Date/Time: Fri, 13 Nov 2026 21:56:28 +0000
1 minute bar count-down on my chart
View Count: 1322
[2022-04-01 00:13:36]
User946955 - Posts: 33
How can I see the count-down for the 1-minute bar on my chart
I used to have this.
Thank you
[2022-04-01 16:40:37]
Refer to the following:
Countdown Timer
[2022-05-02 01:35:26]
Hello I keep getting a message saying connection error message from service. CQG WEB API and I paid my subscription on last week is there any way you can get me connected.
[2022-05-02 15:55:07]
What exactly does the error message state? Or you can get us a screenshot of the message.
[2022-05-02 20:39:51]
Connection error message from service: CQG WebAPI Logon unsuccessful. Sever Message. Your Logon is disable. Contact your FCM. { Date-Time } 2022-5-02 20:28:59
[2022-05-02 21:29:14]
As the message states, your CQG account has been disabled by your broker. You nee to contact your broker to find out what happened.
[2022-10-17 13:44:38]
Hello I paid my monthly subscription on Oct 14th and my account is still on not allowing me to connect to live data feed. Is there any way you can help me get reconnected?
[2022-10-17 16:52:36]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2022-10-17 17:01:21]
It keep saying connection error from service: CQG Web API/ Logon unsuccessful/ Server Message. Your Login is Disabled contact your FCM. 2022.10.17
[2022-10-17 20:43:49]
Refer to number 12 here:
CQG Trading Platform Service: Common Error Messages
In the meantime:
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2022-10-17 20:44:09
[2022-11-04 12:04:27]
Hello I just made a payment still not connected can someone help with this matter.
[2022-11-04 12:36:22]
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2022-11-04 14:18:56]
This is the message that I keep getting when I try to connect. Connection error from service:CQG WebAP Logon unsuccessful. Server message: Your Logon is disabled. contact FCM Date Time 2022-11-04 14:13:53
[2022-11-04 15:03:03]
Your broker has turned off your CQG account. You need to find out from your broker why this is the case.
[2022-11-04 18:58:31]
Hello I was told by Amp Futures that this is a issue on your end that and they have no control in restoring services on their end for me so can you guys please reconnect me.
[2022-11-04 21:16:36]
What AMP is stating makes absolutely no sense. The message you are receiving is from CQG. It is specifically stating that your CQG account has been disabled. If AMP is telling you that it is not, then either you are using the wrong CQG login information on your Sierra Chart, or your account is disabled.
In either case we have absolutely no control over this. You enter the CQG information into your Data/Trade Service Settings window on your local copy of Sierra Chart. We have no control over, or any way to change this or make any modifications to it. It is completely under your control.
We are sorry that you are ending up in a "finger pointing" war, but there simply is nothing we can do on this topic. Refer to the information we have on our documentation for more confirmation. It is at item #12 at the following link:
[2022-11-05 08:49:29]
Important:
In the meantime, to access historical and streaming market data independent from your Trading service. Follow these instructions.
Press "OK"
