Date/Time: Tue, 30 Apr 2024 09:22:25 +0000
Delayed Data Only
View Count: 449
[2021-10-08 00:06:23] |
Jono_VWAP - Posts: 10 |
Firstly i had issues connecting Rithmic Data to Sierra Charts for Leeloo Trading, i am able to connect to the platform but the data is incomplete making my Vwap and other studies look weird. i read this may be due to the data so i connected to the Denali data of which i followed all steps i could, now when i follow all set up steps my data is still delayed. can you help please? |
[2021-10-08 00:22:58] |
John - SC Support - Posts: 31189 |
The reason you are not getting the real-time data is that you have not properly completed the Exchange Agreements. You need to put down the actual broker for which you have a live, funded, futures trading account. Keep in mind, you need to have a live, funded, futures trading account that can be verified in order to get the non-professional exchange rates for the CME Group data. For more information, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a live, funded, futures trading account, then we recommend the service outlined at the following link, which can be opened for as little as $200, which will just stay in that account: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-08 10:03:49] |
I am doing a Funded Challenge for LeeLoo. Do I Put LeeLoo or Rithmic?? |
[2021-10-08 14:44:19] |
Neither of those are acceptable to authorize nonprofessional CME real-time data. It must be a normal funded trading account of your own. For a low cost account, refer to: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-08 14:45:06
