Date/Time: Thu, 02 May 2024 03:32:56 +0000
delayed data feed
View Count: 376
[2022-05-05 13:54:38] |
User717130 - Posts: 3 |
My data is delayed but I am connected and paid. I have the category 5 package. I have not connected to fund account through TOS because I just want to see the volume footprint. Is that the problem?
[2022-05-05 14:23:00] |
John - SC Support - Posts: 31293 |
The only real-time data that is available for free from Sierra Chart is CFD and FOREX data. Refer to the following: Real-Time Data If you are wanting real-time data for other exchanges, then you would need to pay for it. What are the exchanges for which you want real-time data? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-05 15:17:19] |
John, Thank you for the reply. If I am reading this right, I have to connect my provider which is TD ameritrade for this to work. I just want to see NQ, ES, QQQ, SPY, and some other stocks. |
[2022-05-05 16:08:20] |
Sierra Chart does not support TD Ameritrade. You can get real-time data for those symbols through the Denali Exchange Data Feed.: Denali Exchange Data Feed You would need to activate the CME and NASDAQ exchanges. However, be aware of the requirement for a funded and supported trading account when using the nonprofessional CME fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-05 16:26:56] |
John, I activated the denali feed. No issues. "Be aware of the requirement for a funded account and supported trading account." If I understand you right, I need to sign up for another account on another trading platform that is not TD Ameritrade? Is that accurate? |
[2022-05-05 16:33:07] |
Yes, this is correct for the CME Group data. We recommend the following solution: Easy Solution to CME Funded Trading Account Requirement If you do not use the above solution, then you would need a trading account that supports CQG, Rithmic, or the Teton Order Routing Service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
