Date/Time: Wed, 01 May 2024 23:47:11 +0000
Lagging of current sierra version
View Count: 344
[2021-10-12 15:13:35] |
User626859 - Posts: 2 |
I went back to 2308 and that didn't fix it, I was on 2292 before I went to 2318 or whatever we are on at the moment. I checked CPU load and that's not a problem neither is RAM there is over 50% open RAM (I run 32gb)
[2021-10-12 17:10:11] |
John - SC Support - Posts: 31293 |
The only thing we can refer you to is the following, and also the section after it: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.47 - Use Sub Instances to Distribute Processing Load For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 13:33:33] |
I've never had this issue before the update tho, and it's not like displaying a ladder should use a lot of resources? And after the open its usually fine, I've checked CPU load and that doesn't go above 30%, if you could let me know what else I could look into to see whats causing it Date Time Of Last Edit: 2021-10-13 13:34:33
[2021-10-13 14:02:09] |
Refer to all the items on this page: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often If the market data is lagging also refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-13 14:02:20
