Date/Time: Tue, 07 May 2024 21:00:15 +0000
CHANGED SERVICE PACKAGE...NO LIVE DATA
View Count: 672
[2021-10-19 20:41:42] |
User443396 - Posts: 4 |
I UPGRADED TO SERVICE PACKAGE 5 SO I COULD USE TPO CHARTS. NOW I DON'T HAVE LIVE DATA FEED. WHAT DO I NEED TO DO?
[2021-10-19 21:46:35] |
You need to change your Sierra Chart account to Service Package 11: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-05 23:48:47] |
No data feed again. Did I not set the account up properly again?
[2021-12-06 00:06:04] |
We have heard some users are having a problem connecting to Rithmic. So that must be the cause. We have to contact Rithmic about this. For now to at least access market data: Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "Ok" And then translate the symbols in your Chartbooks and Sierra Chart: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-06 00:06:11
