Date/Time: Sun, 19 May 2024 22:50:47 +0000
Merged TPO keeps resetting every restart of program
View Count: 550
[2022-05-04 16:34:45] |
pitbull - Posts: 12 |
Everytime I merge my daily TPO, when I re-open SC, all of it resets and I have to merge one by one again. Is there a way to stop the resetting of merged TPOs? I'm using SC data top of book and will switch to evaluation program Rithmic when trading. |
[2022-05-04 21:01:15] |
John - SC Support - Posts: 31733 |
We are not able to reproduce what you are seeing with Merged TPOs. We just tried a merge and exited from the software and started again and the merged profile remained merged. Is it possible that you are not saving the Chartbook after doing the merges? If you are saving and still having an issue then please attach a Chartbook with a chart in it that shows the problem. Please let us know what profiles you are merging together. Follow these instructions to get us a chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-31 16:05:16] |
skyfly93 - Posts: 15 |
Hello Sierra Chart, I just started using SC since version 2480 and have noticed that each time I have updated to the newest version, I lose 2 things. 1. My composite TPO chart which contain my merged TPOs are all undone. 2. The chart session settings where I have my RTH charts set to exclude the evening session are reset to include the evening session. Is this to be expected after every new SC software update? |
[2023-03-31 16:58:21] |
Sierra_Chart Engineering - Posts: 14423 |
No that does not make sense and it is not likely we can reproduce this. Most likely there is another explanation going on in your particular case. Maybe the symbol of the chart is changing. This would be the only explanation. Regarding Session Times, refer to: Chart Session Times: Session Times Automatically Changing Unexpectedly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
