Date/Time: Sat, 28 Nov 2026 12:12:02 +0000
Top Step
View Count: 926
| [2022-02-13 18:45:44] |
| User931998 - Posts: 3 |
Hello, I need to change my service provider from AMP to Top Step, can you please advise me on how to proceed? well thank you
| [2022-02-13 20:56:01] |
You still need to maintain a live funded account at AMP, only 100 USD, or another broker like Stage 5 for the reasons explained here: Easy Solution to CME Funded Trading Account Requirement Top step trader uses Rithmic and it is very important to read the information here: Rithmic Trading Platform Service: Rithmic Support Policy This relates to the information we gave above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-13 20:56:26
| [2022-02-14 07:42:58] |
Thank you for the information, do I still have an account with AMP? I understand it correctly? How do I connect to a Top Step account and rithmick data? well thank you
| [2022-02-14 09:48:02] |
Yes as is explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart will not provide support for Rithmic data. You will only have problems. Do not waste our time or your time on that. Here are the instructions to use Rithmic: Rithmic Trading Platform Service Here are the instructions to use the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-14 09:50:16
