Date/Time: Fri, 13 Nov 2026 21:50:51 +0000
Real time Sierra charts
View Count: 932
[2022-11-07 15:28:08]
User624168 - Posts: 4
how do I activate real time Sierra charts
[2022-11-07 23:27:54]
What are the exchanges for which you want the real-time data?
[2022-11-10 16:16:41]
I want ymz22
[2022-11-10 16:27:53]
Since you are wanting data for the CME Group, you need to first understand that they (the CME Group) have a requirement that you have a live, funded, futures trading account in order to get the data at the "non-professional" rate. We check the account by having you connect Sierra Chart to your trading account at least once a month (if you are not connected all the time), therefore the account has to be with a trading service that we support (Interactive Brokers, CQG, Rithmic, Teton Order Routing). Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have a trading account, then we recommend the solution outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
Once you have the above worked out, then you would go through the setup instructions for the Denali Exchange Data Feed for the CME Group data at the following link:
[2022-11-11 21:45:08]
I am using ninja as my broker. How do I use ninja to qualify me as non-professional for Sierra charts
[2022-11-11 22:02:42]
If you are setup with Ninja to use the CQG order routing then you would connect Sierra Chart to your CQG account by following these instructions:
CQG Trading Platform Service: Setup Instructions
Otherwise, in order to get the real-time data you would have to setup a separate brokerage account. We recommend the solution outlined at the following link which will only require $100 to setup the account:
[2022-11-12 16:13:39]
SDG - Posts: 1
I am unable to connect to DTC service for which I have a paid subscription. Please advise. Thank you.
[2022-11-14 16:19:29]
SDG:
What service are you trying to connect to? Do you have your own developed DTC Server?
