\ | 2014-06-11 13:09:44 Data Files path: C:\SierraChart\Data\ | 2014-06-11 13:09:44 OS Version Number: 6.1 | 2014-06-11 13:09:44 Checking for new symbol settings for ta | 2014-06-11 13:09:44 Symbol settings are up-to-date for ta | 2014-06-11 13:09:44 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:09:49 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:09:51 The network socket is connected. | 2014-06-11 13:09:51 TransAct: Connected to server. | 2014-06-11 13:09:51 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:09:51 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:09:51 TransAct: Sending logon request message. | 2014-06-11 13:09:51 TransAct: Market data feed reported to be lost. | 2014-06-11 13:10:40 Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:10:40 Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:10:40 Transact Futures - Connection error: Gatekeeper Unreachable. | 2014-06-11 13:10:40 Socket has been shutdown and closed. | 2014-06-11 13:10:40 Transact Futures: Disconnected from the server. | 2014-06-11 13:10:40 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:10:46 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:10:48 The network socket is connected. | 2014-06-11 13:10:48 TransAct: Connected to server. | 2014-06-11 13:10:48 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:10:48 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:10:48 TransAct: Sending logon request message. | 2014-06-11 13:10:48 TransAct: Market data feed reported to be lost. | 2014-06-11 13:11:10 Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:11:10 Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:11:10 Transact Futures - Connection error: Unknown Error Code: 60. | 2014-06-11 13:11:10 Socket has been shutdown and closed. | 2014-06-11 13:11:10 Transact Futures: Disconnected from the server. | 2014-06-11 13:11:10 Transact Futures: Bridge process is still running. | 2014-06-11 13:11:14 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:11:16 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:11:17 Socket has been shutdown and closed. | 2014-06-11 13:11:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:11:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:11:17 TransAct: Disconnected from the server. | 2014-06-11 13:11:17 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:11:17 TransAct: Bridge process is still running. | 2014-06-11 13:11:19 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:11:21 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:11:22 Socket has been shutdown and closed. | 2014-06-11 13:11:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:11:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:11:22 TransAct: Disconnected from the server. | 2014-06-11 13:11:22 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:11:22 TransAct: Bridge process is still running. | 2014-06-11 13:11:24 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:11:26 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:11:27 Socket has been shutdown and closed. | 2014-06-11 13:11:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:11:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:11:27 TransAct: Disconnected from the server. | 2014-06-11 13:11:27 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:11:27 TransAct: Bridge process is still running. | 2014-06-11 13:11:29 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:11:31 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:11:32 Socket has been shutdown and closed. | 2014-06-11 13:11:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:11:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:11:32 TransAct: Disconnected from the server. | 2014-06-11 13:11:32 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:11:32 TransAct: Bridge process is still running. | 2014-06-11 13:11:34 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:11:36 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:11:37 Socket has been shutdown and closed. | 2014-06-11 13:11:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:11:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:11:37 TransAct: Disconnected from the server. | 2014-06-11 13:11:37 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:11:37 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:11:39 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:11:41 The network socket is connected. | 2014-06-11 13:11:41 TransAct: Connected to server. | 2014-06-11 13:11:41 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:11:41 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:11:41 TransAct: Sending logon request message. | 2014-06-11 13:11:41 TransAct: Market data feed reported to be lost. | 2014-06-11 13:12:08 Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:12:08 Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:12:08 Transact Futures - Connection error: Unknown Error Code: 60. | 2014-06-11 13:12:08 Socket has been shutdown and closed. | 2014-06-11 13:12:08 Transact Futures: Disconnected from the server. | 2014-06-11 13:12:08 Transact Futures: Bridge process is still running. | 2014-06-11 13:12:11 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:12:13 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:12:14 Socket has been shutdown and closed. | 2014-06-11 13:12:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:12:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:12:14 TransAct: Disconnected from the server. | 2014-06-11 13:12:14 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:12:14 TransAct: Bridge process is still running. | 2014-06-11 13:12:16 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:12:18 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:12:19 Socket has been shutdown and closed. | 2014-06-11 13:12:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:12:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:12:19 TransAct: Disconnected from the server. | 2014-06-11 13:12:19 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:12:19 TransAct: Bridge process is still running. | 2014-06-11 13:12:21 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:12:23 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:12:24 Socket has been shutdown and closed. | 2014-06-11 13:12:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:12:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:12:25 TransAct: Disconnected from the server. | 2014-06-11 13:12:25 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:12:25 TransAct: Bridge process is still running. | 2014-06-11 13:12:27 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:12:29 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:12:30 Socket has been shutdown and closed. | 2014-06-11 13:12:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:12:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:12:30 TransAct: Disconnected from the server. | 2014-06-11 13:12:30 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:12:30 TransAct: Bridge process is still running. | 2014-06-11 13:12:32 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:12:34 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:12:35 Socket has been shutdown and closed. | 2014-06-11 13:12:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:12:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:12:35 TransAct: Disconnected from the server. | 2014-06-11 13:12:35 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:12:35 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:12:37 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:12:39 The network socket is connected. | 2014-06-11 13:12:39 TransAct: Connected to server. | 2014-06-11 13:12:39 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:12:39 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:12:39 TransAct: Sending logon request message. | 2014-06-11 13:12:39 Connection timed out. Will disconnect and retry. | 2014-06-11 13:13:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:13:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:13:37 Socket has been shutdown and closed. | 2014-06-11 13:13:37 TransAct: Disconnected from the server. | 2014-06-11 13:13:37 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:13:37 TransAct: Bridge process is still running. | 2014-06-11 13:13:39 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:13:41 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:13:42 Socket has been shutdown and closed. | 2014-06-11 13:13:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:13:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:13:42 TransAct: Disconnected from the server. | 2014-06-11 13:13:42 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:13:42 TransAct: Bridge process is still running. | 2014-06-11 13:13:44 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:13:46 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:13:47 Socket has been shutdown and closed. | 2014-06-11 13:13:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:13:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:13:47 TransAct: Disconnected from the server. | 2014-06-11 13:13:47 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:13:47 TransAct: Bridge process is still running. | 2014-06-11 13:13:49 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:13:51 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:13:52 Socket has been shutdown and closed. | 2014-06-11 13:13:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:13:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:13:52 TransAct: Disconnected from the server. | 2014-06-11 13:13:52 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:13:52 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:13:54 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:13:56 The network socket is connected. | 2014-06-11 13:13:56 TransAct: Connected to server. | 2014-06-11 13:13:56 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:13:56 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:13:56 TransAct: Sending logon request message. | 2014-06-11 13:13:56 Connection timed out. Will disconnect and retry. | 2014-06-11 13:14:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:14:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:14:54 Socket has been shutdown and closed. | 2014-06-11 13:14:54 TransAct: Disconnected from the server. | 2014-06-11 13:14:54 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:14:54 TransAct: Bridge process is still running. | 2014-06-11 13:14:56 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:14:58 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:14:59 Socket has been shutdown and closed. | 2014-06-11 13:14:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:14:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:14:59 TransAct: Disconnected from the server. | 2014-06-11 13:14:59 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:14:59 TransAct: Bridge process is still running. | 2014-06-11 13:15:01 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:15:03 Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-06-11 13:15:04 Socket has been shutdown and closed. | 2014-06-11 13:15:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:15:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:15:04 TransAct: Disconnected from the server. | 2014-06-11 13:15:04 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:15:04 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:15:06 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:15:08 The network socket is connected. | 2014-06-11 13:15:08 TransAct: Connected to server. | 2014-06-11 13:15:08 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:15:08 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:15:08 TransAct: Sending logon request message. | 2014-06-11 13:15:08 Connection timed out. Will disconnect and retry. | 2014-06-11 13:16:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-11 13:16:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-11 13:16:06 Socket has been shutdown and closed. | 2014-06-11 13:16:06 TransAct: Disconnected from the server. | 2014-06-11 13:16:06 Will reconnect to the server in 35.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-11 13:16:06 TransAct - Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2014-06-11 13:16:41 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-06-11 13:16:43 The network socket is connected. | 2014-06-11 13:16:43 TransAct: Connected to server. | 2014-06-11 13:16:43 DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:16:43 DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:16:43 TransAct: Sending logon request message. | 2014-06-11 13:16:43 TransAct: Market data feed reported to be lost. | 2014-06-11 13:17:06 Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2014-06-11 13:17:06 Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-11 13:17:06 Transact Futures - Connection error: Unknown Error Code: 60. | 2014-06-11 13:17:06 Socket has been shutdown and closed. | 2014-06-11 13:17:06 Transact Futures: Disconnected from the server. | 2014-06-11 13:17:06 |
[2014-06-11 16:14:59] |
These are the relevant error messages: TransAct: Sending logon request message. | 2014-06-11 13:16:43
TransAct: Market data feed reported to be lost. | 2014-06-11 13:17:06 Transact Futures - Connection error: Unknown Error Code: 60. | 2014-06-11 13:17:06
For these contact TransAct support about them here: http://www.transactfutures.com/ContactUs.htm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
