Date/Time: Fri, 16 Oct 2026 14:20:42 +0000
NQ H2 dom is jumping off the current inside market
View Count: 828
| [2022-02-14 23:55:52] |
| User357195 - Posts: 204 |
Hello SC, Why is my NQH2.CME dom jumping off the current inside market price? Instead of quoting the next quote, the symbol jumps about 10 points. See this screenshot for the current inside market dom..... https://www.sierrachart.com/image.php?Image=1644882561752.png and then notice how the dom jumps to this screenshot on its own when that is not the current inside market.... https://www.sierrachart.com/image.php?Image=1644882446599.png and then it jumps back on its own to the current inside market https://www.sierrachart.com/image.php?Image=1644882561752.png I have seen this before on other symbols but usually all the is needed is to change the symbol to the next month and then change it back and it is ok. However, that is not working this time. Thanks in advance. By the way, I think SC are the best. |
| [2022-02-15 15:19:47] |
We see you are using Rithmic data. We cannot help with Rithmic data. Use the Denali Exchange Data Feed: Denali Exchange Data Feed To authorize the data at the nonprofessional fees, refer to: Easy Solution to CME Funded Trading Account Requirement For now reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
