Date/Time: Sat, 07 Nov 2026 14:15:23 +0000
Sent log this evening for analysis
View Count: 774
[2022-09-19 01:14:39]
jbech96 - Posts: 39
I keep getting dialog box that reads Download Failed Error downloading historical intraday data.
[2022-09-19 06:47:31]
Sierra_Chart Engineering - Posts: 25397
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
[2022-09-19 12:18:50]
jbech96 - Posts: 39
The message Log reads, Windows error code 11004
[2022-09-19 15:12:54]
John - SC Support - Posts: 48459
We are not seeing any logs sent in for your account. We really need to see the log to understand where the particular problem is. Please follow the instructions from Post #2 above so we can see the full message log.
[2022-09-30 12:31:37]
jbech96 - Posts: 39
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:18.002
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:18.002
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:18.002
Software version: 2422 64-bit | 2022-09-30 08:24:18.158
Primary Thread ID: 4220 | 2022-09-30 08:24:18.158
Usage end date: 2022-12-19 | 2022-09-30 08:24:18.158
Enabled for: Advanced Features 2. | 2022-09-30 08:24:18.158
Enabled for: Sierra Chart Historical Data Service. | 2022-09-30 08:24:18.158
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-09-30 08:24:18.158
Enabled for: Delayed Denali Exchange Data Feed. | 2022-09-30 08:24:18.158
Enabled for exchange2: CME | 2022-09-30 08:24:18.158
Enabled for exchange2: fairx_exchange.data | 2022-09-30 08:24:18.158
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-09-30 08:24:18.158
Current selected Data/Trading service: Teton CME Order Routing | 2022-09-30 08:24:18.158
Custom symbol settings values: disabled | 2022-09-30 08:24:18.158
Chart Update Interval: 40 | 2022-09-30 08:24:18.158
Intraday Data Storage Time Unit: 0 | 2022-09-30 08:24:18.158
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-09-30 08:24:18.158
2022-09-30 12:24:18 Local computer time in UTC | 2022-09-30 08:24:18.158
2022-09-30 08:24:18 Local computer time in SC Time Zone | 2022-09-30 08:24:18.158
Program path: C:\SierraChart\SierraChartTransActMA\ | 2022-09-30 08:24:18.158
Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2022-09-30 08:24:18.158
OS Version Number: 6.1 | 2022-09-30 08:24:18.158
Locale Setting: C | 2022-09-30 08:24:18.158
DLLs: JK-V1.2.dll, UserContributedStudies_64.dll | 2022-09-30 08:24:18.158
Allowed protected custom studies: | 2022-09-30 08:24:18.158
Crash reporter started: true | 2022-09-30 08:24:18.158
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:20.015
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 | 2022-09-30 08:24:20.015
Error getting address info for futurestrading14.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:20.015 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:20.015
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:20.015
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:20.015
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:20.030
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:20.030
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:20.030
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:22.043
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 | 2022-09-30 08:24:22.043
Error getting address info for futurestrading15.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:22.043 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:22.043
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:22.043
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:22.043
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:22.058
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:22.058
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:22.058
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:24.071
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 | 2022-09-30 08:24:24.071
Error getting address info for futurestrading16.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:24.071 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:24.071
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:24.071
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:24.071
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:24.086
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:24.086
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:24.086
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:26.099
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 | 2022-09-30 08:24:26.099
Error getting address info for futurestrading17.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:26.099 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:26.099
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:26.099
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:26.099
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:26.114
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:26.114
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:26.114
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:28.127
Teton CME Order Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11092 | 2022-09-30 08:24:28.127
Error getting address info for futurestrading19.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:28.127 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:28.127
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:28.127
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:28.127
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:28.142
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:28.142
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:28.142
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:30.155
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 | 2022-09-30 08:24:30.155
Error getting address info for futurestrading14.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:30.155 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:30.155
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:30.155
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:30.155
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:30.170
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:30.170
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:30.170
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:32.183
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 | 2022-09-30 08:24:32.183
Error getting address info for futurestrading15.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:32.183 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:32.183
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:32.183
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:32.183
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:32.198
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:32.198
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:32.198
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:34.211
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 | 2022-09-30 08:24:34.211
Error getting address info for futurestrading16.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:34.211 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:34.211
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:34.211
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:34.211
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:34.226
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:34.226
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:34.226
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:36.239
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 | 2022-09-30 08:24:36.239
Error getting address info for futurestrading17.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:36.239 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:36.239
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:36.239
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:36.239
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:36.254
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:36.254
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:36.254
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:38.267
Teton CME Order Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11092 | 2022-09-30 08:24:38.267
Error getting address info for futurestrading19.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:38.267 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:38.267
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:38.267
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:38.267
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:38.282
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:38.282
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:38.282
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:40.295
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 | 2022-09-30 08:24:40.295
Error getting address info for futurestrading14.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:40.295 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:40.295
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:40.295
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:40.295
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:40.310
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:40.310
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:40.310
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:42.323
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 | 2022-09-30 08:24:42.323
Error getting address info for futurestrading15.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:42.323 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:42.323
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:42.323
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:42.323
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:42.338
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:42.338
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:42.338
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:44.351
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 | 2022-09-30 08:24:44.351
Error getting address info for futurestrading16.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:44.351 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:44.351
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:44.351
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:44.351
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:44.366
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:44.366
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:44.366
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:46.379
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 | 2022-09-30 08:24:46.379
Error getting address info for futurestrading17.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:46.379 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:46.379
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:46.379
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:46.379
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:46.394
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:46.394
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:46.394
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:48.407
Teton CME Order Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11092 | 2022-09-30 08:24:48.407
Error getting address info for futurestrading19.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:48.407 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:48.407
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:48.407
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:48.407
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:48.422
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:48.422
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:48.422
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:50.435
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 | 2022-09-30 08:24:50.435
Error getting address info for futurestrading14.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:50.435 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:50.435
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:50.435
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:50.435
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:50.450
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:50.450
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:50.450
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:52.463
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 | 2022-09-30 08:24:52.463
Error getting address info for futurestrading15.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:52.463 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:52.463
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:52.463
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:52.463
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:52.478
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:52.478
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:52.478
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:54.491
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 | 2022-09-30 08:24:54.491
Error getting address info for futurestrading16.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:54.491 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:54.491
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:54.491
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:54.491
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:54.506
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:54.506
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:54.506
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:56.519
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 | 2022-09-30 08:24:56.519
Error getting address info for futurestrading17.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:56.519 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:56.519
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:56.519
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:56.519
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:56.534
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:56.534
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:56.534
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:24:58.547
Teton CME Order Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11092 | 2022-09-30 08:24:58.547
Error getting address info for futurestrading19.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:24:58.547 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:24:58.547
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:24:58.547
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:58.547
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:24:58.562
Teton CME Order Routing | Disconnected. | 2022-09-30 08:24:58.562
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:24:58.562
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:00.575
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 | 2022-09-30 08:25:00.575
Error getting address info for futurestrading14.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:00.575 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:00.575
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:00.575
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:00.575
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:00.590
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:00.590
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:00.590
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:02.603
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 | 2022-09-30 08:25:02.603
Error getting address info for futurestrading15.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:02.603 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:02.603
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:02.603
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:02.603
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:02.618
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:02.618
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:02.618
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:04.631
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 | 2022-09-30 08:25:04.631
Error getting address info for futurestrading16.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:04.631 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:04.631
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:04.631
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:04.631
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:04.646
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:04.646
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:04.646
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:06.659
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 | 2022-09-30 08:25:06.659
Error getting address info for futurestrading17.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:06.659 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:06.659
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:06.659
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:06.659
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:06.674
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:06.674
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:06.674
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:08.687
Teton CME Order Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11092 | 2022-09-30 08:25:08.687
Error getting address info for futurestrading19.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:08.687 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:08.687
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:08.687
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:08.687
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:08.702
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:08.702
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:08.702
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:10.715
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 | 2022-09-30 08:25:10.715
Error getting address info for futurestrading14.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:10.715 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:10.715
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:10.715
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:10.715
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:10.730
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:10.730
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:10.730
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:12.743
Teton CME Order Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11093 | 2022-09-30 08:25:12.743
Error getting address info for futurestrading15.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:12.743 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:12.743
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:12.743
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:12.743
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:12.758
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:12.758
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:12.758
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:14.771
Teton CME Order Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11092 | 2022-09-30 08:25:14.771
Error getting address info for futurestrading16.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:14.771 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:14.771
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:14.771
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:14.771
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:14.786
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:14.786
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:14.786
Teton CME Order Routing | Firm: Advantage/Stage5 | 2022-09-30 08:25:16.799
Teton CME Order Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092 | 2022-09-30 08:25:16.799
Error getting address info for futurestrading17.sierracharts.com. Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2022-09-30 08:25:16.799 *
DTC Client socket (1) | CloseSocket call. | 2022-09-30 08:25:16.799
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-30 08:25:16.799
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:16.799
DTC Client socket (0) | CloseSocket call. | 2022-09-30 08:25:16.814
Teton CME Order Routing | Disconnected. | 2022-09-30 08:25:16.814
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-30 08:25:16.814
Added historical Daily data request for MESM22_FUT_CME to the queue. | 2022-09-30 08:25:19.747
Triggering next historical data download in queue. | 2022-09-30 08:25:19.747
Added historical Daily data request for MESU22_FUT_CME to the queue. | 2022-09-30 08:25:19.747
Added historical Daily data request for MESZ22_FUT_CME to the queue. | 2022-09-30 08:25:19.747
Mapping MESM22_FUT_CME to MESM22. Service code: cme | 2022-09-30 08:25:19.747
HD Request # 39 | Downloading Historical Daily chart data for MESM22_FUT_CME. Starting date: 1972-09-30. Service: sc_futures_direct.dtc.trading | 2022-09-30 08:25:19.747
HD Request # 39 | JSON parse error of SC External HD service: The document is empty. | 2022-09-30 08:25:19.794 *
HD Request # 39 | Error downloading historical Daily data for MESM22_FUT_CME. The server returned an error. | 2022-09-30 08:25:19.794
HD Request # 39 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MESM22_FUT_CME | 2022-09-30 08:25:19.794
HD Request # 39 | Completion time: 0s. | 2022-09-30 08:25:19.794
HD Request # 39 | Daily data download complete for MESM22_FUT_CME. Unique request ID: 27 | 2022-09-30 08:25:19.794
Removing historical data download ID 27. | 2022-09-30 08:25:19.794
Triggering next historical data download in queue. | 2022-09-30 08:25:19.794
Mapping MESU22_FUT_CME to MESU22. Service code: cme | 2022-09-30 08:25:19.794
HD Request # 40 | Downloading Historical Daily chart data for MESU22_FUT_CME. Starting date: 1972-09-30. Service: sc_futures_direct.dtc.trading | 2022-09-30 08:25:19.794
HD Request # 40 | JSON parse error of SC External HD service: The document is empty. | 2022-09-30 08:25:19.794 *
HD Request # 40 | Error downloading historical Daily data for MESU22_FUT_CME. The server returned an error. | 2022-09-30 08:25:19.794
HD Request # 40 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MESU22_FUT_CME | 2022-09-30 08:25:19.794
HD Request # 40 | Completion time: 0s. | 2022-09-30 08:25:19.794
HD Request # 40 | Daily data download complete for MESU22_FUT_CME. Unique request ID: 28 | 2022-09-30 08:25:19.794
Removing historical data download ID 28. | 2022-09-30 08:25:19.794
HD Request # 41 | Downloading Historical Daily chart data for MESZ22_FUT_CME. Starting date: 1972-09-30. Service: sc_futures_direct.dtc.trading | 2022-09-30 08:25:19.794
HD Request # 41 | JSON parse error of SC External HD service: The document is empty. | 2022-09-30 08:25:19.825 *
HD Request # 41 | Error downloading historical Daily data for MESZ22_FUT_CME. The server returned an error. | 2022-09-30 08:25:19.825
HD Request # 41 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MESZ22_FUT_CME | 2022-09-30 08:25:19.825
HD Request # 41 | Completion time: 0s. | 2022-09-30 08:25:19.825
HD Request # 41 | Daily data download complete for MESZ22_FUT_CME. Unique request ID: 29 | 2022-09-30 08:25:19.825
Removing historical data download ID 29. | 2022-09-30 08:25:19.825
Triggering next historical data download in queue. | 2022-09-30 08:25:19.825
No download requests in the queue to start downloads for. | 2022-09-30 08:25:19.825
MESZ22_FUT_CME [CV][M] Monthly #18 | Reloading chart. | 2022-09-30 08:25:19.856
MESZ22_FUT_CME [CV][M] Monthly #18 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:19.950 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:19.981
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:19.981
MESZ22_FUT_CME [CV][M] Daily #19 | Reloading chart. | 2022-09-30 08:25:19.997
MESZ22_FUT_CME [CV][M] Daily #19 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:20.090 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.121
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.121
MESZ22_FUT_CME [CV][M] Weekly #4 | Reloading chart. | 2022-09-30 08:25:20.153
MESZ22_FUT_CME [CV][M] Weekly #4 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:20.246 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.277
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.277
MESZ22_FUT_CME [CV][M] Daily #5 | Reloading chart. | 2022-09-30 08:25:20.309
MESZ22_FUT_CME [CV][M] Daily #5 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:20.402 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.433
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.433
MESZ22_FUT_CME [CV][M] Daily #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-09-30 08:25:20.465
MESZ22_FUT_CME [CV][M] Daily #15 | Reloading chart. | 2022-09-30 08:25:20.465
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.480
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.480
MESZ22_FUT_CME [CV][M] Weekly #4 | Reloading chart. | 2022-09-30 08:25:20.511
MESZ22_FUT_CME [CV][M] Weekly #4 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:20.605 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.636
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.636
MESZ22_FUT_CME [CV][M] Daily #1 | Reloading chart. | 2022-09-30 08:25:20.699
MESZ22_FUT_CME [CV][M] Daily #1 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:20.792 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.808
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.808
MESZ22_FUT_CME [CV][M] Monthly #2 | Reloading chart. | 2022-09-30 08:25:20.839
MESZ22_FUT_CME [CV][M] Monthly #2 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:20.933 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:20.964
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:20.964
MESZ22_FUT_CME [CV][M] Daily #5 | Reloading chart. | 2022-09-30 08:25:20.995
MESZ22_FUT_CME [CV][M] Daily #5 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:21.089 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:21.104
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.104
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:21.120
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.120
MESZ22_FUT_CME [CV][M] Weekly #1 | Reloading chart. | 2022-09-30 08:25:21.135
MESZ22_FUT_CME [CV][M] Weekly #1 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:21.229 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:21.260
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.260
MESZ22_FUT_CME [CV][M] Monthly #2 | Reloading chart. | 2022-09-30 08:25:21.291
MESZ22_FUT_CME [CV][M] Monthly #2 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:21.385 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:21.416
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.416
MESZ22_FUT_CME [CV][M] Daily #15 | Reloading chart. | 2022-09-30 08:25:21.447
MESZ22_FUT_CME [CV][M] Daily #15 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2022-09-30 08:25:21.541 *
Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESH15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESM15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESU15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESZ15_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESH16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESM16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESU16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESZ16_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESH17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESM17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESU17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESZ17_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESH18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESM18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESU18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESZ18_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly | 2022-09-30 08:25:21.557
The MESH19_FUT_CME.dly symbol may not be the active contract month. | 2022-09-30 08:25:21.557
[2022-09-30 13:49:09]
Sierra_Chart Engineering - Posts: 25397
To resolve this:
Try flushing the DNS cache. Refer to step 4 here:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
To resolve messages like these:
Refer to:
Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart
