Date/Time: Fri, 13 Nov 2026 21:36:20 +0000
Live Data for Futures
View Count: 741
[2022-11-22 19:13:33]
User678193 - Posts: 12
Hi how can i receive live data for /ES /NQ and other futures. Currently it is displaying these as delayed. Thanks
[2022-11-22 21:56:23]
What you have to keep in mind is that the CME Group has a requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange rates. You need to be able to connect Sierra Chart to this account at least once a month to make the verification and allow you to continue to get the data at the non-professional rate. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do have an account that qualifies for the above, then you will first need to setup your Sierra Chart to connect to that trading account. If you let us know what broker/trading service you are using, we can then point you to the proper instructions.
If you do not have an account that qualifies for the above, then we recommend the solution outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have the trading account issue worked out, then you can go through the setup instructions for the Denali Exchange Data Feed to get the data. You will find the instructions at the following link:
