Date/Time: Thu, 19 Nov 2026 20:16:36 +0000
chart padding
View Count: 1047
[2022-01-04 14:47:35]
Ken Smith - Posts: 58
I cant seem to figure out how to keep a constant space on the right side of a chart. ie: on a 10 minute chart I would like to have a space or padding of about 10 candles.
Also when I go to global settings to set the time zone, it only has NY time which starts recording on my TPO chart a few hours early. at 6:30 pst Im already on the letter G.
there doesnt seem to be an option there to change it. when I go to Global settings/time zone it only shows ( time zone ( list) New York ( -5 EST/-4 EDT)
thanks
ken
Date Time Of Last Edit: 2022-01-04 14:52:32
[2022-01-04 16:28:46]
John - SC Support - Posts: 48595
To keep a constant space on the right side of the chart you need to use the Lock Fill Space option. Refer to the following:
Working With Charts: Locking the Right Side Fill Space
If your issue is with changing the Global Time Zone, then you need to go to Global Settings >> Time Zone Settings and change the setting in there. In order to work with the new Settings Windows, refer to the information at this link:
Settings Windows Interface
If your issue is with the TPO Chart not starting at A, then refer to the following Input to help with this:
Time Price Opportunity (TPO) Profile Charts: Letters Always Start at Primary Session Start Time
Note that the primary session time would be the start of the Evening Session if an Evening Session is defined.
