Date/Time: Mon, 06 May 2024 09:47:36 +0000
No possible to get the Data Feed
View Count: 453
[2021-10-20 15:18:03] |
User833386 - Posts: 4 |
Dear Sierra Chart Team! Unfortunately its not possible for me to get any Data Feed in Sierra Chart! I have AMP as my brocker, an yesterday i got my login data for CQG. I already connected Sierra Chart with CQG WebAPI, but I get no Data. Only "Symbol is unknown" and "Download failed" at every Chart. Maybe you can help my to fix my problem. Kind regards from Austria |
[2021-10-20 15:58:07] |
John - SC Support - Posts: 31379 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-20 19:35:51] |
Hi! Thanks for your reply. I got the following message: "Notice: You have no exchanges enabled for renewal on the Denali Exchange Data Feed service. To activate exchanges, use this link here:" I don't activate any Data Feed, because I paid for the "Active Service: 11 - Advanced + Denali Data Feed" Why its necessary to pay another USD 31,20 to get Data Feed? |
sierra006.JPG / V - Attached On 2021-10-20 19:32:45 UTC - Size: 108.31 KB - 122 views sierra007.JPG / V - Attached On 2021-10-20 19:32:51 UTC - Size: 172.23 KB - 114 views |
[2021-10-20 23:37:41] |
Package 11 includes the Denali Exchange Data Feed Fee. This is a $10.00 per month fee for the data feed itself. It does NOT include the cost of the exchanges. Therefore, to get the real-time data, you will need to ensure that you have gone through all of the Setup Instructions for the Denali Exchange Data Feed for the CME Group at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* As part of that process, you will activate the exchange(s) that you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-20 23:37:54
