Date/Time: Thu, 03 Jul 2025 04:28:22 +0000
3 Quick Questions - Can I install 2 copies one for Rithmic and one for Dinali + more
View Count: 483
[2023-01-26 18:52:12] |
TopGunTrader - Posts: 199 |
Hi, I trade through Rithmic and paid for 2 data feeds from broker as I like Jigsaw's DOM but also often place trades in Sierra. I also have your Dinali feed and would like to use it for sectors so can I install Sierra in another folder and login to that one as well using the Dinali data I have? Second question I notice the stock feed doesn't update and historical data is 15 mins behind I believe I activated exchange agreements so not sure why this is, attached chart to show. Third I have two people I'm learning from including Trade Your Plan Mike who has big lot traders MBO on DOM how do I get this, does it come with your DiNali or an extra cost? If I have Rithmic can this be displayed with that data too?? Thank you. |
[2023-01-26 21:23:38] |
John - SC Support - Posts: 40722 |
You can install and run as many instances of Sierra Chart as you want on a single computer. But, you can only get the Denali data to 3 instances (separate installations, not Sub-Instance - which work differently) at a time. It sounds like you are only asking about 2 instances, so this is fine. Refer to the information here: Denali Exchange Data Feed: Denali Exchange Data Feed Connections on Same Computer Simultaneously Second question I notice the stock feed doesn't update and historical data is 15 mins behind I believe I activated exchange agreements so not sure why this is, attached chart to show.
You are not using the correct symbols. You have setup the NASDAQ TotalView exchange, therefore you need to use the suffix -NQTV with the core symbol in order to get the data from the NASDAQ TotalView exchange (for example - IBM-NQTV). Refer to the information here: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Third I have two people I'm learning from including Trade Your Plan Mike who has big lot traders MBO on DOM how do I get this, does it come with your DiNali or an extra cost? If I have Rithmic can this be displayed with that data too??
The MBO data is only available from our Denali Exchange Data Feed. It requires that you are on Package 12 (Integrated Advanced with MBO) and that you are subscribed to the exchanges including Market Depth (which you are). Refer to the following for information and setup of the MBO data: Market By Order Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
