Date/Time: Mon, 19 Oct 2026 15:21:03 +0000
Help with new account please. Order Flow Labs
View Count: 1433
| [2022-02-10 21:14:25] |
| TraderTom777 - Posts: 3 |
Hi there, Im going to set up the service package 11 to use with Order Flow Labs. I under stand I need live data. If the Denali Data Feed does not give live data which is what I understand from the FAQs how much will Sierra Charts (through CME) charge for access to NYMEX for Crude Oil futures? I will not be trading on Sierra Charts only using for charting and order flow labs tools. Please let me know Im very interested in getting started but confused how this works. Thank you!
| [2022-02-10 21:31:44] |
| John - SC Support - Posts: 48246 |
TraderTom777 The Denali Exchange Data Feed has Real-Time data for the CME Group. Just be aware of the CME Group requirement that you have a live, funded, futures trading account that you can connect to in order to qualify for the non-professional exchange fees. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account, then we recommend the following service: Easy Solution to CME Funded Trading Account Requirement Once you have that worked out, then you can setup the Denali Exchange Data Feed by following these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-15 17:03:00
| [2022-02-10 22:37:26] |
Thank you that makes it clear. Thank you, I do have a live account, because my broker is connected to the platform I execute on they said they need to open a second account. Just wanted to confirm if I get data with the Denali upgrade before I open a second one. Thanks so much, will be in touch when it is open!
| [2022-02-15 17:04:14] |
There was a link that should have been given in the prior post from our support that was missing. Here it is: Easy Solution to CME Funded Trading Account Requirement You do not need a second account. Just connect to the account you have within Sierra Chart. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-15 17:05:34
