Date/Time: Sat, 31 Oct 2026 20:12:43 +0000
Zoom Chart
View Count: 1009
[2022-02-26 09:23:53]
User471981 - Posts: 2
I am not able to zoom out the time bar (x axis) of the attache chartbook (02_M-4d-ESA) in order to see the entire outline of the 36 days right volume profile.
The strange is this happen only for this chartbook configuration. If you see the chartbook 03_8D_1d_4D you can see it is possible to zoom in as I want.
Please could you advise whick setting could be activate/deactivate, in order to fix this issue?
Thank you so much
Best regards
Giulio Scamporrino
attachment02_M - 4d - ESA.Cht - Attached On 2022-02-26 09:23:20 UTC - Size: 23.72 KB - 425 views
attachment03_8D-1d-4D.Cht - Attached On 2022-02-26 09:23:31 UTC - Size: 23.88 KB - 258 views
[2022-02-28 15:54:43]
We are not sure exactly what the issue is that you are having. When we open the chartbook, we can see the Volume by Price profiles just fine. Please get us a screenshot showing the issue you are having so we can understand better. You can take a screenshot by following these instructions:
[2022-03-01 16:29:25]
the problem is that the graph I can not tighten it, no need for a screen but we should connect remotely to show you.
Also I paid for the $46 data package but it won't load the oil and gold data for me, what should I do?
[2022-03-01 18:21:02]
You can control the size (length) of the Volume by Price study through the following Inputs on the study:
- Maximum Volume Bar Width Type
- Maximum Volume Bar Width Percentage
Refer to the information starting at the following link:
Volume By Price Study: Maximum Volume Bar Width Type
With regards to the data, you have not gone through all of the Setup Instructions for the CME Data. You will find the instructions at the following link:
Also, be aware that the CME Group requires that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have a trading account to which Sierra Chart can be connected, then we recommend the following service:
Easy Solution to CME Funded Trading Account Requirement
