Date/Time: Tue, 30 Apr 2024 05:27:34 +0000
Delayed data feed
View Count: 840
[2022-04-22 15:47:50] |
User103390 - Posts: 3 |
I've followed the instructions to change charts to reflect All SC service, and the header displays "M" after the instrument and delayed is displayed at end of chart header. How can i receive the real time data feed? https://www.sierrachart.com/image.php?Image=1650638065587.png
[2022-04-22 16:12:05] |
John - SC Support - Posts: 31189 |
You are getting the Delayed Streaming Data because you do not have any real-time exchanges active. If you want real-time data for the CME Group, then follow these setup instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you want real-time data for EUREX, CFE, or NASDAQ TotalView, then follow these setup instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-25 19:09:43] |
Thanks John, I have an active Denali datafeed, however, when attempting to initiate a trade, the DOM switches to SIM. I've read in Support Board this is due to SC All Services selection in the Data/Trade settings. I haven't moved from AMP at this time, and don't see how to connect trade service to this broker. Can you point me in the correct direction to resolve? Thanks |
[2022-04-25 19:13:52] |
John - Follow-up I selected CQG WebAPI for the trade service, no datafeed service was selected because Denali is included with the appropriate SC package. I apologize for not getting this at the beginning. Kevin |
[2022-04-25 21:18:10] |
It sounds like you have everything working now. Let us know if you need anything further.
[2022-04-26 16:55:18] |
Kvonr824 - Posts: 2 |
Hello, I used to have service package 12 but am now switching over to the delayed data feed that is free but Sierra does not connect to any data feed. Are there any settings I need to change to simply get the free delayed feed for ES and NQ?
[2022-04-26 17:19:40] |
Kvonr824: You need to set your Global Settings >> Data/Trade Service Settings >> Current Selected Service to SC Data - All Services. You also need to have an active account. The account you have posted from is expired, and you will not get any data into the system when you have an expired account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-27 16:17:49] |
Hey John thanks for the response. How do I re-activate my account? I tried doing the trial activation but that still did not work. I'm strictly looking for delayed feed data at the moment while I get back up to speed with the platform before I start paying for a service again
[2022-04-27 17:25:09] |
We see you have not used all of your Trial time, so we have given you the remainder of that time into your account - 12 days. As to the delayed data - be sure to set Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service to SC Data - All Services. You will then get the delayed streaming data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-29 05:24:59] |
Here is the documentation for the Delayed Exchange Data Feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
