Date/Time: Mon, 29 Apr 2024 17:25:28 +0000
Apex evaluation (Rithmic) with denali data feed
View Count: 1644
[2022-02-27 17:41:40] |
Eric Schimmel - Posts: 1 |
I am trying to set up my Sierra Charts to utilize the Denali data feed with my current Apex evaluation which uses Rithmic. However, I am having issues with it appearing to pull data from Rithmic instead of DTC. I have activated and signed the agreements and went through the setup process. Can you help me identify what I am missing here?
[2022-02-27 23:52:07] |
These types of accounts ( evaluation type accounts) cannot be used to authorize CME data at the nonprofessional fees. This is the relevant information for this: The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. ---- You do want to set Sierra Chart to use Rithmic and once properly authorized the Denali data feed will be used even when connected to Rithmic: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-27 23:53:02
